09-09-2021, 11:31 PM | #1 |
Rep 19
Rough idle 440i
Hey so I'm having trouble with my f32 idling abit rough, I installed a catless downpipe a few months ago and everything was fine for a few weeks until all of a sudden a cel popped up I figured it was the o2 sensors so I read a few threads discussing how an o2 sensor spacer would fix the issue and so I bought one and slapped em on yesterday and along with a cheap Bluetooth obd2 reader I bought I cleared the codes. Since then the cel has turned off which is perfect but I noticed an issue where if I leave the car running for like a solid minute it rpms would drop to sub 1k and idle rough until the rpms picked back up within 5 secs.
It also happens when I don't press the gas and the car is just moving bc its in gear but this one is reasonable bc of the rolling resistance. Also after clearing the cel when i took it out for a test drive all of a sudden it threw up 2 errors for 1 not being able to read tpms and 2 for an "unstable chassis" which I have no idea wut it means but is the time I came to a stop the y both disappeared. Any help is appreciated. |
09-10-2021, 08:07 AM | #3 |
M340i
392
Rep 968
Drives: BMW M340i
You did a catless downpipe without a tune? I'm not sure that would work in the long run.
With covid and the fact that I only live 2 miles from work I only drive 5-6k miles a year. I change my oil once a year at about 6k miles. I use bmw oil kit from FCP Euro. 1/3rd the cost of the dealer near me. |
09-10-2021, 11:14 AM | #5 |
Rep 19
Yes I tested the whole thing for exhaust leak after the install and took care of it all so there is no exhaust leak and the o2 sensor spacer goes on top of both o2 sensors and then gets secured to the downpipe
09-10-2021, 11:15 AM | #6 | |
Rep 19
09-10-2021, 03:29 PM | #7 | |
Rep 7,598
For the secondary O2, you are also not supposed to run any kind of spacer (etc) as the secondary O2, if it behaves like it does on the N55, is used for more than just catalyst monitoring and is used to calibrate or prevent drift on the primary O2 (MHD confirmed this). So, remove that one as well. People only run these as a temporary solution to try and pass emissions with a catless (or inefficient catted) DP and they are not supposed to be ran long term. You should removed both immediately. |
JonOhh672.00 Boostedphil698436.00 |
09-10-2021, 06:48 PM | #8 |
Rep 1,597
The reason I asked is I suspected you put a spacer on the upstream O2. This throws off your AFR, you need to remove that. As far as the downstream O2, the urban myth is that its somehow used to adjust the longterm trim or calibrate the wideband which I've never been able to confirm. In fact, ISTA explicitly says that the downstream O2 does not affect AFR and is only used for catalyst monitoring. Theres a long story to this but it does not belong here.
09-10-2021, 07:33 PM | #9 | |
Rep 19
09-10-2021, 07:35 PM | #10 | |
Rep 19
09-10-2021, 08:33 PM | #11 | |
Rep 7,598
09-10-2021, 08:35 PM | #12 | |
Rep 7,598
This is also not a thing... where did you hear this from? Yes, ECU's have adaptations and learn things but they absolutely do not stop throwing a code if you keep clearing it. "Keep clearing codes" is not a solution to a problem if there is one. |
09-11-2021, 05:48 PM | #13 | |
Rep 1,199
Anyway removing cats requires a tune or O2 sims to avoid issues. I recommend you just put the cats back and get a cat-back exhaust system instead of spewing NOx into the atmosphere like it's 1969.
09-13-2021, 09:05 AM | #14 | |
Rep 1,597
09-13-2021, 12:08 PM | #15 | |
Rep 733
If you don't want to get a tune, it's probably best to put the oem downpipe back on and modify your exhaust instead. These motors breathe just fine... actually more than fine...for stock tune. The DME runs all sorts of tests based on those secondary O2s, which in themselves can cause a rough idle as the AFR is varied back and forth between rich and lean during some of the test procedures, which will usually continue until the test is passed...which it won't with a catless downpipe. You can sometimes clearly hear this happening at idle... doesn't feel very nice. |
09-13-2021, 03:07 PM | #16 |
Rep 1,117
Drives: 2015 BMW 435i Xdrive MSport
You would have been better off getting a catted downpipe from Fabspeed or Active Autowereke. It would have given no more sound and no hassle of a check engine light.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
09-13-2021, 03:31 PM | #17 | |
Rep 7,598
https://www.e90post.com/forums/showthread.php?t=1147379 https://blog.fcpeuro.com/faulty-oxyg...toms-diagnosis Quote from FCP page: "The signal from the second bank of oxygen sensors is used primarily to detect any problems with the vehicle's catalyst and to tune the fuel trim. " It's all over the internet, you can do your own searches and fact checking. Fundamentally its because the primary O2 is a wideband and the secondary is a narrowband, so the secondary is used to keep the primary "calibrated" around lambda=1. |
09-15-2021, 04:59 PM | #18 | |
Rep 1,597
Thanks for posting your information. One is an e-series forum discussion and the FCP is a blanket statement. IMO, this is heresay information from users about long-term fuel trim drift not that it should necessarily be discounted. I have not seen LTFT drift on my catless setup. Maybe this was a feature of the ECU program in the e-series. Maybe this is used in the F-series engines but not documented. ISTA does not discuss any use of downstream O2 in anything but catalyst monitoring. I still think this is important enough though to keep an eye on but I still do not see definitive proof that downstream O2 is being used in any way in fueling or calibration. In fact, the forum discusses the narrowband voltage at 1V whereas BMW narrowband baselines at .750mV. Theirs is not a technical discussion meshing with reality of what ISTA is stating. I am going to dig somewhat further including asking FCPEURO where they got their information. Thanks.
09-15-2021, 05:38 PM | #19 |
Rep 2
09-15-2021, 08:04 PM | #20 | |
Rep 7,598
09-16-2021, 10:23 AM | #21 | |
Rep 1,597
