BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Is it possible to retrofit the Supra/M340i HPFP?
      10-22-2019, 05:22 PM   #23
SC_B5X
SC_B5X's Avatar
Drives: 2016 BMW 340i
Originally Posted by kern417 View Post
Yeah that makes more sense. Anyone that I ask running 20+psi has a custom tune with meth. I just wanted to be sure.
If you're hitting a fuel limit then you need more flow. I'm not sure adjusting the mix will help. More/bigger nozzles are in your future.
Is there a reason people don't just drill/tap the manifold and run 6 nozzles?
Edit: duh. intercooler. nevermind.
Yup, if intercooler wasn't in the way I would be using the ProMeth hard line kit like they have on the N54/N55. Oh well. I'll probably upgrade to ProMeth 630cc Nozzles and see if that helps. My plan for the next year is to go with a HPFP upgrade and pick up a Big Boost kit. I'd like to comfortably make 650whp, maybe 700whp on kill mode.
Instagram: SC_B5X
2016 BMW 340i M-Sport Pkg
Pure 800 Turbo, Dorch Engineering Stage 2 HPFP, VRSF 4.5" Downpipe, Remus Axleback, CTS Turbo Intake, 8HP70 Transmission Swap w/ XHP Stage 3 Trans Tune, and Custom E50 Wedge MHD Tune
      10-25-2019, 04:02 PM   #24
CntryClub007
CntryClub007's Avatar
Drives: 2016 340i | 2013 X5-35i
I agree, same boat as you. My JB4 has recently been going into Map 8 mode (from WMI 7), error is fuel pressure dropping. I only went 2-3gal of E85 on this last fill up, but either I got a bad batch of fuel or something is up.
This car needs fuel!
      10-27-2019, 10:53 AM   #25
SC_B5X
SC_B5X's Avatar
Ever since switching to meth i've switched to E29-E28 mixes because running a full E30 my HPFP crashes. Luckily the meth makes up for the lower octane.
HPFP is a must if you really want to max out the stock turbo on these cars (or meth works too)
Instagram: SC_B5X
      10-27-2019, 05:02 PM   #26
CntryClub007
Yeap, just dropped my E85 content to about 1-2gal for 13-14 of 93 with Meth. No idea what that equates too from an E rating, but the HPFP isn't crashing anymore. Trying to figure out my next bolt on to make this thing faster, but I'm afraid I'm all out of bolt ons to try at this point haha.
Might screw with XDelete for fun and go hit the dyno and real 1/4 mile again. Went 11.4 on dragy, but I want a real world track time.
      10-27-2019, 05:34 PM   #27
eksigned
eksigned's Avatar
130
Drives: 440i
I'm one of few thats running MP's updated fuel pump. There's some machining that goes into the process. The new fuel pump sits a bit higher than the previous one did, so it sticks out a small bit. I had issues running into, what I thought was timing being pulled, on MP's stage 2.5 flash on 91. Ran fine with 2 gallons of E. Come to find out this wavy throttle feel was just the car running out of fuel (moderate throttle). Plan is to go with Pure's updated turbo when it becomes available, and mayyybbee run some meth for cooling, and take it from there. I've been able to run 3-5 gallons of E safely and without issue for some time now with MP's new pump. The process went like this: I purchased the pump from BMW Riverside, dropped the car and new pump off at MP. He tuned/logged and modified/installed the pump for a flat fee.
      10-27-2019, 07:51 PM   #28
rahlow
Drives: 2016 340i
So with the boost increased a tad and able to go up to 5 gallons of E have u had it dynoed since or what does the butt dyno tell u in terms of hp increase from the mods?
      10-27-2019, 08:27 PM   #29
B58togo
Drives: M240i
Be patient guys. XDI has their B58 pump in beta testing right now, so it'll drop soon enough. It'll probably be $2300, but it is what it is. I'd love to make 475-480 wheel on the stock turbo with no meth, just E30-E40.
2017 M240i AW/ ZF8/ BM3 E40 Johnson tuned/ Dorch Stg.1 HPFP/ xHP Stage 3/ ER catless DP/ Remus axle back/ BMS intake/ M Performance LSD 11.6 @ 122 mph
      10-27-2019, 11:20 PM   #30
OzBMR
OzBMR's Avatar
Australia
544
Drives: BMW M140i
Looking at the logs from my drag runs WGDC is at 87% - 90% over 5000RPM to try to maintain 19PSI boost at the manifold. Charge air temp climbed from 155 F at the tree to 324 F at 19.3PSI/6200RPM in 5th gear (90% WGDC)
CPI/meth injection would help to control the charge air temps, but how much more useful boost do you think we can achieve from the stock turbo?
