BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > iDrive 4 flash to iDrive 6
proTUNING Freaks
      10-06-2020, 10:43 AM   #1
zox1i
Drives: 116i
Hi,
Can someone post or direct me to guide on how to do this flash. I know that iDrive 4 hardware has 2 GB RAM vs iDrive 5 with 4 GB, but still I would like to flash it. I cannot find any guide on how to do it.
      10-06-2020, 10:02 PM   #2
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Not possible.
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      10-07-2020, 07:43 AM   #3
atzebmw
Drives: Tesla Model 3
Possible
      10-07-2020, 08:41 PM   #4
zox1i
Drives: 116i
Originally Posted by atzebmw View Post
Possible
Yes, I know its possible but I can't find guide anywhere. Can someone please post a guide?
      10-12-2020, 08:39 AM   #5
320dgrey
Netherlands
Drives: BMW 320d
what are the cons on this?
-will iDrive become very slow because it has 2GB RAM?
-how long does the update take?
-is there a way to go back to the previous version when i don't like the speed/handling of ID5?
      10-17-2020, 02:11 PM   #6
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
If you do it, you will regret it, the unit is not designed for this firmware and will not function correctly.
Just replace it with a proper ID5 unit.
      10-22-2020, 11:09 PM   #7
XanderX
Drives: F36
Hi
Let me tell you from my personal experience.
One more time: personal experience. Probably if u do this your head unit will work slow and reboots 2-3 times per day.
I did that because i wanted carplay and i've flash it from id4 to id6.
I had NBTEvo_EXXXXX something.
Now i have NBTevo_O1803 cause from what i've heard from other guys it's the most stable one.( has the most stable kernel)
In 4 month my unit never restarted because all i'm using it's youtube and waze.
The idea is that you are changing the kernel of the UNIX with some MB on the hard drive. If you are using long way navigation routes the 2GB of RAM are getting full and then the headunit probably will restart because it gets a KERNEL PANIC error.
I drive my car somewhere around 30-40 minutes per day with ware and youtube streaming. No issues so far.
No. When the unit boots up BTLD-Bootloader file has RAM Allocation for the speed of the responsive actions. If i press the menu button then instantly will go out of any application i'm in and go to menu. Even though ID6 has some new graphical icons i didn't see any difference.
Somewhere between 35-45 minutes.
Yes. By flashing back to id4.
And now i have id4 with id6 software and no problems.
I don't want to say that anybody is lying but this is how my HU reacts to id6
Cheers!
Poochie9104.50
sspade2464.50
sboz0.00
      10-23-2020, 06:55 PM   #8
UnknownBeing
UnknownBeing's Avatar
Drives: 16 340i (22 M340i in-transit)
Originally Posted by dragosv6 View Post
Hi
Cheers!
Can you provide instructions on this process?
      10-24-2020, 06:16 AM   #9
zox1i
Drives: 116i
Thank you for sharing your experience. I heard different stories wether people have problems after upgrade. Some have constant restarts of NBT Unit, and some haven't experienced single restart even when they have been using guided navigation. I still want to try it. Can you please explain how you done it, or at least can you reply to this questions?
Did you change you I-Step shipment during SVT calculation (other that your original I-Step shipment) and on what value (if you remember)? I presume you changed zeitkriterium and Vehicle Type Code on FA.
Did you use HW-ID's from SVTactual?
What options did you choose when you flashed it (swDeploy etc)?
Thank you!
Hi
Cheers!
      11-17-2021, 07:30 AM   #10
th31
Drives: BMW 430d xDrive 2016
I think you can update NBTEvo iDrive 4 if your car is produced on late 2015/early 2016.
      12-03-2021, 06:29 PM   #11
eurokidx
Drives: BMW F20 LCI 118d.
Only if it was iDrive 5.
      12-07-2021, 06:16 PM   #12
Baja272
Drives: E92 BSM 6-Speed
Several companies like Easy Bimmer Coding claim this is possible and stable. Anyone have experience with any of these remote flashes?
      12-08-2021, 12:25 PM   #13
Derekrpd
Derekrpd's Avatar
82
Drives: 2015 BMW 335i Xdrive
Interested in this too…
2015 335xi Black/BLK, FBO BM3 Stage 2, AA FMIC, CTS Turbo CP, FabSpeed Sport Cat DP, MPPK airbox w/high-flow filter, 18" AG M310's black
      12-26-2021, 04:19 AM   #14
bigdnno98
Real Car Enthusiast
bigdnno98's Avatar
Drives: 340xi
The ID4 hardware doesn't have enough RAM for ID6 software and will glitch/reboot while using the OEM navigation. If only using ACP to navigate, you probably wouldn't notice a difference. I have yet to find the coding instructions online to do it myself.
      12-27-2021, 11:47 PM   #15
not1337
Drives: 2016 340i
I just got this done through EasyBimmerCoding today on my 2016 340i. Been driving around all day with no issues using carplay, works fantastic. They were exactly on time with the scheduled appointment I made and did it over team viewer. Super satisfied, the only additional hardware I installed was a $10 wifi antenna. I was worried it would wipe out my coding, but it retained everything that I had changed. Ill continue testing to see if any issues pop up but I honestly haven't noticed anything.
      12-28-2021, 02:07 AM   #16
bramwall
Drives: F30 320i xDrive
how do i know which version of iDrive i have?
      12-28-2021, 06:29 AM   #17
JeffBMW4Series
JeffBMW4Series's Avatar
76
Drives: 430i F33 Convertible
How much was this please?
      12-28-2021, 08:12 AM   #18
not1337
Drives: 2016 340i
Around $200, i found a discount code ‘BIMMERFEST’ that i used
https://easybimmercoding.com/products/idrive-4-evo-to-idrive-6-flash-coding-package
      12-28-2021, 08:48 AM   #19
elthox
Drives: E91 330xd stage 1
From the map version. check it in options/version
      12-28-2021, 08:50 AM   #20
elthox
Will not reboot if flashed properly.
      12-31-2021, 07:24 PM   #21
Tim.Rader
Drives: BMW 340i
I'm considering this for my 2016 340ix. I'm interested in how your upgrade holds up. Have you tried using the in car navigation with the upgrade?
Thanks,
Tim
      01-08-2022, 02:01 PM   #22
not1337
Drives: 2016 340i
Thanks,
Tim
It's holding up well, no crashes. I don't use the in-car navigation though, I use google maps.
2016 340i - BM3 Stg 2 - XHP Stg 3
flash, idrive 4, idrive 6
