10-20-2020, 02:35 PM | #23 | |
Rep 1,288
Lot of whiches but hey it's Halloween.... lol... |
Pussiwillow521.00 |
10-20-2020, 02:54 PM | #24 | |
Rep 7,606
harkes1078.00 |
10-20-2020, 02:58 PM | #25 | |
Rep 1,288
10-20-2020, 03:48 PM | #26 | |
Rep 3,695
I wouldn’t stress if you don’t see the logs you seek beforehand. Stg 2 E20 MHD and Stg 2 E30 BM3 are fairly similar in power since the stock HPFP is the bottleneck. But, Stg 2+ E30 BM3 blows them both away, and I’d guess you’d pick up ~25whp if you have all the supporting mods to go with your stock turbo. |
10-21-2020, 03:57 AM | #27 |
Rep 2,357
Finally found out how to include AFR and manifold boost in VD Here my latest performance check with "nice and cold" 28°C ambient
Can is running awesome! 100-200kmh in 7.5sec
(A Dane in China) |
10-21-2020, 11:50 AM | #28 | |
Rep 1,288
10-21-2020, 12:04 PM | #29 | |
Rep 3,695
440whp is what a PureBoost tuned PS2 M2 on 93 put down on the Dynojet here on a 90F day. That’s the car I’m mentioning when I’m saying my car did 15whp less with a beta of the BM3 Stg 2+ E30 and E47 with my smaller Dinan turbo and spark plug gap issues. I’m guessing I’ll be 430+ whp with the OTS, fixed plugs, and a cold day. Will find out soon. |
10-21-2020, 12:38 PM | #30 | |
Rep 1,288
ZM22810.50 |
10-21-2020, 01:05 PM | #31 | |
Rep 3,695
So, you can do it for $2k’ish, but if you decide to spend another $2-$2.5k for a larger turbo, that’s where the big power comes in. Think of it as a required stepping stone for now. |
10-21-2020, 01:23 PM | #32 | |
Rep 1,288
10-21-2020, 07:47 PM | #34 | |
Rep 1,288
Pussiwillow521.00 |
10-21-2020, 08:03 PM | #35 | |
Rep 2,357
(A Dane in China) Last edited by harkes; 10-21-2020 at 08:08 PM.. |
FastF30521.00 |
10-21-2020, 08:19 PM | #36 | ||
Rep 1,148
I'm curious to see what numbers on a stock turbo the cam swap would do I may be a pioneer and do it but it'll be a bit, haven't opened this engine up yet so I would need to plan a solid weekend to do it and get tools together for it. Got me thinking tho |
10-21-2020, 08:24 PM | #37 | |
Rep 7,606
10-21-2020, 08:29 PM | #38 | ||
Rep 1,148
But I'm not sure I've seen that much whp with that much wtq together on one car, but I also haven't dug around as I'm not at that stage with this car yet, very curious tho |
10-21-2020, 08:33 PM | #39 | |
Rep 1,288
P.s. read that gotta becareful about valve overlap ... mentioned MAYBE not good for highboost PS2 applications.. In the end for me... too much headache at this point... Last edited by FastF30; 10-21-2020 at 08:45 PM.. |
10-21-2020, 08:52 PM | #40 | ||
Rep 1,148
It held it really nice in the top end, this video was a bit hard tho because I feel like his tune was a literally a base tune then does a cam swap and custom tunes it, he only made 12whp or so and lost 5wtq over just a cam on same tune Custom to custom would be more fair but I can see the curve and can't deny it looks good |
10-21-2020, 09:32 PM | #41 | |
Rep 1,288
can't post the article... only increase peak 5hp but carried 35hp more upper rpm stk turbo 93 tune only dp s55 ... Last edited by FastF30; 10-21-2020 at 09:46 PM.. |
Pussiwillow521.00 |
10-21-2020, 10:33 PM | #42 | ||
Rep 1,148
Never seen that before |
10-22-2020, 12:53 PM | #43 | ||
Rep 7,606
The original posts i am quoting here are actually from a different thread but i am posting here as i feel its more relevant to the discussion in this thread: https://f30.bimmerpost.com/forums/sh...1766027&page=3
Note, your dyno run was in 5th gear and my log was in 4th, so i pulled values from corresponding RPMs rather than speeds. Here's my log: https://datazap.me/u/thejeremyman9/3...27-28-29-30-31 I think the interesting thing is that the MHD map runs a bit more timing at peak TQ RPM, but less timing up top (probably because its an E20 map and its not as aggressive as a custom tune would be). Also interesting is that my boost is basically the same (slightly higher) at peak HP RPM, likely due to stock HPFP limitations. Aside from that, the values are quite similar. My guess I would be making about the same torque (trade 1 psi for 2 deg of timing) +/- a few, but you would be making a bit more peak HP (2.3 deg more timing), which makes sense. This of course is only peak #'s and says nothing about area under the curve but interesting nonetheless since your log has corresponding dyno results. FastF30 probably likes this comparison since he's all about these estimations recently lol. |
FastF30521.00 EstorilMSport83.50 |
10-22-2020, 04:05 PM | #44 |
Rep 1,288
It's basically the same thing as bigger ratio roller-rocker arms... I always wonder if there was something can be done OHV... so I emailed them to see about a upgraded HPFP is required and what typical gains to be made on the N55.. Yes.. I'm very interested in this.. $1500 +/- including labor and tune...25whp up top???? yea it's worth it... I was told many years ago when you start hitting 11 second quarter mile times... the cost of Hp is roughly $1,000 per 10whp (that's everything included)... seems it still holds today... so this would be a good deal...
