BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > BMW 340i B58 VRSF Downpipe DIY :) NO CEL ;) *SOUND CLIP* Stock exhaust+Catless DP
      01-21-2020, 03:48 PM   #67
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
492
Drives: BMW 340i xDrive
Going catted DP from VRSF, still worth it to install the 90 deg spacer while I'm down there anyway?
In a different post I posted I got a comment saying the secondary o2 sensor also affects the Air Fuel Ratio. Anyone running rich or lean because of this?
Anyone do this with a catted DP?
      01-21-2020, 03:49 PM   #68
F30MGM
F30MGM's Avatar
Drives: 2016 340i
Secondary is for emissions. It lets the car know if the cat is efficient
Car List:
2000 328i E46 Steel Gray Metallic 5SPD MT- Sold
2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current
      01-21-2020, 04:25 PM   #69
WrxToBeamerGuy
492
Check out this discussion. It's one of the reasons im questioning messing with the post cat secondary o2.
https://bmw.s p o o l s t r e e t.co...l-needed.4877/
remove the spaces that I added to get to the discussion....
      02-01-2020, 01:56 PM   #70
s55jesus
M Enthusiast
s55jesus's Avatar
438
Drives: 2018 F80 M3 ZCP
  [0.00]
Just got my VRSF catless downpipes installed yesterday from a shop but I'd like to give a big thanks to the OP for the o2 spacer trick. I've driven about 100 miles since then and no CEL.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC
2017 F30 340i (SOLD)
2015 F82 M4 (SOLD)
      02-01-2020, 03:51 PM   #71
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
I Have a decat fitted, standard system but its still not quite loud enough. I love the fact i can make the car louder in sports and quieter in comfort, im thinking rather than cut the mid pipes out and risk drone to fit the remus axle back as it seems to be the cheapest valved axle back about,any one got this combo and fancy posting a sound clip?
      03-07-2020, 10:36 PM   #72
nog0odd3ed@gmail.com
Drives: 2023 X5 40i Msport
Doesn't TX do emissions probe test? Or just ODB2? How do you get away with doing catless downpipe?
      03-09-2020, 11:31 AM   #73
Rangeball_81
Drives: 340i M Sport
Appreciate the guide, I used it this weekend to install a CG catted downpipe. Thanks!!
Shout out to Mike at X-HP for all the advice on which one to buy.
      04-16-2020, 01:25 AM   #74
Stlnation
Stlnation's Avatar
Drives: 2018 x3 m40i
Originally Posted by Solid67 View Post
IIRC HJS and GESI cats are made of metal and can withstand heat much better than a ceramic-based cat which is what's in the VSRF and most of the other brands.
If you intend on having aggressive burbles then you want to go catless or get an HJS or GESI cat. With ceramic-based cats, you will eventually blow them out. If you really don't care about burbles then go with a ceramic-based one.
Which companies use hjs or gesi cats? What do you mean by “blowing them out”?
      05-02-2020, 11:49 AM   #75
F30MGM
F30MGM's Avatar
Drives: 2016 340i
Obd2 so they don't test pipes like California. However this is off-road use only you know what I mean
Car List:
      05-04-2020, 12:03 PM   #76
McBill
Drives: BMW 340i M Sport
Hopefully I'm not thread hijacking here: I'm planning out a mod path for my 340i this summer and a catless DP is on my list. If I get an OTS map will I still need the 2nd O2 elbow in order to avoid a CEL?
      05-04-2020, 06:27 PM   #77
F30MGM
F30MGM's Avatar
Drives: 2016 340i
Actually I deleted cat code but it still comes back saying short circuit to ground aka not plugged in, instead of cat inefficiency so I think maybe yes. Going to put code back and report
Car List:
      05-06-2020, 01:42 PM   #78
Gotobedbro
Drives: BMW 340i
Did you notice any rattle noise with the vrsf downpipes? I heard these downpipes don't come with the clip that uses 2 screws that are on the stock downpipe.
      05-06-2020, 03:06 PM   #79
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
They do now. Any new VRSF DP will have the bracket.
2020 X3M
MG Flasher; Wedge Performance E50 tune
MSS Urban; Rohana RFX11
      05-11-2020, 06:37 PM   #80
HaloF30
Drives: BMW 2016 340i xDrive
i ordered a min ago and had it installed and it rattles but I’ve learned to live with it. I’m trying to see if I talk with vrsf to see if they’re willing to swap it out with the revised version because man it gets to me sometimes I got a nice car but sounds horrible in sport with that ridiculous rubbing
      05-11-2020, 06:53 PM   #81
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
The rattle is from your wastegate, not the downpipe.
If you can post a video of the sound you're referencing along with a screen shot of your order number we'll be more than happy to assist you with the rattle you're experiencing.
      05-12-2020, 12:20 AM   #82
HaloF30
This is one I made once i first had it installed to see if I could fix it and there was no revised dp but now there is .. it’s not that the pipe itself has an issue it just rubs up against the metal side wall of The car because it doesn’t have that small support bracket.
https://streamable.com/ezcq8
      05-12-2020, 07:08 AM   #83
kern417
Cheapskate
4445
Drives: 2018 440i |2016 340i | 2010 X5
If it's rubbing then the downpipe wasn't aligned properly. Loosen the clamps and rotate it. The bracket doesn't prevent it from rattling.
Youtube/Instagram/TikTok: @kern417
      05-12-2020, 07:57 PM   #84
HaloF30
i took it to get installed and even the guy told me that he tried moving it around to get it not to rub but regardless it rubbed and said because it being xdrive there’s more coverage or something under so it rubs. so I just left it as is
      05-12-2020, 07:58 PM   #85
HaloF30
This.
HaloF30, please post a screen shot of your order confirmation so we can verify ownership of the product.
tiago would you like me to send it as a pm?
      05-13-2020, 07:33 AM   #86
HaloF30
Please e-mail us a copy of your invoice so we can trace your order and we'll be more than happy to assist.
sent! Thank you Tiago.
      05-13-2020, 05:07 PM   #87
yokata
yokata's Avatar
Bulgaria
156
Drives: Bmw F30 340xi
I had the same issue with my xdrive ,the guys cut it and re arranged it, but finally it worked out...
      05-13-2020, 06:13 PM   #88
HaloF30
Lmao bro what?! but fr what did they cut?
