06-12-2018, 08:37 PM | #1 |
Rep 130
Engine Modifications on B48 Engine
Mind to share out what have you done to your B48 engine? Below is the list of mods I've done to mine.
1. JB4 Piggyback 2. Burger Billet Intake 3. FTP Charge Pipe |
06-13-2018, 07:29 AM | #2 |
Rep 432
06-13-2018, 08:57 AM | #3 |
Colonol Forbin
208
Rep 338
Mandang Umaga!
I plugged in a JB+ and switch between the AFE drop in filter and the BMS billet intake. There just isn't much available for the B48. Hopefully that changes soon! I wound up applying CQuartz to help keep the black car clean. |
06-27-2018, 09:15 AM | #5 |
Rep 38
Did you notice a difference between the JB4 with stock air filter and when you added the intake? Did you happen to dyno with and without the intake? I keep reading folks saying intake does nothing for performance, but BMS boasts up to 8whp by adding it. TIA
06-27-2018, 09:52 AM | #6 |
Rep 4
Just picked up my 18' B48 330i. Was a little disappointed to see the lack of options we have in terms of mods, but I did place an order for a decatted downpipe from Armytrix so we'll see how that goes. Once installed I'll upload a clip.
06-28-2018, 10:38 PM | #7 |
Rep 130
usually performance is not much just that u get more sound only.. haha
06-28-2018, 10:39 PM | #8 |
Rep 130
at the moment even doesnt have a remap for it yet.. only piggyback... as for intercooler i dont think we will have it as b48 is water cooled
10-21-2018, 11:50 PM | #10 |
Rep 95
Hey here what I got now
Power: JB4, +BT, +EWG, JB4 progressive meth control system with CM3 + CM7 Stage 2 Flash by TMC 22psi (~22psi 3-5k, ~20psi at 6500RPM) FTP Charge Pipe ARMA Carbon Intake Unrestricted DP Others: KW V3 Coil Over 18' forged wheels, (28kg vs stock 44kg) Lithium Battery (8kg v stock 23kg) AP 9440 4 pot, on fronts only with 330 floating disc (21kg vs 29kg stock) Carbon Strut bar Still Considering: Cat-back , 55mm stock pipe may be restriction so looking for options here Hood, stock is 17.5kg, wet carbon hood are like 12-13kg so basically for looks not weight M2 Control Arms, for a bit more negative camber LSD, hard to find for reasonable price as our diff gears are welded on |
Boundless4626.00 |
10-03-2020, 04:51 PM | #11 |
Rep 20
Engine Mods
I've fitted;
Wagner Tuning chargecooler for the B48/B58 FTP chargepipes V2 MST Performance cold air intake Supersprint decat, and Supersprint 3" OPF delete front-pipe, Supersprint mid-pipe with resonator, into a M140i M-Performance backbox. Custom map from Drivr Tuning (Denmark) running ~17psi(safety and reliability) Gearbox software updated to Sport (software from 140i,240i etc) so i have paddle shifts and launch control Only running V-Power 99 Currently running 300hp and 442nm on dyno. Last edited by p47r1ck; 10-06-2020 at 01:36 PM.. |
Boundless4626.00 |
10-04-2020, 07:07 AM | #12 |
Rep 280
Those figures are "engine" power extrapolated from the dyno right ? What were the figures to the wheels ?
Engine power from dyno is very ... bullshitty, the dyno operator inputs an adjustment factor to get from wheel figures to engine figures, this is just a made up adjustment pulled out of thin air. |
10-04-2020, 02:18 PM | #13 |
Rep 2,805
Drives: F33 430 and F39 M35i
Stock b46 with bm3 stage 1 93 on a mustang dyno shows me at 233whp. Never bothered to calculate “engine” hp.
