04-29-2017, 06:29 AM | #89 |
Rep 775
N55 engine in 435i. Sorry, i should have been specific
Edited my above post accordingly. The stock DV is a known weakness in the N55 with lots of boost (22psi in Dinan Stage 4) and so the stock DV doesnt hold pressure well between boost events. Go Fast Bits DV+ is a bolt on solution. Hope this helps.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. Last edited by enjoythemusic; 04-29-2017 at 07:23 AM.. |
BASELINE136.00 |
05-02-2017, 07:57 AM | #90 |
Rep 173
Anybody with a 6MT have any feedback to share on the MPPSK Elite? I may pull the trigger on this later this summer but I'm hoping that the power delivery is still smooth enough for daily driving.
05-04-2017, 02:00 AM | #91 |
Rep 149
Drives: 2016 340ix Msport mppsk
If we have a mppsk and add the tune would we not have an issue due to the unique nature of how the DME is setup with a hard cap on fueling around 380-400whp.?
05-05-2017, 11:21 AM | #92 |
Rep 127
05-12-2017, 11:26 AM | #93 | |
Rep 149
05-12-2017, 12:03 PM | #94 |
Rep 1,170
It should not but it does take some additional power to drive the front axles, if I had to guess I would say if a RWD has 13% power loss for the drive train xDrive might go up to 14%. This is purely speculation on my part, I'll be happy to consider any other points of view or preferrably some cold hard facts.
edit: In fact xDrive doesn't lower HP but may lower the amount of HP you can put to the ground, HP to crank is not affected by the drive train.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
05-12-2017, 02:33 PM | #95 |
Rep 484
Drives: 440 xi MPPSK JB4
Location: Socialist People's State of NY - Long Island, NY
05-12-2017, 03:20 PM | #96 |
Rep 1,170
Can you be more specific in regards to "ceiling"? Is Terry referring to the fuel cap? A link to his comment? Not trying to put you on the spot, just curious.
05-12-2017, 03:59 PM | #97 |
Rep 484
Beek707.00 |
05-12-2017, 05:39 PM | #98 |
Rep 703
So it's been discovered that MPPSK does raise the fuel limit? Previously it was said that it doesn't but I have not been able to test it either way. If it does then that's great news even if it's a small amount.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
05-13-2017, 02:17 PM | #99 | |
Rep 1,170
"With the JB4 Bullitt as also added in the fuel pressure control connector which lets us extend his fuel trims slightly. Since we have more room to work with on fueling with the PPK it's a good use of it." edit: Bullitt = Billet, more I think about it more I think not so mainly I'm just
'09 Outback for a beater and grocery getter. Last edited by Beek; 05-13-2017 at 04:38 PM.. |
05-16-2017, 03:30 PM | #100 | |
Rep 484
Here is some more detail on this:
http://www.n54tech.com/forums/showpo...72&postcount=2 Read the FAQ "Can I run E85 with this platform?" - Looks like they updated the FAQ with some detail about it. Quote:
Beek707.00 |
05-26-2017, 10:39 PM | #101 |
Rep 1,011
ordered the elite tuner for my 340xi w/ MPPSK. should have next week with holiday delay. will install and post up impressions and feedback.
05-27-2017, 07:19 AM | #102 |
Rep 484
Curious does this have Bluetooth? If so what does the app do?
Also, does this need to be installed by he dealer or can I self install? |
05-27-2017, 03:28 PM | #103 |
Rep 418
Will you have dyno? It would've been better for me if you had a rwd lol
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
monkiboy534.50 |
05-27-2017, 09:40 PM | #104 | |
Rep 1,011
"Dinan's ECU is Bluetooth® Smart meaning that you can change maps simply via a Bluetooth connection on your iPhone or Android device." |
05-27-2017, 09:42 PM | #105 |
Rep 1,011
i'll do a dyno after install after a few days more than likely. i thought of doing one prior to install so car has a settled factory MPPSK tune not a just-swapped map or dinan on base MPPSK map that hasn't settled but not sold on paying twice for dyno time and making the drive twice. it would be nice to see the deltas and provide the data. not sure.
05-28-2017, 11:31 PM | #106 | |
Rep 3,127
Dealer can install or it can be self installed. The only downside of a self install is the labor is not guaranteed so if it is improperly installed and an issue is caused due to it not being installed correctly then the warranty would not apply. As an example the battery is not unplugged for install and you short/brick the DME as a result. The warranty would not cover that. |
05-29-2017, 08:04 AM | #107 | |
Rep 484
Thanks... can the app upgrade the firmware in the unit also?
05-29-2017, 10:46 AM | #108 |
Rep 231
05-30-2017, 10:35 AM | #109 | |
Rep 3,127
Not sure what you mean. The SPORT unit cannot be upgraded to ELITE. Different systems. If you mean can the non-MPPSK stage 1 tune be switched over a MPPSK stage 1 tune the answer is no as well. It comes down to how the licensing is issued on our end in why that isnt possible. Always exceptions to the rule but thats the company line at least. Regardless, most folks will do 1 or the other and not do both considering the relatively minimal gains in doing so while doubling up the price. Early adopters of MPPSK are the most affected. |
05-31-2017, 10:33 AM | #110 | ||
Rep 231
The reason I asked this question was because some already have the Stage 1 installed and were thinking of getting the MPPSK installed. It sounds like they will need a completely new Stage 1 (MPPSK). Quote:
