04-18-2018, 06:19 PM | #265 |
Rep 1,912
Also can any one check there Carly adapter & see if these 2 pins are the same height.
Happy Motoring
Evdok |
04-19-2018, 05:58 PM | #266 |
Rep 1,912
Emailed Carly about this as no one replied , this was the reply to my email.
"Hello Don't worry this is okay It's just for safety reasons, so that the ground connection will be disabled at least" no idea what it means
Happy Motoring
Evdok |
04-21-2018, 12:53 PM | #268 | |
Rep 292
Drives: 2014 335i 6MT MSport
Gonna play with the seatbelt nag noise settings later. I hate having that go off if I'm just driving from the mailbox to the garage...
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
04-23-2018, 10:36 AM | #269 |
Rep 45
Yes, it shows on the iDrive screen. Disabling the legal disclaimer makes it so you don't have to click OK every time the car starts up. Changing the animation actually changes the iDrive start up animation. This only appears after the car has been turned off for like an hour or something, it doesn't show up every time you start the car. I forget the exact time frame.
04-29-2018, 09:48 AM | #270 |
Rep 24
I gave Bimmercode a try and am scared I won't be able to stop using it!
Here is what I did: Removed legal disclaimers (it was annoying at the front end of the car on top view) Extended the Park Assist Distance (so it doesn't shut down so quickly) Removed the 1,5 second delay on confort access so mirrors fold right away Delayed the seat belt chime to 500 meters so it is not harassing immediately Enabled door handle leds while reversing (this is really cool) Changed animation to M (because why not, I have a M kit at the end) Extended the welcome lights to 60 seconds I have a couple of questions : Has anyone setup lights when you you lock the car and walk away? Do you have any other cool tip you can share? Thanks! |
M3 Adjuster7909.00 N26Ghost496.50 |
04-29-2018, 01:34 PM | #271 |
Rep 292
I did this (and I have M Sport!) but it's only showing generic BMW letters in Helvetica. Do you need the wide screen for this?
04-29-2018, 02:34 PM | #272 |
Rep 24
04-30-2018, 08:46 AM | #273 |
Rep 1,615
I got bored over the weekend and "un-coded" it, tested then re-coded it...no issues to report.
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
05-06-2018, 02:18 AM | #275 |
Rep 4
Can you achieve this through the bimmercode app? http://www.bimmerfest.com/forums/sho...d.php?t=646514
05-06-2018, 09:23 AM | #276 |
Rep 30
I have it coded, but I don't really any difference between this and the regular sport mode. I thought this was going to be the sport+ that everyone was talking about, ah well.
05-06-2018, 11:25 AM | #277 | |
Rep 1,615
05-14-2018, 06:25 AM | #278 |
Rep 374
Drives: 2017 540i
I second this. Car already had sport+ , but did not show "S1, S2, etc." on the gauge cluster when putting in the DS (M/S to the left) (My car is a sport line but I did not order the car with the Sport Automatic Transmision option - 2TB). After coding, gained the faster shifts in DS/Sport+. Was super easy and the result is awesome.
2017 540i :: 2006 M3 :: 2012 328i Sport Line (sold)
05-15-2018, 06:18 AM | #280 |
Rep 85
On a f36 can i Turn on Video in Motio with bimmercode app? Also watch dvd when driving?
Can I also activate SPORT+? I now have Carly and the options are limited. Thanks |
05-21-2018, 05:03 PM | #282 |
Rep 26
On the transmission section, if you go to advanced there’s an option to disable “Allrad” which translates to all wheel. Haven’t tried it but this might potentially disable x drive for some rear wheel fun.
05-24-2018, 05:23 PM | #283 |
Leave the gun. Take the Canoli.
9119
Rep 7,665
Has anyone successfully coded the driver seat to move back when you open the door using Expert mode? A few of the settings that I've read you have to change don't have options to actually change.
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40 --> 2025 X5 M60
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
05-24-2018, 05:27 PM | #284 |
9119
Rep 7,665
Anyone know where to find this in Expert mode to disable the trunk foot opening
FEM_BODY > CAM_SMART_OPENER = nicht_aktiv
05-30-2018, 04:54 PM | #285 |
Rep 525
Folks, please help me.
Much to my disappointment, i cannot see the 'folding mirrors on lock' option anywhere in bimmerapp. I have a 440i coupe, August 2016, i'm in the UK. The car has external folding mirrors but i have to press a button for that function. It does not have comfort access. All i want to do is for the mirrors to fold when I press the lock button on the fob, and likewise, unfold when I unlock. In the bimmerapp menu in Simple mode - I go into the electronic ECU section, and all i can see is an array of comfort access related stuff, and its all active. but i can't see the option to actually do what i want above. is this in expert mode? if so....which code is it? EDIT: IGNORE THIS....got it working. Thanks to this post https://f30.bimmerpost.com/forums/sh....php?t=1438566 Last edited by gippy; 05-30-2018 at 05:22 PM.. |
EDWYER1676.00 |
05-31-2018, 12:09 PM | #286 |
Rep 1,061
I used Bimmercode to add video on motion but I've been having an issue getting my '15 435i to read my USB.
My 64 GB Sandisk USB drive is formatted using my Mac for FAT32, which to my understanding is compatible w/ BMW but I'm getting a consistent, "Not supported" error. Is there something I'm doing wrong? |
