11-06-2016, 07:04 AM | #1 |
Rep 72
Planning to do ASD retrofit with HK audio - questions
Hi Guys
As the thread title states, I am planning to do an ASD retrofit on my 2012/09 euro build 335i with HK audio. Information on this seems to be quite dispersed on the net and battling to find answers to my specific questions. So some background from ISTA: In cars with the Top-Hifi audio system (Harmon Kardon), sound is sent from the head unit to the HK amplifier via the MOST bus (fibre optic). The HK amp then converts the digital signal to analogue and sends the audio signals to the various speakers in the car. The MOST bus also tells the HK amp when to switch on or off, as it needs to be on only when the head unit is sending audio to the amp. In cars with ASD, the ASD module is connected to the KCAN2 bus which gives it speed signals, load readings, and other signals in order for it to be able to generate the correct car engine sound at the output. If the car does not have HK, then the speaker wires which come from the head unit are then passed through the ASD module, which then adds its engine sound signal to it, and then outputs it to the speakers, i.e. the ASD module sits in series with the head unit and speakers. Therefore, if you do a ASD retrofit on a car like this, you physically have to cut wires/wire it such that the signal from the head unit to the speakers is broken, sent through the ASD module, and then sent to the speakers. In a car with HK, the ASD module outputs engine sound signals similar to the above, however, these signals are input to the HK amp and the HK amp becomes responsible to perform the addition of the ASD engine sound signal and the audio signals. Since the speaker wires are only run from the HK amp to the speakers, there is no longer a need to cut these wires because the ASD module does not sit in series with the head unit, the HK amp and the speakers. Therefore, in theory, the retrofit of an ASD module to a car should be easier if it has HK audio. So far I have got the following wiring diagram and pinout from ISTA/D based on a newer car with ASD and HK audio. As you can see, there are 9 wires from the ASD module to the HK amp - four sets of speaker signals, plus one radio signal ON signal (to tell the HK amp to switch on in the case of the car being on but the actual audio system is off) These 9 wires go to connector A52*3B on the HK amp. The problem I am having, is that my connector and pinout on my HK amp does not have so many inputs (as per the drawings on ISTA), and I cannot seem to find a pinout for my particular connector. My one looks like the pictures below. Does anyone have a pinout for the connector - alternatively if they have done this retrofit if they can put me in the correct direction? |
08-18-2018, 07:20 AM | #2 |
Rep 30
Hello buddy, I have the same HK amp with the same MOST plug. Did you have any joy with this retrofit? I read somewhere else there is a different HK amp for ASD with I different MOST pinout for the ASD.
08-18-2018, 11:16 AM | #3 | |
Rep 72
Yes I did in fact get this to work, but it wasn’t entirely straightforward. It is correct that HK amps for ASD are different, and our HK amps don’t support ASD. So what I did was create my own wiring harness, which takes the output of the HK amp (to the speakers), and then inputs those into the inputs of the ASD module, and coded the ASD module to work in stereo mode (Ie as if there was no HK amp in the car) |
08-19-2018, 07:38 PM | #4 | |
Rep 314
You are sending speaker-level outputs to the the ASD module when it is expecting line-level outputs/inputs - be ready for your ASD module and/or HK amp to burn at any moment. The ASD acts as an amp in cars with the base stereo system which is what you have coded it to do. So you are essentially amplifying an already amplified signal. Your audio will probably sound like shit and clip like hell at medium to high volumes. You've also messed with the entire sound stage by having four channels driven by the ASD module and the rest by the HK amp with no tuning capability at all. Only proper way to do this retrofit is to replace your HK amp with an ASD version one. |
08-20-2018, 07:42 AM | #6 | |
Rep 72
With regards to four channels driven by ASD, and the remainder not driven by ASD, sure, that is true but not relevant. You don't need ASD coming out from more than four speakers. Once again, in a stereo installation this is the way it is in fact set up. With regards to tuning capability, the HK amp still runs all speakers, so it can be adjusted as it could always be - no change there. |
08-20-2018, 01:33 PM | #7 | |
Rep 30
08-20-2018, 07:00 PM | #8 |
Rep 30
So trying to get my head around your configuration. So you take the feed from HK amp to speakers and tap into the ones you want....eg FR FL RR AND RL. That then goes into the ASD module input. The output of ASD then inputs back into the same speaker output thus ADDING the ASD sound? Or am I way off. I’m struggling to get my head around how the ASD gets the “sound” into the speakers.
08-21-2018, 03:34 AM | #9 | |
Rep 72
I'll post some pics in the next post of the harness - I don't recall if I took installed photos. If you want to save yourself the time you can buy my full kit and just plug it into your car - I had my fun with it already :-) DM me if you are interested |
08-23-2018, 01:16 AM | #11 | |
Rep 314
08-23-2018, 02:36 AM | #12 | |
Rep 72
Been running my ASD system for well over a year now though without issue, so I assume that the ASD module can in fact accept the amplified input. Also, I rarely play sound loudly, so I am far from the maximum output of the HK amp |
08-01-2021, 11:30 AM | #13 | |
Rep 29
Did you try just to connect ASD outputs directly to HK outputs to have mixed sounds in stereo mode? Also did you run RAD_ON from the HU? and maybe you have complete harness for sale Thanks. |
08-01-2021, 02:42 PM | #14 |
Rep 2,180
In the HK(688) OEM amp with ASD the engine sound is mixed with the music in the OEM amp - the ASD only works as an engine sound generator.
Retrofitting the ASD to a non-ASD HK(688) OEM amp requires the engine sound mixing with music after the OEM amp, which requires the ASD to mix the OEM amp audio output with the engine sound instead of only generating engine sound, and expecting that the ASD can withstand 14-35V inputs instead of 10V max. The ASD is not designed to accept the output of the HK(688). Good luck with this retrofit. |
08-02-2021, 05:55 AM | #15 | |
Rep 29
08-07-2021, 11:00 AM | #16 |
Rep 29
Some progress with ASD. So I've connected ASD to CAN from COMBOX, coded it with VO and FDL with F80/S55 engine sound and then directly jammed outputs from ASD to outputs from HK! Everything works fine, there's engine sound from speakers, but when big connector is not attached to HK. When I put connector back, even without power supply attached to HK, ASD sound dissapears! Putting HK in work with power and MOST gives radio sound without any issues.
So there's some strange things happening when ASD outputs are in parallel with HK outputs, either in ON or OFF state, even without power attached. Polarity of ASD and HK outputs are correct, taken from TIS. ASD coded as STEREO and SL or TL power level. Need some advice... Thanks. PS: Checked with multimeter, HK outputs are "minus" and mosfet (maybe). ASD outputs shows around +6V on both "-" and "+" outputs. So seems when connected to HK, it just conflicts with HK "-". PPS: Finally made same thing as topic owner. Put HK outputs to ASD inputs (only for two front speakers) and it sounds amazing. Last edited by MemphisM5; 08-10-2021 at 03:36 AM.. |
08-21-2021, 06:30 AM | #18 |
Rep 29
Just made some diagrams and photos of my installation. It's here : https://f30.bimmerpost.com/forums/sh...php?p=27945320
