01-20-2022, 10:04 PM | #1 |
Rep 236
Buffing out scratches, expectations?
I made a huge mistake on not checking my clay mitt when cleaning my bonnet after the a good wash, only clayed the bonnet, and I scratched the thing out of it
I hand buffed the most I can and it wasn't too bad but I wasn't happy given that I could still see scratches. So I ended up investing in an orbital DA, pads and Menzerna polishes. I started off with the medium cut pad and medium cut polish, I didn't see much differences. Then I went and did heavy cut pad (microfibre) and heavy cut compound, I did notice less scratches but I could still see a few. I cured the mf pad with 5-6 drops, rubbed it in, and then another 5 drops for cutting. I run 4.5-5 on the DA and do 3 passes (1 down, 1 across and 1 down). I think I've put enough pressure (?) and I do go over it fairly slow. Am I doing something wrong? The damage Hand buff Heavy compound I reduced the exposure on this photo (car sapphire grey) |
01-20-2022, 10:14 PM | #2 |
Rep 16,054
When I do a full correction I use Menzerna, Step 1, 2 and 3. With the Step 1 and Step 2 I use a rotary buffer, which works much faster than dual action. I use dual action with Step 3. The Menzerna site gives good advice on what to use and how to use it.
01-30-2022, 03:38 PM | #3 |
Rep 113
Sounds like your doing it right. The thing is you will never get all the scratch out unless you spend hrs of time on it. My guess would be maybe try another polish pass see if it gets you anything. Todd over at essoterric always talks about diminishing returns or chasing. At some point trying to get to 100percent starts doing more damaged. Your first picture to your last looks 100 times better in my opinion. I say leave it with a little road dust nobody from 5 feet away will ever notice
01-31-2022, 06:01 AM | #4 |
Rep 15
