BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > REVIEWED: KW Street Comfort fitted (with other bits n bobs)
      01-01-2018, 11:44 AM   #23
MattRST
Drives: F30 335d
Great review ! I'm completely on board with the "how suspension should be comments" until you've driven a car with proper suspension it's hard to believe how much of a difference it can make .
You've convinced me. Had ohlin DFVs on my previous car but will now consider the KWs
Cheers
Current: F30 335d xDrive M Sport Plus
18" MPS4 - 405Ms - ACS Springs - Eibach 16mm ARB - Indigo GT Remap
Regret selling: Mitsubishi Evo X
      01-01-2018, 11:58 AM   #24
Dr Forinor
Dr Forinor's Avatar
Drives: 2015 F31 335d
Cheers
I'm glad it helped you.
I am a fairly enthusiastic driver, I like my twisty roads but as I've gotten older the ride comfort has climbed up the priority list.
For someone like me, [meaning someone who is NOT going to track the car, or go all out on public roads and absolutely wring the neck off the thing], this is a great piece of kit.
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs. Poly bushes.
MattRST87.00
      01-01-2018, 05:13 PM   #25
DonDP
DonDP's Avatar
43
Drives: F31 330d / Z4M Coupe
Nice review, thanks for taking the time to write it.
I am still considering what route to go with my setup. Currently on M-sport struts with ACS springs. I think I have narrowed it down to 3 options now. The ACS struts to match the springs, Bilstein B8 struts with existing springs or the KW street comforts.
However, reading this review makes me think its now between 2. Full ACS or Full KW.... decisions decisions... would be good to get a comparison between your new setup and the m-sport struts with ACS springs...
      01-02-2018, 06:45 AM   #26
Dr Forinor
Dr Forinor's Avatar
I think either way, you need to go "Full whatever". Mixing an aftermarket component with an original component will only do half the job, and it will still never be right.
McBeemer183.00
      06-13-2018, 03:14 PM   #27
ryanwarriors9
Drives: F30 335D
After reading your thread Iím swaying towards the kw but not sure which ones yet. I have a 335d x drive with adaptive suspension with eibach pro springs but I think a front shock has gone so leaning away from the adaptive system as itís a fortune to replace when I can just go for a set of coilovers. My only issues are and concerns at the min are the lights on the dash that it may throw and getting around the edc system
I have read a few people having issues with the delete kits and that it affects the steering set up as the car still thinks itís there but it isnít
Hope you can help with a bit of advice
Cheers
Ryan
Ps I have already sent you a pm before seeing this post
      06-14-2018, 02:42 AM   #28
Dr Forinor
Dr Forinor's Avatar
Originally Posted by ryanwarriors9 View Post
After reading your thread I’m swaying towards the kw but not sure which ones yet. I have a 335d x drive with adaptive suspension with eibach pro springs but I think a front shock has gone so leaning away from the adaptive system as it’s a fortune to replace when I can just go for a set of coilovers. My only issues are and concerns at the min are the lights on the dash that it may throw and getting around the edc system
I have read a few people having issues with the delete kits and that it affects the steering set up as the car still thinks it’s there but it isn’t
Cheers
Ryan
Hi,
Read your PM, but I'll reply here for the benefit of someone else who may also want to know.
I have the KW Street Comfort kit, which for me is brilliant. It is designed more towards to the "relaxed comfort" side rather than the "sharper handling" side, and that's what I want. It's a family car, and so for that reason I wanted comfort to be primary to handling, but I wanted little compromise in the handling department. So as far as that is concerned I think this delivers just fine.
In regards to the adaptive suspension, I got the KW Delete Kit that was fitted alongside the KW Street Comfort and have had no issues with anything at all so far.
Hope that answers your question.
      12-09-2018, 02:56 PM   #29
devil84
Drives: F36 430D X Drive
Hi guys thread revival. OP - 6 months down the line how you finding the KW street comfort set up?
Did you got for DDC? Interested why you did not go for that one?
      12-10-2018, 03:36 AM   #30
Dr Forinor
Dr Forinor's Avatar
I am very happy with the setup. The weakest link now is the runflat tyres, which I hope to resolve this summer coming.
DDC? Sorry it's been a while since I looked into this, what's that?
      12-10-2018, 06:48 AM   #31
Watsey
Originally Posted by Dr Forinor View Post
I am very happy with the setup. The weakest link now is the runflat tyres, which I hope to resolve this summer.
DDC? Sorry it's been a while since I looked into this, whats that?
DDC is KW's branding for EDC-compatible dynamic dampers. Plug-n-play.
Current : F31 330sD, DMS remap, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech BBK with Pagid RS4-2 pads, Birds ARBs.
      12-10-2018, 06:58 AM   #32
Dr Forinor
Dr Forinor's Avatar
Ah, thanks.
I preferred to have passive shockers rather than dynamic. Just personal preference I suppose but I'm much more comfortable with knowing what my suspension can take since it's at a fixed rate as opposed to "changing all the time" (dynamic).
      12-10-2018, 07:43 AM   #33
Watsey
Ah, thanks.
I hold the same view - passive dampers provide the predictability which I value more than having switchable modes.
