12-23-2019, 05:24 PM | #1 |
Boost Addict
334
Rep 349
HK Amp Replacement...can I use a different P/N? *UPDATE: Resolved*
Hey guys I have a HK amp that got water damaged.
Can I use another HK amp with different P/N from the same chassis? (how about 4er? 2/5/6er?) Does this require coding if different? If so, how or where do I get this coding done? I just want sound back in my car *UPDATE* I found a company in TX called Logic7amp. They tried to fix my amp but it was too corroded. They replaced it with another amp and coded it for my VIN for $650. Works perfectly now. Hit them up if you guys need HK amp work. Apparently they get a lot of F-series HK amps w/ water damage.
S55 M2C | Three Pedal Club | E30TU
12-23-2019, 09:31 PM | #2 | |
Rep 10,473
Do you have the damaged part number? |
12-23-2019, 10:54 PM | #3 | ||
Boost Addict
334
Rep 349
From RealOEM... Quote:
Thanks, -San
12-23-2019, 11:10 PM | #4 | |||
Rep 10,473
1. in a way that involves or affects both sides. 2. in a way that involves two parties, especially countries. So this means an older part can be used instead of a equal or newer part. ret·ro·spec·tive·ly with consideration of past events or situations. "medical records were retrospectively reviewed on 120 patients" with effect from a date in the past. "the rebates apply retrospectively from 1 April" retrospectively refers to past (or retrospect), so that means the newer part can replace the older part, but not necessarily the other way around. At least that's how I understand it. As thus: Last edited by IK6SPEED; 12-23-2019 at 11:22 PM.. |
Tchao333.50 |
12-23-2019, 11:43 PM | #5 | |
Boost Addict
334
Rep 349
To confuse things further...if you look at the newer amps on the list, 2014 for example, some 2012 production are retro, while other 2012 productions are bilateral. Normally I wouldn't mind to wing it, but amps are running $600-1000 USD used
12-23-2019, 11:46 PM | #6 | ||
Rep 10,473
Tchao333.50 |
01-13-2020, 11:12 AM | #7 |
Boost Addict
334
Rep 349
*UPDATE*
I found a company in TX called Logic7amp. They tried to fix my amp but it was too corroded. They replaced it with another amp and coded it for my VIN for $650. Works perfectly now. Hit them up if you guys need HK amp work. Apparently they get a lot of F-series HK amps w/ water damage. Great customer service, helped me trouble shoot when I installed the amp, I had a 5A fuse break during my water ingress, and that killed power to my fiber optic emitter, so I still had MOST-Ring errors, the guy knew exactly what to look for over the phone, I ran to Autozone real quick to get a small frame fuse, car stereo works amazing again.
09-10-2020, 10:55 AM | #8 | |
BMW Veteran
310
Rep 503
my HK amp died so i'm looking for a repair or a replacement. Did the other AMP you installed have a matching part # to the old one? |
09-10-2020, 11:00 AM | #9 |
Rep 16,082
Logic 7 is the name of the BMW amp/system, which is subject to copyright, so I doubt any company can use it as their business name.
09-10-2020, 11:01 AM | #10 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
It appears they changed domains. New website is: bavlogic.com
09-10-2020, 04:44 PM | #11 | |
Luxury at the redline :)
9105
Rep 7,563
Forward the video below to 7:35: |
09-10-2020, 09:40 PM | #12 | |
Boost Addict
334
Rep 349
Heres the website. No, the replacement amp did not match the P/N. They can use to the same case and just replace the board, but I did not care. The first replacement Amp for some reason lost the coding after a week of use. So they sent me another amp, this one with the same case P/N (it was actually my old case) and everything is working fine since. They updated the software on the amp too supposedly, obviously I cannot verify that. Hope this helps.
Poochie9104.50 |
10-27-2020, 04:44 PM | #13 | |
BMW Veteran
310
Rep 503
To close the loop on this, a matching part # top HiFi/HK amp (and ASD module -- in my case the ASD module came with the replacement amp since they share a mounting bracket and the dismantler didn't bother removing it) will plug right in and work without any programming. The only clue that the amp was replaced is when you scan the car with INPA D, a fault is present indicating the amp does not match the VIN of the vehicle. I found a guy that can VIN code the amp but haven't gotten around to it. It does work perfectly though. During the process, i also spoke to Becker audio and they also offer a repair service, although they quoted me around $900 for the repair if any of the circuit boards were to require replacement. A new unit runs about $1300, even after a sizeable discount. |
05-26-2023, 05:54 AM | #15 |
Rep 593
Drives: 2018 F48 X1 xDrive 18D
How to VIN code the AMP?
