05-29-2022, 11:43 PM | #45 | |
Rep 26
How long you with that? |
05-31-2022, 08:56 PM | #46 | ||
Rep 234
06-27-2022, 05:36 PM | #47 |
Rep 33
More research and info for this thread.
The issue only happens when the oil cooler stat opens starting at 69°C and fully open by 75°C. For me the car drives perfectly before the stat opens. I confirmed this by using Bimmerlink to monitor the trans temp while driving around. My theory is that when the stat opens its starves the sump of oil causing the transmission oil to be too low for certain gears. I attempted to top up the gearbox oil following the ZF procedure and it has improved the issue somewhat, I used to get the judder at 69°C exactly and now it needs to be hotter, i.e. when the valve is fully open. I may try to get more oil into it, but to be honest I followed ZF's procedure exactly so I not sure how I'm going to get more in for the 0.5 overfill, it was dripping out, but perhaps I need to be more aggressive forcing it in before closing fill plug. Its a tricky procedure. In any event here is the procedure. Note: You will need to keep the engine running during the procedure. If you don't, the transmission will piss out oil when you open the fill plug. Its tricky given the Auto stop start likes to cut it out on regular intervals and there is no button to disable in the 330e. Your options are have another person rev it periodically during the fill to keep it running or code auto stop start out temporary with bimmercode (you need to have the engine running during coding to do this - its a bit of a hack and you will get a light on the dash but its only temporary and can easily be coded back). ZF 8HP automatic transmission: Checking the oil level
08-12-2022, 07:05 PM | #48 |
Waylander
Rep 7
So I've finally found out this damn issue after a year and tons of money spent, turns out it was my fuel vent valve(solenoid) which is part of the evap system(the valve is near the intake manifold). Had it in with bmw and they told me these valves fail alot in the 330e's due to corrison. Not sure if you guys got a check engine light(around a month after symptoms showed up) but I eventually got a running rich code which pointed to this issue but I've read sometimes a code may not show up. Cost of repair was 380 quid. Worth checking your evap system for vacuum leaks just to rule this out. Also you will know it's the fuel vent value if you are having issues filling up at a petrol station because the petrol refill will keep clicking when your filling up.
08-13-2022, 03:43 AM | #49 | |
Rep 584
[/B]2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
08-16-2022, 06:49 PM | #50 | |
Rep 33
08-21-2022, 03:03 PM | #51 |
Rep 5
is it an X-Drive? If so, then I had the same issue and it turned out to be the Transfer case (sending drive to the front wheels)
£4k later paid for by the dealer and problem solved, ran as smooth as butter |
08-29-2022, 06:09 AM | #52 |
Waylander
Rep 7
Well that didn't fix the issue back in with BMW tomorrow they think it's carbon buildup on the values because our cars are direct injection and mines got 195km so they could be on to something. I think your issue could he carbon build up aswell and not transmission related at all.
08-29-2022, 07:43 AM | #53 | |
Rep 33
I think your issue is potentially not the same as the one described in this thread. A carbon build-up is very unlikely. The B48 does not generally suffer from carbon build up issues which were very prevalent on the N style engines https://www.northamericanmotoring.co...b48-check.html It sounds like the dealer is adopting a hit and hope approach which will ultimately end up costly for you. One quick way to know if your issue is the same, is to get the transmission temperature up to 75C. You can use BimmerLink to monitor this if you can get your hands on an compatible OBDII adapter (or just bring it for a 20 min drive - should be up to temp by then). Get the car the 68km/hr at 1500rpm on a clear road. Gently squeeze the throttle through the rev range of 1500-2000. You should get a violent vibration that feels like its coming from the rear if its the same issue. The issue should more less be replicable every time as long as you are up to temp. The issue doesn't happen for me at all up the car is up in the range of 71-75C transmission temp. The trans cooler thermostat starts to open at 69C. |
08-29-2022, 09:08 AM | #54 | |
Waylander
Rep 7
That's similar to what's happening to me but the vibration is more in the front kind of like the whole car is shaking. I'm getting a running rich code also so I think it's misfiring under heavy load,bmw technician said all cylinders were misfiring slight rough idle aswell. Carbon buildup can happen in these cars because they are direct injection. They have done a leak down test and compression test and all is fine there so it's surely carbon buildup. They are doing it for free aswell so might aswell try it. |
08-29-2022, 09:13 AM | #55 | |
Waylander
Rep 7
10-07-2022, 12:34 AM | #56 |
Rep 2
Hi!
