02-20-2013, 06:53 AM | #1 |
Just one more taste...
566
Rep 2,011
Upgraded video card, lower performance??
So i replaced my video card last night because it shat the bed after 5 long years of CS and porn.
I replaced the old video card: nVidia 8600GTS http://www.nvidia.com/object/geforce_8600.html With this nvidia galaxy 620 http://www.bestbuy.com/site/Galaxy--...&skuId=5606903 I realize that the card is on the low-end of the performance scale but i figured that by increasing the video card memory by 8x (256mb to 2gb) i would at least see a little bit more stable FPS in CS:GO on similar settings under higher load situations. I saw that my max-fps dropped by 10-20FPS under normal running around! My drivers are up to date and the card is on the performance setting under the control panel. Would my 3gb of ram on my computer be the bottleneck now? Would increasing just the volume of ram help me or should i increase the speed also? Its currently 2x1gb sticks and 2x512mb sticks in the secondary slots. Im running W7 64bit, so i should be able to utilize more than 3gb of ram. Processor is quad core 2.4ghz Q6600 Is there internal motherboard limitations? Thanks for any help.
My Build Thread: Jet Black 6MT 128i with MSport
02-21-2013, 12:56 AM | #2 | |
Agent Smith
274
Rep 3,344
Drives: 2016 i8
Regarding the video card, you did downgrade unfortunately. Memory size is far from the most important spec, especially if you aren't maxing the resolution or running multiple monitors or using ultra high texture packs. Your first bottleneck is going to be GPU core and memory clock speeds, and if you look at the specs off nvidia's site, you can see why: 8600GTS: GPU Engine Specs: 10.8 Texture Fill Rate (billion/sec) Memory Specs: 128-bit Memory Interface Width 32 GB/sec 620: GPU Engine Specs: 11.2 Texture Fill Rate (billion/sec) Memory Specs: 64-bit Memory Interface Width 14.4 GB/sec So you actually downgraded on memory bandwidth by a lot. From http://www.gpureview.com/memory-band...ticle-356.html - "The amount and speed of the memory matter very little in comparison to the overall memory bandwidth. If you want a card with good memory, this number says it all." This measures how quickly the card can access said memory. Having more doesn't help if it takes longer to access it. If you can spend a little more, you may want to return it and check out something like this: http://www.amazon.com/EVGA-GeForce-1.../dp/B00966IU4M
The i8 needs a V8 amirite?
02-21-2013, 06:38 AM | #3 |
566
Rep 2,011
Perfect. Thank you so much!!!
edit: It appears that the card requires a minimum of 400W PSU, and i think mine is 375W, should that be alright?
02-21-2013, 11:31 AM | #4 |
Agent Smith
274
Rep 3,344
Drives: 2016 i8
You can use this to estimate it: http://www.extreme.outervision.com/p...ulatorlite.jsp
Based on some of the info you gave me, I only got it up to 260w. I'm fairly certain you'll be okay - the 400w minimum rating includes other factors like CPU, motherboard, memory and hard drives. Unless you went all out, you're probably under 350w. From nvidia: "Lower power configurations are possible using lower total power system configurations (CPU, Storage, Memory)."
