BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > KW street comfort spring binding
VIBE Motorsports
      07-20-2019, 07:31 AM   #1
HandyRandy
Drives: F30 328xi '13
Finally figured out what is causing my horrible noise. The spring coils are binding (lower two). How do I fix this?
      07-21-2019, 11:36 AM   #2
M4_GTS
Hong Kong
858
Drives: M4 GTS
you're not the first one. someone else had the same issue. look at all the coils compressed, there's hardly any room for more compression. those springs are too soft for the car.
Originally Posted by FMLYSDN View Post
You're a dick. Oops. Did I just say that?
      07-21-2019, 02:28 PM   #3
cfm56d7b
Did you install the coilovers yourself or was it the installation done by a shop?
Thanks for sharing the picture. It appears the spring pre-load is excessive.
      08-23-2019, 06:04 AM   #4
PhillyfaanM3
PhillyfaanM3's Avatar
Drives: 2018 Mineral Gray Metallic M3
What car do you have? Is this on an F31 Sports wagon? I can't say that my springs were binding, but the stock springs that KW provided were not the correct spring rates, so any time I would drive over two adjoining unleveled surfaces, it sounded like my entire front end detonated as it slammed down.
As I only had them on for 2 weeks and had them professionally installed at the dealer, KW replaced the front springs with stiffer springs.
I knew of two other F31 wagon owners who also had to have springs replaced. Good luck.
2018 MG F80 M3 ZCP | HRE FF04 | Michelin Pilot 4s | M Performance HAS Coil Overs | Stek PPF | DINAN CF Intakes | IND Engine cover | Akrapovic Evolution Exhaust |
      09-11-2019, 12:37 PM   #5
MacklinUSOB
Drives: f30 328i 6MT Sport
Definitely is adjusted way higher than designed for. Collar is adjusted all the way up AND there is a spacer installed.
Lowering the collar and removing the spacer will reduce binding, if the height is unsatisfactory you'll need a stiffer spring. It must be riding and handling terribly with that much coil bind.
Add 5 horsepower for every M logo
328i RWD | Sportline | CRed on MW | 6MT | Bootmod3 STG 1 | MPE | GPlus FMIC | KW V2 | F80 LCA/TS | APEX SM-10 | R-S4 | Hawk HP+ | RBF600 | SS Lines |
Past: E36 328is & E38 740i
