11-01-2021, 09:00 AM | #1 |
Rep 3,126
NEW RELEASE: DINANFLASH Handheld for the BMW B58M0 Engine
DINANFLASH Handheld for the BMW B58M0 Engine Part Number: 4431 Applications:
Product Page(s) / Pricing: https://www.dinancars.com/products/s...lds/parts/4431 Release Date: Available Now! Description: Flash tuning meets convenience and versatility with a feature rich handheld device. That’s right – the most significant and important performance enhancement available for your turbo charged car is now deliverable from the comfort of your drivers’ seat. With multiple octane calibrations dependent on your specific needs, desires or limitations nestled in the palm of your hand you can switch to the appropriate map with the click of a few buttons and a short flash. The main component of the DINANFLASH Handheld is the Dinan performance engine software loaded onto the device which is your ticket to maximum power. Not just any power however - safe, reliable power that does not sacrifice the long-term health of the engine. Dinan performance engine software is so much more than just turning up the turbo boost after all. It is a fully re-tuned engine management program that maximizes power while keeping all the BMW factory safeguards in place. In most cases Dinan software engineers also implement their own additional safety precautions in order to guarantee flawless performance that may not have been needed with factory power levels/programming. Protecting your BMW, while giving the most performance, is the definition of "Performance Without Sacrifice". To do just that, drivetrain and engine components are analyzed for strength, and then the calibration is tested on the dyno and in the real world for durability and drivability. This process has been a cornerstone of Dinan software development for decades and a major reason why Dinan performance tunes are often labelled as being the smoothest, factory-like solution in the marketplace. While the tune itself is the most noteworthy aspect of the DINANFLASH Handheld it is also much more than just an improved delivery mechanism for the masses. It is loaded with additional features that assist in monitoring, logging and troubleshooting as well. These features allow increased visibility on the inner workings of the engine/vehicle and help to ensure that the car is functioning at peak performance at all times. Features/Benefits:
11-01-2021, 09:12 AM | #2 |
Rep 190,614
Nice
11-01-2021, 02:42 PM | #3 |
Alexander Hartunian
58
Rep 95
Drives: 2018 BMW 440i
Is this compatible with vehicles that have been updated to the latest i-level firmware, which locks the current DME build from flash tuning?
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
11-01-2021, 02:53 PM | #4 |
Rep 3,126
Yes. Any B58(MO) equipped vehicle can be unlocked using the supplied poweir harness and following the prompts as directed with the device. Process is outlined in the installation manual if you are curious but we should be also posting a installation video to the product page a bit later this afternoon as well.
alexander759958.00 |
11-01-2021, 03:51 PM | #5 |
Rep 106
Drives: 2023 BMW M3 6MT
My 340i has the MPPSK kit installed, is it possible to flash back to the original MPPSK settings?
Retired: 2011 BMW 323i, 2012 335i Sportline
Current: 2017 340i | MPPSK | 8AT | Current: 2023 M3 /// | 6MT | Aventurine Red III | |
11-01-2021, 04:21 PM | #6 |
Rep 3,126
As long as the MPPSK tune is present when conducting the flash, yes. The device reads whatever the the present version of tuning is on the vehicle so it can revert to that state as "stock" when requested.
11-02-2021, 05:18 AM | #9 |
Rep 598
11-02-2021, 07:26 AM | #10 |
Rep 105
So, for the guages, I'm assuming you can pick what you want displayed and keep it up while driving? Can you keep the tuner plugged in and get the gauges every time you drive it, or do you need to re-set the gauges each time?
11-02-2021, 11:08 AM | #11 | |
Rep 3,126
Yes, you can can pick up to 4 PID's to be displayed on the screen and they would display as you are driving when the device is connected. You would have to re-select those PID's anytime the device loses power though as they are not saved to memory. The functionality of the gauges/logging was designed to be more tertiary with the intended use of troubleshooting more then anything else and as such constantly fluctuating. Perhaps if there is enough demand/justification to make a change to the coding that would allow a save state that could be implemented down the road. I wouldn't think that would require any great effort but seemingly lesser stuff has surprised me before. |
11-04-2021, 12:20 PM | #12 |
Rep 317
Can this device unlock the full potential of future upgrades like intake and downpipe like a BM3 or MHD tune can?
Can the burble settings be changed preferably to turn them down? |
11-04-2021, 12:44 PM | #13 | |
Rep 3,126
Currently there is not a burble option but there *could* be at a future date within the coding option menu. We opted to not include it just because we wouldnt allow going over factory settings for emissions reasons and the thought was the vast majority of folks will want to increase, not decrease, them which would cause some confusion/irritation. |
11-04-2021, 03:39 PM | #14 |
Rep 5,364
Will something similar be released for EWG N55s?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
11-04-2021, 03:42 PM | #15 |
Rep 3,126
11-05-2021, 02:31 PM | #16 |
Rep 105
So I got my tuner in today. Hooked it up and says it needs update. Downloaded the app, hooked it up and it says it has my vehicle info and needs configured and is get an email when it's ready.
Is this normal? How long will it take before I can program my car? |
11-05-2021, 02:45 PM | #17 | |
Rep 3,126
The process is outlined a bit within the FAQ on the product page HERE. |
11-06-2021, 11:46 AM | #18 | |
Rep 5,364
I would think it would be an extremely easy transition to the N55 given you already have tunes for them and DMEs are even easier to tap into. You've already got the device. Seems like a huge missed opportunity |
11-08-2021, 07:25 AM | #19 | |
Rep 3,126
It's also a balancing act of managing resources (people and time) to do something like this where the market is already pretty well represented (given, not exactly with a handheld like this) along with the new development where the ceiling can be more robust. Usually, the longer something is in the rear view mirror the harder it is to go back to but its not unsurmountable. With the N55 I would think the chances are quite good since the newer ECU's which we would ultimately WANT to go to next are still locked out. Might as well expand out to applications we could in the meantine and ones that have the most upside. The MEVD17 N55 and the MG1 MINI are the logical ones in my estimation. |
11-09-2021, 09:25 AM | #20 | |
Rep 105
11-09-2021, 01:34 PM | #21 | |
Rep 598
Talk about a disappointment for you so far Dinan get this guy his tune! |
11-10-2021, 09:35 AM | #22 |
Rep 105
I’d really just like some sort of communication from them. I’ve called twice, submitted a ticket online and posted on here with nothing other than the previous post from 5 days ago telling me 24-48 hours. I was promised a phone call that never happened, no emails, nothing. I spend $700 after tax and can’t even get a response as to when I might be able to actually use the product. If it's going to take however long because of whatever reason, fine, but just let me know something
