05-31-2020, 06:32 PM | #1 |
Rep 4
Do I need to swap my sway bar?
I've been looking to do some coilovers on my 2016 340i Xdrive with Msport package (no track and handling package) I've pretty much decided on the Bilstein B16 kit, and read somewhere that the Sway bar needed to be swapped to the M-sport suspension sway bars because of clearance issues? Of course, now I can't seem to find the post that made mention of that. Has anyone put coilovers on their 2016 or newer xdrive and found this to be the case or should I be good to go?
05-31-2020, 10:57 PM | #2 |
Rep 3,539
You don't need to swap sway bars to fit B16s. After installing the B16s though you might consider moving to a larger rear sway bar since the B16 front springs are so stiff compared to the rear.
06-01-2020, 01:38 AM | #3 | |
Rep 5,392
Wiesbmw46.00 |
06-01-2020, 10:41 AM | #4 |
Rep 3,539
I'm going to have to partially disagree with you on this one. With softer springs the H&Rs front/rear set can work, but with the front spring as stiff as it is on the B16s, it's going to be punishing and cause a lot of understeer. The H&R rear bar alone might be fine for him though.
06-01-2020, 02:43 PM | #5 | |
Rep 5,392
I should have been more clear that I was agreeing with your assessment and only recommending the H&R bar for the rear, along with the stock front bar. Stay safe! |
06-01-2020, 07:39 PM | #7 |
Rep 3,539
I recommend you feel the car out with just the B16 first. If you feel like there's not enough rotation in corners then add a larger rear bar.
06-03-2020, 11:13 AM | #8 |
Rep 261
Drives: 2017 320i xdrive
Do you recommend upgrading shocks and struts at some point paired with H&R sport springs? I already have these installed and would rather avoid coilovers in the future if springs+shocks/struts will have similar effect on handling.
06-03-2020, 03:41 PM | #9 |
Rep 77
I currently have B16 Komforts on an F31 xDrive with stock way bars and there is no fitment issue, as other have stated. Farkle is quite right that the stiffer front springs (accounting for motion ratios) results in some less-than-desirable characteristics: body twisting from slow rear response, understeer, unsettled over bumps. However, body roll is greatly reduced compared to stock suspension, so I'd also agree that trying just the B16s before changing sway bars is the way to go.
Another option to consider is pairing the B16s with a stiffer rear spring to make the rear ride frequency higher than the front. Farkle has great threads on both the rear spring swap (you can use the B16 adjustable perch) and ride frequency. I currently have this type of setup, and I think it is a notable improvement over the springs that came with B16s. |
FaRKle!4016.00 bigshooter52.00 |
06-03-2020, 05:39 PM | #10 | |
Rep 5,392
Unless your car came with Adaptive shocks which handle a spring drop better. Put your VIN into the mdecoder website and look for an Adaptive line item to find out. When Adaptives leak/wear out the Bilstein B6 Damptronic are a great replacement choice Two standard shocks that work well with dropped springs are Koni Yellow Sport Adjustable (for comfort) and Bilstein B8 (non-Adjustable) Hope this helps! |
06-03-2020, 05:41 PM | #11 | ||
Rep 3,539
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 06-03-2020 at 05:48 PM.. |
07-13-2021, 11:14 PM | #12 |
Rep 420
Would you say the same about the B14s? B16s are B14s w/ electronic adjustable dampering, right?