Boundless4626.00 |
10-04-2020, 03:34 PM | #14 | |
Rep 4,327
regarding OP post i'd add a FTP intake pipe, Active Autowerke catted downpipe and flash tune. if stock intake...https://www.ftpmotorsport.com.tw/pro...ipe-inlet-pipe if aftermarket intake...https://www.ftpmotorsport.com.tw/pro...ll-intake-pipe https://store.activeautowerke.com/co...atted-downpipe Last edited by alohasurftoad; 10-04-2020 at 03:52 PM.. |
chowser512025.00 |
10-04-2020, 07:37 PM | #15 |
Rep 47
I've had my car dyno'd two different times with different mods on the same dyno. Both times ambient temperatures were around 94°. When I dyno'd on BM3, the dyno wasn't working well so I'm sure I make more out of it.
2017 330i B46 Mods: JB+ 245whp/291tq Mods: BM3 Stage 1 E30 xHP Stage 3 253whp/314tq |
10-04-2020, 08:02 PM | #16 | |
Rep 2,805
Stock run was 210whp. Flashed stage 1 and both showed 233whp. So 23hp gain. I was happy with it. I thought about stage 2 but I really don't want to install a catted dp (emissions checks in my area still). |
alohasurftoad3078.00 |
10-06-2020, 11:27 AM | #17 |
Rep 384
i got b48 330i, and the mods so far:
Performance: BM3 Stage 2 FTP Charge Pipe FTP Intake Pipe Armytrix catless downpipe Straight pipe valvetronic cat-back exhaust BMS Open billet (now back to stock, due to some issue with open filter)
Instagram: nightfall.f30
10-06-2020, 01:27 PM | #18 | |
Rep 20
Nice mods, any idea of what power you have? Interested in hearing what issues you had with your BMS billet intake. I just removed my MST "cold-air" open intake today, and honestly believes the car runs better.. Had a weird feeling about the intake. Replaced it with the OEM filter-case and a KN drop-in filter. |
10-06-2020, 01:32 PM | #19 | |
Rep 20
I ran a dyno back then and it had 265hp and 442nm, so imo it was "pretty" close.. And now, with all my mods, same place, same guy, same enviroment, had 300hp.. Buuuuut yea its hard to get an exact idea of how much. Theres a company close to me that has a Dynojet dyno - but i'm lacking feedback and information about whether its more precise or just another roll by the dices..... |
10-06-2020, 02:26 PM | #20 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
2018 F32 430i xDrive, ZF8HP50
-B48 Bm3 stage 2 e30 -Evo Racewerks downpipe catless, ceramic black -Evo Racewerks chargepipe kit, gloss black -Injen SP1123 open air intake, ceramic black -AWE full catback straight pipe exhaust system (performance midpipe with resonator + touring axleback, gloss black tips) -xHP Stage 3, custom flash settings Need tires... thinking ps4s on 225/45/19 front 245/45/19 rear need suggestions here. Want to run gloss black grilles, black rims and chrome delete on glacier silver. Pics, Videos, dragy tests coming...should be ~300whp, ~475 nm / ~350 ft lbs wtq. Last edited by Avaley; 10-07-2020 at 02:11 PM.. |
VipinLJ1941.50 |
10-06-2020, 06:36 PM | #21 |
Rep 636
10-07-2020, 01:51 PM | #22 |
Rep 176
BMW 330e B48 Hybrid
Modifications: 1. BM3 Stage 2 Tune (custom tune in progress) 2. Snow Performance Stage 2.5 kit (#5 nozzle with 100% meth) 3. ER catless downpipe 4. FTP charge pipe 5. FTP intake pipe 6. BMS intake (cone filter) 7. Custom 3” exhaust – Borla 40943 XR-1 Sportsman Racing Muffler, Vibrant 1142 3” Ultra Quiet Resonator, Pipewerks custom dual 3” tips on one side of car. Car was making 350whp, 440wft-lbs on stage 2 91 oct BM3 OTS map (without custom exhaust). Car currently does low 13s. Unfortunately no xHP for my car as yet. |
Avaley731.00 |
