12-14-2021, 07:54 AM | #1 |
Rep 286
Suspension Refresh Help
My adaptive suspension on my 340i is on its last leg. I currently daily drive this car and want to keep the suspension soft and compliant. What are my options? I'm not particularly interested in coilovers, I'd like to stay relatively OEM so I've been debating just replacing the them with OE style B4 dampers but noticed the B6s aren't much more expensive. Does anyone have any experience with the B6 dampers? Again, I really would like a soft, daily driver ride.
Any opinions welcome. Thanks.
17' 340ix|Track Handling Package|MPPSK|MP Stage 2.5 ECU Tune|MP Stage 2 Trans Tune|AP Intake|763M Wheels
12-14-2021, 10:36 AM | #2 | |
Rep 5,393
My understanding is that B4-DampTronics are pretty much stock replacements. So considering that you like the stock Adaptive ride, and depending on how long you intend to keep the car, they may be the way to go. B6-DampTronics (and B6 in general) are supposed to be Bilstein's upgrade in both higher quality materials and higher level technology. Now the "technology" part might concern me based on your comments. Because Bilstein tends to make things stiffer/harsher as you go up the chain in their product line, as if they assume people are weekend trackers. I would look for specific comparison of specs between the two models. You may find that the B6-DampTronic are set up more stiffly than B4-DampTronics. Based on your requirements that isn't what you want. Tip: you can increase comfort level when you replace dampers/springs by also replacing all of the stock rubber components above and below the springs and dampers. Even if they look fine, rubber degrades over time with use. New rubber bits will make the ride the most comfortable. Hope this helps! |
12-17-2021, 02:50 PM | #3 |
Rep 97
B6
sspade2464.50 tobefair-idontcare54.00 |
12-19-2021, 11:36 AM | #4 | |
Rep 10,256
If you are looking for near OEM ride quality, you will find B6 Damptronic shocks substantially stiffer. B4 Damptronic shocks + new OEM springs + replacing stock rubber components as mentioned above = would be a prudent approach considering your requirements. |
johnung4528.00 tobefair-idontcare54.00 |
12-24-2021, 03:49 AM | #5 | |
Rep 151
I hate the way it rides. Its noticeably stiffer than stock and michigan potholes would never allow me to enjoy that sort of thing. I hate the way it sits. It is perfect in the rear imo, like 1 inch wheel gap and the front looks close to stock. Im now considering kw ddc coilovers or something else. Ive heard that b16 damptronic are even harsher and that kw is more tame in this sense. I could also use some advice, what does everyone think of kw ddc? Should i delete edc and go with another coilover kit? V3? V2?
I bought this car like 2 years ago cuz of the supra hype. Someday itll be a 900 awhp beast. Maybe?
gds4.50 tobefair-idontcare54.00 |
12-24-2021, 03:50 AM | #6 | |
Rep 151
01-10-2022, 12:27 PM | #7 | |
Rep 132
The Bilstein front spring cups are orientated differently to OEM and therefore raise the ride height up with the same spring. I.e. my 10mm lower MP Springs yield an OEM ride height with the B4 DT's. |
01-10-2022, 03:44 PM | #8 | |
Rep 10,256
Are B4 Damptronic shocks that unsuitable that returning to OEM 'damptronic' is an option? I also find that OEM M Adaptive shocks can be best described as lethargic. They have difficulties keeping up with rapid changes in road surface and at some point just begin to bounce. My car has OEM M Sport springs. |
gds4.50 |
01-10-2022, 04:37 PM | #9 |
Rep 132
They are certainly stiffer than OEM mlite shocks, especially when cold. They have mellowed since new. Problem is i have never paired them with OEM M Sport springs so my comments may not be fair. Also my wheels are 19 inch with low profile non-runflat tyres. If I'm honest the electric part of the adaptive is just so non-consistent. Perhaps the bilstein amplify this. I.e. i can drive out of my housing estate thinking this is fine.. another time I can be driving back after a longer drive and the shocks feel stiffer even in comfort mode. I think the adaptive nature of the shocks doesn't react well with sudden changes in road surface. The best shocks I've experienced for that were on my old e92 with Koni FSD dual valve shocks.
Perhaps if I put oem springs in they'd be fine albeit stiffer than oem shocks. |
02-01-2022, 08:33 AM | #10 | ||
Rep 286
What does this forum think about deleting the EDC function of the vehicle and replacing the shocks with OEM non-edc shocks or an aftermarket equivalent like Koni or Bilstein for a compliant but comfortable daily driving shock? The reason I ask is because I love this car but the EDC shocks are 4-5x the price of regular shocks and I don't mind not having that function. Of course the sport setting is stiffer, but in reality it's not much of a difference especially in comparison to any aftermarket option. Also, the car just rolled over 90k and I want to keep the car for a while without dumping a ton of money into a depreciating asset. Anyways, what do you guys think?
