12-03-2014, 12:44 PM | #244 |
Rep 398
im not getting the target list either,i have tried uninstall/reinstall as well,it is the latest link from shawn,any ideas
f31 330d mineral grey/black interior with extra stuff fitted
12-03-2014, 01:05 PM | #245 |
Rep 8,636
All I did was delete all the pszd data from the directory, download the new lite data from shaun, unzip and copy it in to the dir and it all started working.
12-12-2014, 10:43 AM | #247 |
Rep 398
when i input the generated activation code it goes back to the start and asks for the code again,im on europe next 2015-1 maps on the generator,what have i done wrong and can anyone check my imput file to see if i have messed it up
12-12-2014, 11:31 AM | #251 |
Rep 398
i should have said that when i try to attach it,it says invalid file is there a way round that
12-12-2014, 11:49 AM | #253 |
Rep 1,894
Try: DX534O2VHRNECAFJAADA
File looks fine to me. Did you copy the FSC.exe from NBT_FSC folder into the tools directory? If you did can you send me your lookup.xml file? |
12-12-2014, 12:01 PM | #254 |
Rep 1,894
Doh! I thought you had issues generating the code.
Couple of the more obvious things: When you enter the code, the 'O2' did you use a number zero or the letter O? Why not try both! Have you got the NBT or CIC? Have you downloaded the correct NBT 2015-1 maps? |
12-12-2014, 12:08 PM | #255 |
Rep 398
tried both 0 and o,its nbt ive got and pretty sure its the right maps,will double check
12-13-2014, 03:48 AM | #257 |
Rep 398
got it now,not being carefull enough when putting in the code i think,thanks for your help kitster
12-13-2014, 09:45 PM | #258 |
135 to 335 M Sport to X3 30d M Sport
164
Rep 1,788
Drives: 2018 X3 30d, optioned up!
For anyone else in Oz watching this thread, I successfully generated the same FSC code that I bought for the 2014 maps, so then thought 'Woohoo', onto generate a new one for the 2015 maps, but...
... Australia isn't in the list in the generator software :-( Update: Okay, research indicates I need to edit the LOOKUP.XML file and add one for the Australia/New Zealand maps. However, I don't know the details for the entry. Kitster, you indicated it was pretty simple, but how do you work out all of the values?
2018 X3 30d, Carbon Black Metallic, M Sport Package, Panorama glass sunroof, Lumbar support, Instrument panel in Sensatec, Ambient Lightning, Harmon Kardon Surround Sound , Dynamic Damper Control
12-14-2014, 02:10 AM | #259 |
Rep 1,894
You need to insert a new entry into your lookup.xml.
Example: <SgbmId id="NAVD_000014BA_255_001_091" SWID_FscShort="00AA0003" name="Road Map AUSTRALIA / NEW ZEALAND Next 2014" supplier="TAS" sop="01.07.2012" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/>
The rest remains the same. Normally I would test this out before posting but based in the UK, the Australian/New Zealand maps are no good to me |
12-14-2014, 02:11 AM | #260 |
Rep 1,894
12-14-2014, 05:03 AM | #261 | |
164
Rep 1,788
Here's a directory dump of the Aus/NZ 2015 files, if that helps: Based on other entries, I have added another entry and changed to this: </SgbmId> <SgbmId id="NAVD_000014BA_255_001_092” SWID_FscShort="00AA0004” name="Road Map AUSTRALIA / NEW ZEALAND Next 2015” supplier="TAS" sop=“14.10.2014” version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> Will give it a go now...
12-14-2014, 05:11 AM | #262 |
Rep 1,894
When you unpack the rar files, they normally appear in a folder called (like): NAVD_000014BA_255_001_091, in which you will find the 1,2,3 ....directories etc etc.
Based off the last Oz 2014 map, the code was NAVD_000014BA_255_001_091, why not try NAVD_000014BA_255_001_092. Worst case it'll generate a bad code which your car will reject. |
12-14-2014, 05:28 AM | #263 | |
164
Rep 1,788
