09-27-2018, 12:11 PM | #1 |
Rep 776
ZGM Flexray Synchronisation failure
I am having an intermittent Flexray synchronisation failure that is causing my ZGM module to store a fault (17 instances according to Ista). SA is saying that he cannot look at "electrical gremlins" until it causes an issue. Anyone else seen Flexray synchronisation faults? This is on F31. Thanks in advance.
10-05-2018, 06:51 AM | #2 | |
Rep 10,351
Just drop a comment in any of his posts and he'll answer you within a day. He's a technician at a BMW dealer with years of experience.
"Drive more, worry less. "
10-05-2018, 09:58 AM | #3 |
Rep 235
I've done a ton of retrofits and mods to my car and I see this one pop up all the time on ISTA as well. I haven't noticed any symptoms as a result of it so I just ignore it, but if you do find out please report back here.
02-24-2019, 04:21 PM | #4 |
Rep 60
Just reading some old posts and found this one. I have F31 and noticed the same Flexrey sync issue. I believe it was only if I connected Ista with ignition on and car not running. When car was running and then ista was connected no issue was detected.
02-25-2019, 03:19 AM | #5 | |
Rep 3,947
03-05-2019, 03:19 PM | #6 |
Rep 776
Thanks for the followup.
I wondered if it was related to ISTA, but I recall having some mileage stamps where I knew I was not connected, so I dismissed the idea. That car is gone now, will see if it pops up on the ole replacement. |
08-22-2021, 07:10 AM | #7 |
Just an F Series Owner
22
Rep 67
hi, probably its a bit late...
i also have an intermittent fault ZGM. Flexray synchronization process failed. would it be an issue? |
