05-02-2020, 01:48 PM | #1 |
Rep 217
180001 DME Code
Hey all,
I have been chasing down a boost leak recently (120308) and so I swapped my CTS CP for a VRSF one. I was checking my DME codes yesterday and noticed I had an 180001 DME code. From what I can tell it only comes on when the boost leak is present which is at high RPMs. For mods I have: - MHD Stage 1 OTS Map - VRSF CP - Panel air filter From the reading I have don't it is a MAP sensor, O2 sensor or my Cat. Any suggestions? |
05-02-2020, 02:18 PM | #2 |
Rep 7,733
What made you think you had a boost leak? Did you physically test or infer from logs? If logs, post those where you think there is a boost leak.
Is your cat monitor in the ready state? |
05-02-2020, 03:18 PM | #4 | |
Rep 7,733
If you clear the code does it come back immediately? You need to get some logs, or pressure test, or both. With so little information/data, we can only guess what the issue might be. Also the sequence of events isnt clear. You installed CTS CP, then got the drive moderately message and indciated error code? Then you swapped to VRSF and got the same thing? Did you verify your orings? Made sure to teflon tape and tighten the bung plugs in the CP? |
05-02-2020, 03:23 PM | #5 |
Rep 217
Ok so here's some specifics
- The drive moderately comes on at high RPMs only - It comes on every time I clear it (and drive into high RPMs) - When pilling up the DME history is 120308 and 180001 - I did a smoke test and I know it's coming from the CP to IC connection. I am waiting on new o rings - I am asking more specifically about diagnosing the 180001 not the 120308 |
05-02-2020, 04:42 PM | #6 | |
Rep 7,733
