BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      Yesterday, 05:38 PM   #5479
stylobic
Drives: Mini Cooper s R56 2011
Originally Posted by muniz_ri View Post
You may want to check out this Audi site:
https://www.audizine.com/forum/showt...-3G-MIB/page15
yeah i had a look of that one, but I don't see the point to buy this brand $100 more than Andream for the same product.
I still don't understand if all of those hardware are from the same factory and from a generic firmware, each reseller is doing some little customization just to justify sticking their own brand on it.
      Yesterday, 08:11 PM   #5480
SuperLomi
Drives: 2013 336i M-Sport
Any tips on how to remove the climate control connector? Pressing what I think is the release tab only lets it partially disengage. It feels like itís hung up on one side.
      Today, 01:27 AM   #5481
Masum2004
Drives: 2013 F20 116i
Originally Posted by lawnmower351 View Post
Originally Posted by Masum2004 View Post
Thanks for your response. Sounds great as you have the PDC. I don't have the front PDC means I will have to manually activate it. Hence looking for a one button / quick shortcut option.
I have the andream unit and custom software. If I press the option button for 3 seconds, it activates the front camera. Works great. My front camera is located above the lower grill and the parking lines makes it easier to gauge the distance to the curb.
That's great to know I need to find out if a custom software is available for RoadTop one aswell.
      Today, 01:34 AM   #5482
BzsBimmer
BzsBimmer's Avatar
Drives: 2015 F80 M3 & 2019 X7
What custom software are you running? My custom software doesnít have that
      Today, 01:35 AM   #5483
Masum2004
May I know which versions you have. Need to see if they are cross compatible. I got the below versions?
      Today, 05:42 AM   #5484
stylobic
where you guys have support from Andream ? They don't reply on Facebook msgr
      Today, 07:49 AM   #5485
zeus_1903
Turkey
Drives: 2014 3.20d f30
friends, now I am using carlinkit v9.2.9 version MCU 20.6.2.0, how can I install it in what order if I want to use custom firmware?
      Today, 09:12 AM   #5486
shonuff1
Drives: BMW M4
I just installed a Carlinkit unit. Does anyone know if it's possible to have the system autostart in iDrive and not Carplay/MMI? I use satellite radio most of the time and just use Carplay for Google Maps/Waze.
2016 F82 M4
      Today, 09:15 AM   #5487
Xerxist
Drives: BMW F21
Did this yesterday.
Just download "v2.0.B0.mod" from the first page extract the file on a formatted FAT32 USB drive.
Attach the USB drive to the unit.
Turn off the car and wait for the unit to shutdown.
For me it took like 5min.
Press and "Hold" the Back and button on the iDrive start the car and release the Back button once you hear a click from the unit. (probably 5sec)
The flash process should start.
      Today, 09:30 AM   #5488
phyco1991
phyco1991's Avatar
Drives: F20 125i mSport
Originally Posted by Lolo_14 View Post
Can you provide the coding detail or point to a page that provide the setting to do (I have BimmerCode) ?
Thanks in advance
Should be under the Head Unit section and called something along the lines of CE_DEVICE_SPEECH_RECOGNITION but you will need to enabled Expert Mode to see/change it.
      Today, 11:04 AM   #5489
biomed27
Drives: f30
Anybody notice really low call volumes? I find myself having to increase the volume a lot during phone calls and once the phone call is over the music is extremely loud. I have the A version of andream if that helps any.
      Today, 11:58 AM   #5490
Lolo_14
France
Drives: BMW F31
Ok thanks !
I checked and seems indeed in
HU_NBT > 3003 TELEFON_TELEMATIK_ONLINE > CE_DEVICE_SPEECH_RECOGNITION
Seems I will have to set it to nicht_aktiv I guess
I will have a try this week end / Thanks !
      Today, 01:04 PM   #5491
zeus_1903
Turkey
Did this yesterday.
Thanks for answer, So do I need to replace the MCU afterwards? If I need to change it, should I do it the same way? then can I revert to the carlinkit version if I want?
      Today, 01:38 PM   #5492
Xerxist
Drives: BMW F21
The MCU is included in the custom one.
I haven't reverted because this is much better.
From the custom you can flash without pin it seems, but i would use the same method as how I flashed the custom to revert back to stock.
But people here might have a better way.
      Today, 01:57 PM   #5493
MihaiP
Drives: bmw f48
I just finished installing andream. Everything went pretty fast.
I didn't get to explore much because it was late.
Came with the following software versions and mcu(b_v.1.1.2 and mcu20.8.19.23). There is something new for update or these versions are up to date?
      Today, 02:25 PM   #5494
Fishie
Drives: 2013 BMW 32ix
2016 F82 M4
I had this issue as well. Go into the mmi settings, lower the aux volume setting. This will make you increase the volume to listen to music, and when the audio switches over to idrive Bluetooth for calls, it should be at the same level.
      Today, 04:45 PM   #5495
tuzogt
Austria
Drives: F31 318d B47 @125kW/420NM
That seems to be a new MCU.
      Today, 04:57 PM   #5496
MihaiP
Drives: bmw f48
Yes, it's new. I checked page 1 and seems that I have the newest mcu version
      Today, 05:03 PM   #5497
tuzogt
Austria
Are you an iOS or an Android user? AA autostart would be nice.
      Today, 05:15 PM   #5498
Masum2004
I got the same MCU on a RoadTop unit, bought last month.
[COLOR="Blue"]
I will really appreciate if someone could kindly help me to identify the Custom Firmware I can install. I have BMW F20 December 2013 (NBT). [/COLOR]
I want to get the option to turn on Front camera by pressing a button (e.g. - option button) as the below post by @lawnmower351. Also hoping that the custom firmware will fix the random issue with the auto start.
Thank you so much.
      Today, 05:16 PM   #5499
MihaiP
Drives: bmw f48
Android. I haven't been able to check to much after installation.
I had some problems with the transmission selector (broken spring) and it took me a lot of time!
Tomorrow I hope to check/discover more about andream mmi ! I honestly don't really know what and how to do but I hope to find out tomorrow( how to connect , what settings to do , etc).I just installed autolink and android auto on my phone !
If you have some tips maybe you will send me a pm.
      Today, 05:27 PM   #5500
BzsBimmer
BzsBimmer's Avatar
Well Iíll be... tried again just now and it works, pressing the option button for 3 seconds!!
Many thanks 🙏
andream, android, android auto, apple, carplay, mmi, retrofit
