08-02-2019, 09:33 PM | #1 |
Rep 155
My N20 does not like Liqui Moly
A couple of years ago I made a post on here where I mentioned a strange problem when I changed my oil using Liqui Moly 5w40 LLF, my "minimum oil level" light came on after about 5500km.
I then switched over to using Castrol Edge 5w30 and did not have ANY issues over the next 3 oil change intervals. My last change was back to LM just to try something different again. Lo and behold, 5500km into my interval the min oil level light came on again! Super bizarre. There are no leaks, spark plugs aren't fouled so I know the piston rings and carbon deposits aren't an issue. Will be the last time I use Lm for now. Any other similar experiences? |
08-02-2019, 09:46 PM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
I've been using LM for about 14k miles with no issues. 7k intervals for changes and the car is in the shop now for its third oil change with 5w30
08-02-2019, 10:57 PM | #3 |
Rep 243
I switched over to Liqui Moly 5W30 Special Tec LL engine oil after my factory maintenance/warranty ended.
My car seems fine after trying out LM over BMW OEM engine oil. Next oil change interval might try Castrol Edge 5w30 since it's inexpensive but I don't mind to use LM again since it's made in Germany. |
08-03-2019, 03:59 AM | #5 |
Rep 3,679
I'm currently on my first oil change with LiquiMoly 0W-40. No problems, and the engine definitely runs a bit cooler. Takes slightly longer to get up to temp and doesn't reach quite as high of a peak temperature.
08-03-2019, 08:15 AM | #6 |
Rep 16,079
I'm on my second change using Molygen 5w-30. No problems. I added Ceratec with the first change to Molygen, and my mileage is significantly better, though I can't say if the Ceratec or Molygen alone is responsible, having done both at the same time. I don't see the OPs issue being related to LiquiMoly, but it could be related to using the thicker 5W-40. I wouldn't use a 5W-40 unless I lived in the Mohave or similar climate.
08-03-2019, 11:42 AM | #7 |
Rep 5,456
LM 5w40 here. Change every 5k miles. Have done 4 changes now and have had no problems.
08-09-2019, 06:13 PM | #9 |
Rep 34
Drives: BMW 320i XDrive
Running LM Special Tec LL 5W30. Engine runs smoothly and even noticed a small up-tic in fuel mileage. I'm doing an oil change tomorrow and will be sending an oil sample to Blackstone for an analysis. My car is a 2015 320i with 49,000 miles.
09-16-2019, 04:43 PM | #12 |
Big Turbo Boys N Girls
327
Rep 579
I use Pennzoil Ultra Platinum 5w30 for winter and 5w40 for summer. Car does not burn any oil and runs smooth.
I change my oil every 4 to 5K to keep it fresh as I push a lot of power and beat on her.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
09-17-2019, 05:16 PM | #13 |
Rep 387
I'm running 5w-40 LM Molygen now without issues. I was running 5w-40 Pennzoil Platinum Euro before; change my oil every 6k. I sent out the Pennzoil for a Blackstone analyses and it came back excellent. I will be doing the same with the LM in about 700 more miles. For my next oil change I'm thinking of going Amsoil. I will send that out for analyses too and decide from there which of the three I will stick with.
Did you add the correct amount of oil when you did your oil change? If your car is the RWD model, it takes exactly 5 qt, 10 oz. If you under fill, you will likely get the light to come on, not sure about if you overfill. Last edited by IraHayes; 09-17-2019 at 05:22 PM.. |
09-18-2019, 09:30 AM | #14 | |
Rep 212
That's one of the things I like most about Euro oil packaging -- it comes in 5L bottles. Just pour in the entire bottle. |
09-18-2019, 10:59 AM | #15 |
Rep 387
Yes, you are correct. If you are able to get 5 liter jugs, your are golden.
05-23-2020, 05:57 PM | #17 |
Rep 34
I've been using Liqui Moly Special Tec LL 5W30 for 30,000 miles. Oil analysis by Blackstone showed 10,000 mile intervals would be perfectly acceptable. Although I'll continue to change it before then.
2015 320i xDrive 8AT 3M Pro Series PPF | Suntek Window Film | Mishimoto Oil Catch Can Kit | M Performance Gloss Black Grille |
05-25-2020, 09:36 PM | #18 |
Rep 338
You know how long it would take me to get to 10k lol, in two mths i put less than 300 miles on her..
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
05-25-2020, 10:54 PM | #19 |
Rep 3,748
05-26-2020, 11:42 AM | #20 |
Rep 16,079