Assuming I'm at about 420 wheel HP, just adding XDI HPFP and full E85 I'm thinking maybe only another 20 - 30 HP max. Not great value for money. Add a bigger turbo and it'd be a different story.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
      10-28-2019, 12:00 AM   #31
rahlow
Drives: 2016 340i
$2300??? Sounds like a much better value going with Alex. I've spoke to him and his numbers aren't near that high.
kern4173380.00
      10-28-2019, 12:02 AM   #32
SC_B5X
SC_B5X's Avatar
Much rather figure out a way to retrofit Supra pump or wait for Spool's pump than use XDI bullshit. It might be a good pump but i'm not buying anything from a company that price gouges the way they do. $2300 for a pump is criminal.
So the meth actually made zero difference in IAT's for me. I have a feeling it's because we're injecting it pre-intercooler.
Instagram: SC_B5X
eksigned129.50
kern4173380.00
      10-28-2019, 11:28 AM   #33
Solid67
Drives: 2019 M240i xDrive MP Edition
Off-topic question, but what is Pure's updated turbo and when is it coming out?
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 OTS / xHP Stg 3 ZF8 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe (Ceramic Coating) / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 /
M405 7.5Jx19f + 8Jx19r / Pirelli P Zero runflats - 225/35 R19f + 245/30 R19r
      11-12-2019, 08:36 PM   #34
Solid67
Bumping this thread. I've been in touch with Tom Wrigley Performance and he said he swapped the B58TU pump into his m240i. All he had to do was extend the wiring. Didnt mention anything about tuning or flashing to compensate for the HPFP. His car is putting down 701rwhp on race gas and meth and about 600rwhp on 93 and meth. He's using a PS2 (I believe he has the hp record).
kern4173380.00
      11-13-2019, 07:34 AM   #35
Solid67
Here is the part number for the B58TU HPFP:
https://www.getbmwparts.com/oem-part...mp-13518631642
kern4173380.00
      11-13-2019, 08:13 AM   #36
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
They look incredibly similar. What's interesting is that the supply line is the same and the rear fuel rail is the same between Gen 1 and TU. The front fuel rail is different, but that's probably because it comes with a fuel pressure sensor. That sensor will need to have a higher threshold than ours to compensate for the pumps higher pressure range.
I'm just digging, so don't take this as the holy grail. But there are a lot of consistencies. The main concern is the hard line going to the fuel rail. Looks like ours has a bend, where the TU one is a straight 90.
B58 Gen 1 Pump
13517642466
B58 TU Pump
13518631642
Instagram/Youtube/TikTok: @kern417
      11-26-2019, 12:58 PM   #37
kern417
Cheapskate
I bought one from Germany. We'll see how this goes. Hopefully full E85 on stock turbo in my future.
Solid67163.00
      11-26-2019, 01:14 PM   #38
BMWILUVU
Drives: 340ix
I don't think the lines will be a big deal nor the fitting. Are you going to install it w/o remap? Will be interested in seeing your logs.
Sub'd.
      11-26-2019, 01:19 PM   #39
kern417
Cheapskate
Sub'd.
Yeah to start off. See what it does with OTS mapping.
Solid67163.00
      11-26-2019, 02:16 PM   #40
Solid67
Very interested to see your results given that I have moved on from the CPI kit. I'm just waiting until Spring and hoping to do the HPFP, meth kit and a turbo upgrade.
      11-26-2019, 02:56 PM   #41
J3Vr6
Drives: 2016 BMW 340i (RWD)
I'm extremely curious of your results. Please start a thread on the progress when it comes!
      11-26-2019, 03:12 PM   #42
kern417
Cheapskate
Will do. I was pretty much locked in to get the CPI kit, but then a deal came up on the pump that I couldn't refuse. So I guess we're starting this process earlier than expected
J3Vr63.00
      11-26-2019, 06:54 PM   #43
jackstrath
Scotland
537
Drives: 16' F31 340i & 03' Focus RS
I see the post on PureTurbos FB page saying they just fitted there PS2 Turbo and the new z4 HPFP (guessing the same as the supra) to a M140i and made 580bhp odd, pump bolted right up with only the wiring needing extended aparently !
Solid67163.00
      11-27-2019, 07:37 AM   #44
Chris@VargasTurboTech
Drives: All Things TurboCharged
We can confirm the Supra pumps are a direct bolt-on with only a wiring extension. We made the swap yesterday morning in about 20 minutes including the wiring extension. We will be offering the Supra pumps as an add on to our upcoming turbo. We will include wire with crimp/solder/seal connectors on both sides and some split loom. Simply snip, strip, and use a heat gun to make the connections.
kern4173380.00
Solid67163.00
340i, hpfp, hpfp upgrade, m340i, supra
