BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - Southeast > Rotor... availability?
      10-29-2025, 10:19 AM   #1
raktion
Drives: BMW e93, F33
Lurker turning to post - primarily due to personal ineptitude I fear. I fully accept that I may have simply looked over the current answer and if so I invite you to "flame away" as I take no offense. But please also point me at said answer if so.
I have a 2015 F33 (435i sport line) w grey brake calipers. Fronts look like the brembo, rears appear smaller (Pretty sure 340x30mm Front, 330x20mm Rear). I want to get drilled rotors - admittedly for the aesthetic - to see if I wanted to do a true M Brake system upgrade.
I have to change brakes anyway.
From research and reading the forums I found the Zimmerman rotors - drilled - for the grey standard caliper (well mine is sport line) brakes... but the part number is for the pair. I have only found this available online in a couple places, and they state they are single rotors. As these would be directional I am at a loss.
Thus, does anyone know of any currently available rotors - preference is cross drilled but at this point I would consider slotted / slotted and dimpled / slotted and drilled, etc.
This has become basically a back to the drawing board item but I am hoping someone here has current info they can offer.
      10-31-2025, 09:04 AM   #2
Oksamit78
Oksamit78's Avatar
499
Drives: E39, E90, F30 & F34
RockAuto has a plethora of rotors available for your car, including Zimmerman. You can review their availability in drilled/dimpled/slotted as a start if you have not done so yet:
https://www.rockauto.com/en/catalog/...hub,rotor,1896
2003 E39 530i 5-Speed w/ M Spec, Sapphire/Black, M54B30, Active Autowerke Perf Tune
2010 E90 328i XDrive, Space Gray/Saddle Brown, N52B30A
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
