02-25-2021, 01:14 PM | #1 |
Rep 134
Coilover Install DIY or by Shop
I have just purchased BC coils and am considering installing them myself but I also got a quote from a local shop to do the install/alignment for $350.
I was curious based on members opinions on here if I should consider doing this install myself or just bite the bullet. I am relatively mechanically inclined and have done installs such as Downpipe Chargepipe etc but I would need to purchase or rent spring compressors etc. Maybe even purchase a torque wrench as well. |
02-25-2021, 03:36 PM | #2 | |
Rep 1,934
02-25-2021, 06:29 PM | #3 | ||
Rep 3,539
That said, if you don't already have those parts, you might also need some of the less common torx/etorx and passthroughs our cars require. You can see all the tools used in my video below. If you find you're lacking lots of the tools required, $350 really doesn't seem like much for someone else to do it. Or you can always use it as an excuse to go on a tool shopping spree ! Quote:
02-27-2021, 04:42 AM | #5 | |
Rep 525
i'm one of those that did it myself following ISTA + Farkle; it was a bit of a pain at times, was on my own, but in the end all the better for it and a very satisfying experience. However my reasons were doing it were to save money in the long run i.e. if i fancied swapping them out again + i wanted the general knowledge as i track the car and wanted to learn so i could make upgrades in the future. In the short run, it might end up being almost as expensive as taking it to the shop, simply because of the tooling required, so it totally depends; if you already have some of the tools, then great, might as well have a go yourself. if however you don't, and you're only ever planning on doing this once and leaving these new coilovers in your car for years, then probably just pay the 350 and let them at it. |
03-01-2021, 10:57 AM | #6 |
Rep 1,649
I am a DIY guy, so my gut response is do it yourself. But I think you should be realistic and ask yourself if you are ready to jump in. While swapping the suspension isn't terribly hard, without the right tools it would be a frustrating experience. It sounds like you don't have much in the way of tools so buying the right stuff will cost you close to what you have been quoted or maybe even more. As others noted there are things like torx bits, pass through sockets, etc. that are necessary and then other tools that will make it go much smoother. If you plan do this kind of work in the future or are looking to start building a tool box for this project and future ones/cars, then go for it. I find it very satisfying to do the work myself. Watch Farkle's video a few times to get a feel for it and also to take notes on the tools you will need. ECS is a good spot for a lot of the things you'll need. Schwaben makes them and are reasonably priced.
03-01-2021, 03:40 PM | #7 |
Rep 1,288
$350 is a no brainer... mine was double that...
03-01-2021, 08:35 PM | #8 |
Rep 785
Makes me a little nervous about the quality of the work... Seems like a pretty good deal considering an alignment is close to 100$ by itself
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
03-02-2021, 09:31 AM | #9 |
Rep 1,288
I can see your point... I still had to help them figure out how to adjust my coilovers properly since mine has double adjustment... but BK are pretty straight forward... suggest watching a BK install video and then watch/ help them install...
03-02-2021, 02:29 PM | #10 |
Rep 320
Depends on what you plan on using the car for...if there are track days ahead then the knowledge may prove indispensable later on. 350 is a good price assuming it is done properly.
I didn't use spring compressors for removal of the stock springs or installation BCs so I doubt you will need them. Setting the ride height was the most time consuming step for me because you have to remove the wheel, turn the collars, put the wheel back on, settle the suspension and measure. |
