06-19-2018, 10:30 AM | #1 |
Rep 5,457
Drives: F30
328 vs 320 exhaust question
What is the difference between the two?
Anything other than the single outlet (320) / dual outlet (328) ? |
06-20-2018, 09:02 AM | #2 |
Rep 2,382
That and I don't believe the 320i has an N26 variant, so midpipe is different just in terms of not having a secondary cat.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
06-20-2018, 09:22 AM | #3 |
Rep 5,457
Drives: F30
06-20-2018, 09:24 AM | #4 | |
Rep 5,457
Drives: F30
Im interested in whether or not a 320 axle back portion would make sense to swap in place of my 328 axle back. Probably a dumb idea but I wouldnt mind trying the single outlet rear exhaust look for a minute or two. Not looking to spend a lot of money and figured I could probably source one very cheap or maybe even free if Im lucky. What about the electronic valve component on the 328? What do people do when they put on a new exhaust that doesnt have that (assuming the 320 doesnt). |
06-20-2018, 09:27 AM | #5 | |
Rep 2,382
06-20-2018, 09:31 AM | #6 | |
Rep 5,457
Drives: F30
Is the opening on rear bumper actually different on 320 vs 328? I was not aware. The goal would be to make sure it is pin straight/centered when I had it welded on. |
06-20-2018, 09:33 AM | #7 | |
Rep 2,382
06-20-2018, 09:39 AM | #8 |
Rep 5,457
Drives: F30
I see that... doh!
Probably wont do it lol. Going to research other options... obviously in a perfect world I would swap the rear bumper and get a 335 looking exhaust but that would obviously be pretty expensive considering paint, parts, labor etc. At least a grand if Im looking at it right... Back to the drawing board! If you dont mind... what are the preferred direct swaps for 328 exhaust (axle back) that are direct bolt on and do not require bumper swap? |
06-20-2018, 09:43 AM | #9 | |
Rep 2,382
06-20-2018, 10:37 AM | #10 | |
Rep 3,679
Scroll down to the bottom of that link and you'll see the single oval outlet as well as hear the exhaust. Worth mentioning that I always like to caution against buying an exhaust based on sound in video. The MPE for example sounds WAY different in person than in video.
06-20-2018, 10:51 AM | #11 |
Rep 5,457
Drives: F30
Thanks guys. Definitely looking into your recommendations
06-21-2018, 06:16 PM | #12 |
Rep 1
Nice mods, definitely also planning on chagning the rear bumper on my 328i, but was wondering if a diffuser would be a good replacement in your opinion until i can save up to grab the M style rear bumper and get that thing painted. Also as far as the exhaust id s concerned do you happen to know what the diameter of the muffler is for the inlet and dual outlets? Thanks!
06-21-2018, 08:11 PM | #13 |
Rep 361
Do they both mate to the same downpipe connection? I guess I'm trying to ask do the n20 in both 320 and 328 have the same exhaust?
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO |
06-21-2018, 10:36 PM | #14 |
Rep 1,067
I'm pretty sure the 328i piping is larger, but I could be wrong. I'll see if I can find where I thought I read that.
Edit: In general, the problem is that the midpipe in 320i is 60,2mm and in 328i it is 75mm. http://f30.bimmerpost.com/forums/sho...d.php?t=805887 |
06-22-2018, 09:08 AM | #15 | ||
Rep 2,382
https://drive.google.com/file/d/1iPI...ew?usp=sharing Quote:
http://www.realoem.com/bmw/enUS/show...diagId=18_0975 http://www.realoem.com/bmw/enUS/show...diagId=18_0975
CntryClub007489.50 |
09-13-2018, 01:04 PM | #16 |
Rep 25
Hey Guys. Relatively new to the whole modifying in cars. I have a 2014 320i with jb1 tune and a resonator delete. It sounds nice but I want to give it a more aggressive sound but not ignorant like while I'm in the neighborhood or going to school. What are the safest options for doing something like this.
09-13-2018, 01:18 PM | #17 | |
Rep 4,318
09-13-2018, 01:29 PM | #18 | |
Rep 5,457
Drives: F30
Wasnt aware this would make a noticeable difference on its own. Any pics of the work? |
09-15-2018, 01:39 PM | #20 |
Rep 4,318
