BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Akebono on M Performance Brakes
      10-19-2018, 08:22 AM   #1
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Vehicle: 2017 BMW 330i xDrive Sports Wagon (F31)
Current Brakes: BMW M Performance Brake System
370 x 30 mm front
345 x 24 mm rear
As most know, the brake dust with these brakes is something else (especially with gold wheels). I was planning on getting Akebono EURO Ceramics, but read previous threads (older) where they weren't available for these brakes. I sent them an email, with this reply:
Thank you for contacting Akebono with your brake pad question. If your vehicle has blue calipers then the correct pads will be EUR1880 front, and EUR1656 for the rear. Please let us know if you have any other questions or concerns.
Are they referring to the same brakes, or the M Sport Brakes?
If different, can someone confirm that Akebono still has no option for these brakes?
If not available, who makes the best street pads (quiet) with low dust for this brake (I've read many threads, but asking specifically for this brake)?
Thanks!
UPDATE: Installed Akebono EURO 1880 (Front) and EURO 1656 (REAR). Happy with Purchase - see post #68 (https://f30.bimmerpost.com/forums/sh...2&postcount=68)
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      10-19-2018, 03:37 PM   #2
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
370 x 30 mm front
345 x 24 mm rear
Thanks!
Should be correct as Msport blue or Mperformance calipers only differ by the carrier allowing for the difference in rotor size.
Should even work for the front Grey brembo as those are the same caliper as the both Msport blue and Mperformance front calipers.
eleven11371.50
      10-19-2018, 08:13 PM   #3
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Thanks.
The BMW brake options are quite confusing. I believe you are correct. Worst case scenario, I'll send them back if they are the incorrect size.
2017 X5M - Current
      10-20-2018, 12:30 AM   #4
chhappy7
chhappy7's Avatar
Drives: TBD
I'm subbing to see how this turns out.
I've been getting mixed messages as well.
      10-20-2018, 05:19 PM   #5
mlev
mlev's Avatar
Drives: 2022 Tesla Model Y Performance
It looks like those EUR1880's will fit if your VIN has the S2NHA code (I believe 2NH is M Sport Brakes). They should be correct.
I opted for R1 Ceramic pads (much cheaper) for this issue and am pretty happy with them. Only issue is an initial squeal when cold until they warm up with a couple stops. I have heard better things about the Akebono's.
Logicoeur991.00
      10-20-2018, 09:40 PM   #6
chhappy7
chhappy7's Avatar
Drives: TBD
But this is about the M Perf brakes though. And your post is sort of exactly what many dealers and resellers have told me where some of them don't even realize that there IS M perf brake set, and give replies that it will fit the M sport brakes.
2020 X3 M40i
2015 328i - Sold @ 104,000 miles
      10-20-2018, 09:55 PM   #7
mlev
mlev's Avatar
That's because the M Perf Brakes and M Sport Brakes are both 370mm and 340mm. The only differences being the caliper color and rotors (drilled/slotted vs blank) and weight of those rotors. Pads and caliper size are the same.
johnung4528.00
      10-20-2018, 10:07 PM   #8
chhappy7
chhappy7's Avatar
Drives: TBD
And yet, many manufacturers and dealers of aftermarket pads (Akebono, Hawk, etc) are unsure whether it'd fit or not. Not saying their physical dimensions and specs are not the same. Even when I look up rotors and stuff, it looks to be the same.
For example, if you go here you'll see that for front euro ceramic brake pad set, it says for vehicles with standard brakes (Without M-sport or M-performance), and yet rear Euro ceramic brake pad set says for vehicles without M Performance brakes, but does not mention M Sport brakes.
Or even easier, look at where this post started. It's like that where I would send a message asking if it'd fit M Performance brake kit, and even give them the part number and specifically say that it's yellow and not blue or whatever, still get a reply saying they're not sure or that it'll fit M Sport brakes.
Let's say you ask a manufacturer if the LED headlights would fit in place of Xenons, but they tell you it'd fit in place of halogen, would you take their word and go for it? I mean physically the slots are the same. But the wiring is probably different going from halogen to LED and Xenon to LED.
It's like that. It's kind of frustrating when they are not super clear.
2020 X3 M40i
      10-21-2018, 06:38 AM   #9
Logicoeur
Logicoeur's Avatar
991
They are not the same rotor dimensions.
The pads fit because they have the same caliper, while the distance the caliper sits from the center of the wheel/axle is different (by way of carrier length)
      10-21-2018, 08:00 AM   #10
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
From what I read here the front brake pads fit across different calipers. The part numbers only differ because of compound. This info might be out of date as I’m not sure if anything changed with the x40 updates.
Logicoeur991.00
      10-21-2018, 10:14 AM   #11
eleven11
eleven11's Avatar
Drives: -F85 X5M-
The VIN search will provide no help, as the brakes I have were added afterwards (to model in link above).
Thanks for the feedback on the R1 pads.
2017 X5M - Current
      10-26-2018, 04:22 PM   #12
Pdxway
Pdxway's Avatar
19
Drives: 2013 328i
May I know what you get?
I also have M Performance brake and it is about time to replace the pad. I am looking for something that is less noisy and less dusty too.
Thanks!
      10-27-2018, 12:26 PM   #13
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Thanks!
Certainly. My independent mechanic believes the Akebono pads I listed above should work. I haven't scheduled an installation yet, but will definitely update afterwards.
2017 X5M - Current
      10-29-2018, 08:42 AM   #14
Sweeney921
Sweeney921's Avatar
98
Drives: 2000 BMW E39 M5
Looking forward to hearing how these work out, particularly your impression of their initial "bite"
      10-31-2018, 07:18 PM   #15
Pdxway
Pdxway's Avatar
19
Drives: 2013 328i
I am getting the R1 ceramic pads to try. Will see if that works.
      11-01-2018, 07:01 PM   #16
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Sounds good. Let us know what you think.
2017 X5M - Current
      11-01-2018, 11:02 PM   #17
Pdxway
Pdxway's Avatar
19
Drives: 2013 328i
I ordered M sport package from R1 and got the shipment today. Unfortunately, they send the wrong type. I got non Brembo single piston type of pads instead. Very disappointed!
Update: Called them and the sales associate didn't really attempt to find the correct parts for me. But he did offer me return label. I guess no R1 review....
      12-03-2018, 05:41 PM   #18
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
Their website says these are the proper parts for the blue calipers, there was a set on RockAuto so I ordered them. Not sure when I'll get around to installing them as I'm refinishing a set of blue calipers to put them in so it'll be at least until next year before I install them.
Anyone else install them?
      12-03-2018, 06:11 PM   #19
eleven11
eleven11's Avatar
Drives: -F85 X5M-
These are supposed to be the correct ones. You actually purchased the last ones on RockAuto, that I was going to purchase today. Great price.
2017 X5M - Current
      12-03-2018, 08:26 PM   #20
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
Oops I had been checking RockAuto for a while and never saw them on there before. And yeah they were like half the price of ordering from ECStuning so I just went for it.
      12-04-2018, 12:12 AM   #21
M4_GTS
Hong Kong
1153
Drives: M4 GTS
I grabbed their last set of front and rear that was in stock 2 weeks ago too. Back on Nov 16, the price was $67.75 for EUR1880 and $60.60 for EUR 1656.
Originally Posted by FMLYSDN View Post
You're a dick. Oops. Did I just say that?
      12-04-2018, 06:07 PM   #22
eleven11
eleven11's Avatar
Drives: -F85 X5M-
No worries mate.
I wasn't 100% sure the price was for a set (left + right), so I stalled on placing the order.
2017 X5M - Current