Anybody figured out yet the juddering problem? Im having the same issue with my 330e. Got error codes from trans switching from 7th to 8th gear, after that plenty of other codes from electric motor etc. But the first one was from trans, it did the juddering now and then before this. |
04-19-2023, 01:46 PM | #59 |
Rep 1
New 330e owner checking in.
2017, 116k miles. Same issue as described in the thread. Seems a bit of a coincidence that a bunch of us are experiencing it. It's definitely only when the car has been properly warmed up. A shuddering just under 2k revs, from the back, somewhere between 6th and 8th gear. It would be nice to get to the bottom of this. I've got a 2 year warranty from the dealership I bought it from, so if it's a gearbox issue it should be covered. This thread seems to have died a bit, but I'd love if someone got this sorted and could share. Thanks |
04-26-2023, 01:36 AM | #61 |
Rep 9
I didn't have this exact same issue, but mine acted like this: Sometimes on cold starts putting it in drive and trying to go forward it couldn't, and would barely creep forward. And if i would rev it the revs would climb but the car wouldn't start going anywhere, and after like 1 sec it would then launch forward spinning the wheels instantly because the high revs it got. Ended up at the dealer alot of times, where they constantly wanted to pull codes.. but there was never any codes. After some time they wanted to replace trans so they did that. Calmed down the problem a bit, and after the change didn't completely fix it they also changed the mechatronics. And that fixed it
04-27-2023, 01:48 AM | #62 | |
Rep 11
Do you believe that the mechatronics was the main fault all along? (Also, what is the mechatronics? ) |
04-27-2023, 11:47 AM | #63 |
Rep 9
08-05-2023, 07:53 PM | #64 |
Rep 1
Hey lads.
Recently got a 2016 330e, 82k miles. It spent 7 weeks in a garage fixing the charging. Had it for two weeks beforehand and on occasion this would happen but on a one off instance. Since I've had it back from the charging repair, it's pretty much an identical issue as everyone above, word for word with how everyone else's is. One thing I've noticed as well is that once it happens on a drive, it will continue to do it for me until I get home or to my destination. Next time I drive it's fine until I stress it with a hard accel, and from then onwards it won't stop. I've had my gearbox serviced and fluids replaced today by a BMW specialist, but the same issue is occuring again. He said that the fluid was in desperate need of changing, but the mechanical aspects of the gearbox looked good, and there were no error codes at all from both engine and gearbox. I am going to replace my spark plugs tomorrow and hopefully get the coils done in the next few days myself, as I feel like it may be a fuel related issue as opposed to the gearbox. Will update if this makes any difference. But please, if anyone here has had some success in fixing this issue please reply, it would be greatly appreciated! Thanks |
08-06-2023, 03:24 AM | #65 |
Rep 584
Friend has a 18 month old X5 45e. Was getting slight shutter on acceleration. Wasn't always present. Went to BMW and they diagnosed it as a failed component in the gearbox. Apparently the days that only 4 gearboxes failed globally. So the replaced the gearbox and BMW requested the failed unit be returned for investigation.
Luckily he's under warranty. Otherwise a new replacement would cost €14,000 ! |
11-10-2023, 09:10 AM | #66 |
Rep 33
If you read the comments, one of the guys has a 330e from 2016. He changed the entire propshaft and it fixed the problem. Anyone tried this and had success? - I'm sceptical because it only happens when warm, and it doesn't make sense to me that the prop would only behave like this when the car is warm. The propshaft is also pretty expensive, about €1,400 from BMW. If it is something to do with the propshaft it's unlikely to be the whole thing. It could be the center mount or the guibo (rubber prop shaft coupler) which are a bit more reasonable to replace. |
