BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > BMW alignment question
      08-16-2018, 05:39 PM   #1
buckybadger
BMW forever!
buckybadger's Avatar
I just got new M performance suspension (shocks/springs) installed on my car a month back.
I drove the car for a week and then got the alignment done at a local BMW shop. The tech said that alignment is in spec and he also printed it out for me.
Now I have been driving the car for few days and I notice that steering is slightly more looser with less feedback post-alignment. Also, sometimes when I make sharp turns, the steering needs to be turned more. There seems to be a pull in the opposite direction of the steering. The car still drives straight but feel a little wobbly with looser steering. This was not the case before alignment. I took the car back to the shop and they checked my suspension and alignment. Everything was normal. Now the tech is saying the suspension may have settled down and softened in the last few days and that is what I'm feeling. I don't think that is the case though.
Can a bad alignment cause such issues even when they are within spec? Maybe the tech didn't do a good job? The BMW alignment specs, which I had done last year are different compared to the local tech ones. However both are considered to be within the spec range.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-17-2018, 03:16 PM   #2
buckybadger
BMW forever!
Anyone?
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-17-2018, 03:35 PM   #3
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
Post the printout ..
It's possible his machine isn't calibrated right. A little toe either way on either wheel can make a difference in feel. Maybe get a 2nd (3rd) opinion on a good rack.
You're also supposed to put weight in the car https://www.newtis.info/tisv2/a/en/f...ent/1VnXNvlEsc
"Vehicle with complete equipment for normal operation with: 2 x 68 kg on front seats (seats in centre position); 1 x 68 kg on rear seat (centre); 1 x 21 kg in luggage compartment (centre) and full fuel tank."
but nobody does that. I sat in the drivers seat last time but I would like to try that method.
      08-17-2018, 05:44 PM   #4
buckybadger
BMW forever!
Thank you, please see attached snapshot of before and after alignment.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-19-2018, 11:14 AM   #5
buckybadger
BMW forever!
Anyone?
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-19-2018, 04:01 PM   #6
cfm56d7b
This is a very unusual case. There is a likely case of more understeer since extra effort is needed while turning. The question is why.
Sometimes it's best to go back basics.
How is the tire pressure?
Any chance that the shocks are defective?
All suspension components torqued to specs?
Can the alignment be done again this time mirroring factory specs?
      08-19-2018, 06:42 PM   #7
buckybadger
BMW forever!
Yes shocks look good. Tire pressure also good.
Only thing I can think of is alignment. Can anyone tell if my alignment is setup in a way that can cause the loose feeling in the steering?
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-20-2018, 08:38 PM   #8
buckybadger
BMW forever!
Can anyone give feedback on my alignment specs?
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-21-2018, 01:31 AM   #9
DSH7
Drives: F30 328i
Your alignment numbers look good. They added a little front toe, but hardly any. If they added a ton it would contribute to the symptoms you describe, but not .22 total toe. Check out this thread for some great info on alignment specs.
      08-21-2018, 07:11 AM   #10
B58 parts
B58 parts's Avatar
The printout looks good. I'd call the guy and tell him you think it's a bit out up front and ask him if he's calibrated the machine .. ever. And/or fork over $100 to have it checked somewhere else and get a 3rd opinion.
      08-21-2018, 09:10 AM   #11
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
32psi front left, 35psi front right? Ive noticed that tire pressures being different on mine caused a weird feeling of twitchy steering before and that turning one way was easier than the other.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      08-21-2018, 10:35 AM   #12
buckybadger
BMW forever!
Thanks a lot!
I have mine at front 35 psi and rear 38 psi, just like the door jam says. I do have non-run flats. Should I use the same psi or different one?
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-21-2018, 11:42 AM   #13
B58 parts
B58 parts's Avatar
I didn't even notice the tire pressure L/R. LOL. well, yeah ...
"Observe the following test conditions prior to the chassis/wheel alignment check:
Only BMW approved wheel and tyre combinations may be installed on the vehicle
Correct tread depth. The tread depth for each axle may differ from left to right by max. 1‐2 mm.
Correct tyre pressure (see label on vehicle).
All chassis and suspension components must be technically OK.
Condition of suspension and shock absorbers OK: Visually inspect for breakage, etc.
Vehicles with self-levelling suspension: Pull fuse of air supply system so that there is no controlling down or up." [1]
"Car loaded down to normal position Vehicle with complete equipment for normal operation with: 2 x 68 kg on front seats (seats in centre position); 1 x 68 kg on rear seat (centre); 1 x 21 kg in luggage compartment (centre) and full fuel tank." [2]
[1] https://www.newtis.info/tisv2/a/en/f...rement/6IrCYFB
[2] https://www.newtis.info/tisv2/a/en/f...ent/1VnXNvlEsc
Further reading, https://www.newtis.info/tisv2/a/en/f...g-measurement/
      08-21-2018, 04:45 PM   #14
buckybadger
BMW forever!
Thanks, I believe all the components are intact. I still feel something to do with alignment or steering adjustment.
I'm going to get the alignment done at the dealership soon.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-28-2018, 04:01 PM   #15
buckybadger
BMW forever!
Just a quick update, I went back to the dealer and got my car aligned:
1. The previous alignment was more biased to move the car to go right. That's why I always felt the car is drifting or heavy on one side.
2. The car was within spec but it was not aggressive enough.
3. Now that my car feels more planted, less bumpy and tracks straight.
4. The steering definitely feels more precise with the on-center feel significantly improved.
The dealer just made minor changes to the alignment compared to before and the car rides much much better, feels more aggressive and rotates around corners more smoothly compared to before.
In general, the dealer was expensive but well worth it in my case. Going forward, I will only do alignments at BMW.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-28-2018, 06:17 PM   #16
strobe89
strobe89's Avatar
Drives: 2013 M3 + 2015 335i xDrive
Mind sharing the new alignment specs? I just installed ACS springs on my car and in need of an alignment. Would be nice to know what I should be targeting. Thanks!
      08-29-2018, 01:50 AM   #17
DSH7
Drives: F30 328i
Also interested. Thanks.
