11-13-2019, 12:32 AM | #1 |
Rep 44
[HELP] Smoke on passenger side engine bay
I've recently noticed a faint white smoke and burning smell coming from the passenger side engine bay of my 435i after driving anything more than a couple miles.
It looks like it's coming from the o2 sensor (could be wrong) but I can't tell if that's the actual problem or just a symptom of a bigger issue (leak somewhere?). There's no engine light and oil levels look fine. I have CPO warranty for one more week so I'm planning to take it in and get it checked, hopefully covered. But before I do, anything I should check beforehand that i'm missing? Also, why would the sensor corrode like that? Thanks. https://streamable.com/ View post on imgur.com |
11-13-2019, 07:44 AM | #2 |
E4 Mafia
328
Rep 418
Drives: E30, E36/5, E46x2, F22, F30
Garage List 2004 BMW 330xi [0.00]
1990 BMW 325i [0.00] 1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
I didn't look at the video but my guess would be a leaking valve cover gasket. oil leaking down and burning on the exhaust. dealer will replace it if necessary.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k) | '04 E46 330xi MT (198k) | '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
11-13-2019, 08:35 AM | #3 |
Rep 694
I just dealt with this on my E93 335. Mine was a leaking rear main seal about 140k miles on her. Drips down on the catalytic converter. Repair was expensive and my guys in my bodyshop werent comfortable doing it. We took an old heat shield from a wreck and diverted the oil away from the cat.
Take it to the dealer and they will tell you the car is going to start on fire etc etc. Sucks but seems to be pretty common (and embarassing when stopped at a light) |
07-04-2022, 03:22 PM | #4 |
Rep 1
Hello Tommy, you mentioned using old heat shield to diverte the oil drip away from the cat, did that actually work? I'm having a slow leak but if this trick will work, I'll try it.
Paul |
07-05-2022, 10:47 AM | #5 |
Rep 7,607