02-01-2022, 11:17 AM | #11 | |||
Rep 5,393
With your goals in mind I took a quick look at TireRack and Turner. Here are the options that I see: Keeping Adaptive/EDC System: 1) Bilstein B4-DampTronic $1,380-$more? This will give you the same suspension feel that you like now. Also replace the rubber top and bottom spring/damper mounts and external bump stops. There were some other B4-DampTronic options listed for your car at maybe $200-$400 more but descriptions were terrible and I didn't have time to figure out exactly which Bilstein's fit your car. Avoid the B6 options as discussed previously since they are harsher than B4's. 2) KW Street Comfort EDC coilovers $2,059 You aren't keen on coilovers but KW has a reputation for high quality and the most comfortable in case you change your mind. Non-EDC Options: Note: there are various methods to cleanly eliminate EDC that you can look up. Budget roughly $200 3) Koni Special Actives $760 Best replacement damper. High tech dual valve system developed with McLaren makes this a comfort and a sport shock that automatically adapts to road conditions. Also change out stock suspension bits as previously discussed. If you wish to replace old stock springs and slightly lower at the same time, get Eibach XDrive springs ($305) with won't add harshness. See photo. Part number is probably E10-20-031-06-22 Labor to replace springs is essentially free if done at same time as dampers. Make sure to replace bump stops with shorter F80 bump stops. See photo. Avoid H&R and Dinan which are much stiffer/harsher 4) Koni kit with Sport Yellow dampers and the Eibach XDrive springs. $1,094 Fronts are adjustable for comfort although set at full comfort they aren't as comfortable as KoniSA's. Great dampers though. Not as stiff/harsh as Bilstein B6/B8. Replace stock bits and use F80 bump stops. 5) KW Street Comfort Coilovers $1,819 Same description as above. Recommendation: Unless you have a change of heart on coilovers, I would recommend investigating the exact part numbers and best prices that you can find on the Bilstein B4-DampTronic. They would give you the ride that you like and are accustomed to. Replace stock suspension bits too. If that total price is more than you want to invest then consider the non-EDC Koni Special Actives. I have them and they are far more comfortable than stock and sportier too. Replace stock bits and turn off your cars EDC. You have the Eibach spring option too. They are mild lowering, about 0.8" in front and 0.6" in rear to eliminate some of the XDrive reverse rake. Good luck! Hope this helps! |
02-01-2022, 12:45 PM | #12 | ||
Rep 5,393
02-01-2022, 12:50 PM | #13 |
Rep 10,256
johnung comments are as comprehensive as one could possibly wish for.
OP, how important is it for you to adjust the suspension after initial installation - for example rebound / compression + suspension height? |
johnung4528.00 |
02-01-2022, 12:51 PM | #14 | |
Rep 5,393
02-01-2022, 01:41 PM | #15 | |
Rep 1,003
Bilstein and Koni options for non-electronic dampers look to be around $7-900. You love the car, you're getting solid value out of it now, and I bet part of the reason you love it is in the way it rides... or at least used to ride. Based on your goal I'd be afraid that anything other than OEM is going to be a disappointment. It's going to be trading comfort for stiffness. I've been there done that many times over and at this point I'm with you, I want my daily driver to be comfortably sporty. My suggestion is to spend the extra $1k to get the "right" parts and enjoy them. If you sell the car long before hitting 180k miles, it'll be a favorable line item in the description - shocks replaced with OEM. It'll bolster the value of the car and/or be one less holdup giving the buyer's market pause when shopping. Better yet, take the car in for a complimentary check at your dealer if they offer, or ask your vehicle inspection shop, or jack up the car and take a look and you might find that one of your shocks is clearly failed as someone mentioned, with fluid leaking. You could very well replace just the fronts or just the rears and get that ride quality back, and put off doing the other axle until something actually fails. |
Chukker27.00 |
02-01-2022, 09:25 PM | #16 |
Rep 785
Do the 335 and 340 use different part #s for the adaptive dampers? I just took some off my car with a good bit of life left in them. I'm about to put them up for sale in the classified section
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
02-02-2022, 09:46 AM | #17 | |
Rep 1,003
The answer is yes, they do use different part numbers. The LCI refresh usually includes revised "suspension tuning" and tweaks to geometry, as was the case with the F30. So 340 owners would need to seek out lower-mile 340 shocks. |
Jvac432.00 |
02-02-2022, 11:30 AM | #18 | |
Rep 785
02-03-2022, 01:31 PM | #19 |
Rep 75
Ok so been doing lots of reading on this to try and figure out what next steps are for me.
Recently picked up my first bimmer, 2016 340i Xdrive with M-Sport package but standard suspension (non-edc). She has been well maintained with regular service but at 82k on the clock the suspension is starting to show (what I think) are signs of needing replacement in near future as the suspension is feeling a bit bouncy over undulations but harsh over small stuff. Park of it is the thinner profile run-flat tires that the dealer put on, which I will be going to normal tires and running something like a 245/40r18 in the near future, but I am looking to lower the car ever so slightly. Will see snow and winter driving, bad missouri and kansas roads and will be a daily driver for the most part when I actually have to commute into the office. So really just looking to close the fender gap a bit (may .5" all around). This won't be tracked but gf and I both enjoy spirited driving (she's got an '18 x3 m40i) when the opportunity arises. With that said, would moving to coilovers be a better bet than going with something like the Koni Special Active and Eibach springs? Want something that is still going to have a comfortable ride, so looking at maybe KW Street Comfort or V1? Seems like Bilstien B14s will be stiffer than I want. |
02-03-2022, 02:23 PM | #20 | |
Rep 1,003
02-03-2022, 05:12 PM | #21 | |
Rep 352
Could someone confirm if this is a XDrive thing or is this the case with all B4's? I want to achieve a nice Eibach level drop using their springs, so if the b4's raise the front slightly higher - what good springs can I use to compensate for the increase in height to still achieve the Eibach drop without the front looking noticeably higher? |
02-04-2022, 08:54 AM | #22 | ||
Rep 5,393
You don't say what year or model you have. But if you are considering Bilstein B4's then consider the Koni Special Actives instead. B4's are really just stiff replacement dampers while the KoniSA's are a combination comfort and sport shock. And they won't change ride height. I installed them with Eibach springs, and the drop was spot on with Eibach drop estimates Hope this helps! |
