| 07-06-2018, 05:19 PM | #1827 |
Rep 49,196
![]() 2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
FlorinQCK-2.50 |
| 07-11-2018, 07:42 AM | #1829 |
Rep 49,196
FlorinQCK-2.50 |
| 07-15-2018, 08:16 AM | #1833 |
Rep 49,196
PM sent.
FlorinQCK-2.50 |
| 07-17-2018, 08:30 PM | #1835 |
Rep 49,196
You either pull file from Car Head Unit or from BMW Server, but the latter requires dealer access.
FlorinQCK-2.50 |
| 07-18-2018, 03:15 PM | #1836 |
![]() 72
Rep 245
SWID_FscShort for CIC Premium 2018-2 Western Europe
Hi There Guys,
I though that I was being clever and used SWID_FscShort="0028002F" in lookup.xml to generate a FSC code for CIC Premium Western Europe 2018-2 and the generated code does not work! Could someone (ie Shawn) maybe please give me the correct short code to use? Many Thanks Andrew |
FlorinQCK-2.50 |
| 07-18-2018, 03:30 PM | #1838 | |
Rep 49,196
FlorinQCK-2.50 |
| 07-18-2018, 03:32 PM | #1840 |
Rep 49,196
See Post # 5.
FlorinQCK-2.50 |
| 07-18-2018, 04:30 PM | #1842 |
Rep 49,196
Pull DE File from NBT, feed DE File to FSC Gen using parameters 0xA9 0x32.
FlorinQCK-2.50 |
| 07-20-2018, 03:36 PM | #1843 |
![]() 36
Rep 99
appreciate your help so far. got my dads car to update his maps and he has ROAD MAP EUROPE PREMIUM 2010. I see that there are currently 2018-1 version, however split is West and East. Do I update it to both versions (West and East) or just one?
FlorinQCK-2.50 |
| 07-20-2018, 06:19 PM | #1844 |
Rep 49,196
You can only load one or the other. U.K. is West.
FlorinQCK-2.50 |
| 07-29-2018, 01:50 PM | #1845 |
Rep 12
Hi guys, I read in the previous page that the FSC code to update Route Map on HU_EntryNav must be bought from dealer because ASAP access is needed. Something changed or this is the only way to get an activation code for this map? Thank you.
FlorinQCK-2.50 |
| 07-29-2018, 02:04 PM | #1846 |
Rep 49,196
There is no public FSC Generator for ROUTE Map Update, so you cannot do it yourself. But you do not need to pay Dealer. PM sent.
FlorinQCK-2.50 |
| 07-30-2018, 07:01 PM | #1847 |
Rep 270
Drives: ///M6 GC
Just wanted to thank all those who posted instructions & what worked for them
Prerequisite: disable all firewalls, Antivirus & WiFi. Set Ethernet to DHCP (not static) 1. Connect ENET cable to OBD port 2. Connect ENET to laptop Ethernet port 3. Start vehicle (DO NOT step on the brakes, engine does not have to be on) 4. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig 5. Ensure you have 169.254.xxx.xxx IP address for Ethernet 6. Launch E-Sys Launcher (NOT E-Sys) 7. Select Connect ![]() 8. Select appropriate Target (based on I-Level) ![]() Note: Don’t use _DIRECT ![]() 9. Select Connection via VIN 10. Select Connect 11. Click Expert Mode 12. Select FSC Extended ![]() 13. Diagnostic Address (hex) = 0x63 14. Click Identify ![]() 15. Application Number (hex/dec) – 0xDE 16. Upgrade Index (hex/dec) – 0x1 ![]() 17. Scroll down & select StoreFSC 18. Select Add to the batch button (>>) ![]() 19. Select Read 20. Select Save 21. Use the following naming format when saving FSC file. XXXXXXX_000DE001.fsc Note: XXXXXXX is the last 7 of your VIN >>> Generating FSC code for map updates <<< 1. Copy NBT.EXE + XXXXXXX_000DE001.fsc to C:\EC-APPS folder 2. Open command prompt & go to C:\EC-APPS folder Type: NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt Ex: C:\EC-APPS> NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt ![]() This will create a file called code.txt with the map FSC code inside ![]() I used the FSC file as is, did not have to use BASE64 or decode the file. Out of laziness, decided to use a batch file that I used to generate FSC for my CIC Ex: batch file. Note: replace XXXXXXX w/ the last 7 of your VIN ECHO OFF CLS IF NOT EXIST NBT.exe ECHO File NBT.exe NOT FOUND! IF NOT EXIST XXXXXXX_000DE001.fsc ECHO XXXXXXX_000DE001.fsc does NOT EXIST! c:\EC-APPS\NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt IF %ERRORLEVEL% EQU 0 ECHO File code.txt was created successfully! PAUSE Place & run batch file in C:\EC-Apps where NBT.exe & your FSC file is located. NBT.exe I have is dated 7/1/2015 (77KB). Seems to be newer than what I found in the ZIP files posted by others. Uploaded all the files I use here if anyone wants it: https://drive.google.com/drive/folde...Nl?usp=sharing >>> Determine Region & Map sequence code <<< Note: requires HxD application: https://mh-nexus.de/en/hxd/ Region & Map sequence code - located in the 1st folder of the map files File path = 1\INFO_MAP_NANT_#####\Info_Map.imp North America NEXT: ![]() |
FlorinQCK-2.50 |
| Bookmarks |
| Thread Tools | |
