View Poll Results: Did you experience timing chain failure on your N20 engine? | |||
Yes, my timing chain failed or required replacement. | 33 | 14.47% | |
No, I have not experienced timing chain failure. | 187 | 82.02% | |
I replaced my timing chain as a preventative measure. | 8 | 3.51% | |
Voters: 228. You may not vote on this poll |
05-09-2020, 11:52 AM | #265 | |||
Rep 126
Drives: 18' 340i ZHP 6MT Melbourne red
18? 340i manual, Mineral Gray over Coral Red leather with aluminum dark carbon trim, MPPSK, M sport, ZTR, Executive pack
18? Individual X5 Mineral/Amaro Brown M sport adaptive m suspension, Executive, drivers assist, drivers assist plus with adaptive cruise 16? 328i xDrive |
05-13-2020, 04:47 PM | #266 |
Rep 221
How do piston rings fail?
| 2018 BMW 330i | 30k Miles | M-Sport Package | Driving Assistance Plus | Premium Package | Executive Package | Harmon Kardon | Active Blind Spot Detection | PDC | Mineral Grey Metallic/Coral Red Dakota Leather |
| 2022 Toyota Highlander Platinum AWD | |
05-24-2020, 03:10 AM | #267 |
Rep 26
Model: 2014 F22 228i
Mileage: 94,000km (58,000 miles) Built: July 2014, West Germany Timing Chain Status: No problems (so far) Oil Changes: Approx every 10,000km. Every 8,000km from now on. Stop/Start Coded Status: Coded off. Additional Details: FBO stage 2 with decat since ~90,000km. Idles rough after startup, but my tuner says this is due to the cold start delete. Unrelated thing that I'm not sure if anyone else experiences, but my car doesn't change out of 1st gear after cold/semi cold start until about 2200 RPM. Not sure if this is normal? If I drive really slowly for a little before taking off though it shifts into 2nd normally. |
05-25-2020, 08:51 PM | #269 | ||
Rep 338
Mine does that too (320ix), i even have the BM3 Trans flash done..
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
06-02-2020, 10:55 AM | #270 |
Rep 34
***HIGH MILEAGE UPDATE***
Model: 2013 F30 328i (N26) Sport RWD Mileage: 110,000 miles Timing Chain Status: Very little play. Minimal marking/scoring on chain Oil Changes: Every 6k with OE BMW Oil. Stop/Start Coded Status: Coded off. Additional Details: I started tuning around 90k miles and have been FBO since 100,000 (Call me crazy for waiting this long but i did it anyways and now ive got a mean daily driver. When I do my next OC (111k), I will be replacing Valve cover and oil filter housing gaskets and will further inspect the TC. Will probably also think about doing the transmission since i plan on making this bad boy hit 200k!! (I recently saw a 209k 2012 328i for sale at BMW so its possible!) Next upgrade will be the MHI Turbo and transition to BM3 from Jb4 Upgrading to FBO seems to be more beneficial for the N20 than a detriment (in my opinion)....granted that you take great care of your car. Let me know if you have any questions. I hope this helps ease the minds of other high mileage F30 owners.
BMW 328i | Injen Intake | ER Charge/TIC Pipes | VRSF FMIC and Catless DP | BMS Oil Catch Can | Muffler Delete | Jb4-Map 2, 93oct |
Silverlining_m21734.50 Ajax91553.00 |
06-02-2020, 05:44 PM | #271 |
Rep 10
2013 328i, no timing chain issues so far, 65k miles, full synthetic every 5-6k miles. Also FBO running stage 2 BM3 if that matters
Silverlining_m21734.50 |
06-24-2020, 11:30 AM | #272 |
Rep 10
I absolutely agree.
This should be an ongoing survey to get a more & more accurate picture of the numbers. I suggested a while back adding more info such as the millage when any failure/preventative-replacement was done too. Would be interesting to see if there's any pattern like where the failed units come from. Or are they all from the same factory? |
06-28-2020, 07:27 AM | #273 |
Rep 51
Drives: 2013 328i xDrive, 2018 X3 M40i
Hey. Last month I noticed a whine on my 2013 328i 71,000 miles build date 9/2012 Took it to dealer and they verified it was indeed the dreaded oil pump chain whine. Contacted BMW NA. Long story short they good willed the whole cost. Worked with Nick at BMW of Schererville in Schererville, Indiana. Very pleased to see BMW step up. The advisor said that the general consensus will be a recall in the near future. He said they have done around 20 this month alone. All my oil changes done at dealer 6 month intervals less than 8k each time except initial one. Auto start stop coded off since 11k Miles. Seems to be hit or miss as far as preventing this issue. Roll the dice it seems.
06-28-2020, 09:56 PM | #274 | |
Rep 103
06-29-2020, 08:05 PM | #275 |
Rep 329
2014 328 N20 engine
Build date 6/2014 Miles 57,200 Chain broke. It’s sitting at dealer. Oil changes done every 6,000 miles or 90 days which ever comes first. Waiting to hear from BMW to see if it covered. Meanwhile I’m driving a loaner |
sspade2464.50 |
06-29-2020, 10:24 PM | #276 | |
Rep 5,456
Drives: F30
Other than the coolant thermostat (relatively common) and timing chain (relatively uncommon) the N20 has proven to be a very reliable engine. Capable of 200k plus with proper care. |
06-30-2020, 03:12 PM | #277 |
Rep 891
I just wanted to pop back in here and make sure everybody knew about FCP's new 2 part timing chain DIY. It is the only DIY that I know of on this job and they really did put a lot of effort into capturing the details. Hope someone finds it helpful!
Part 1 Part 2
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
07-03-2020, 10:03 AM | #278 |
Rep 51
RE: Timing chain
Yeah he said there will likely be a recall in the near future. The cases they have encountered and have gotten covered with vehicles outside of the warranty period seems to indicate that. In addition the failure rate is becoming more prevalent with the vehicles getting up higher in miles. The only thing I see as a barrier is that i don't think its very common for a manufacturer to issue a recall for model years that are that old.
trentr986.50 |
08-11-2020, 03:16 PM | #279 | |
Rep 48
08-12-2020, 09:57 AM | #280 |
Rep 7
Guides failed at 130k kms on my '13 328ix. I recently replaced timing chain and I'm getting 2 camshaft position sensor codes paired with all cylinders misfiring. I made sure that my timing is correct and these codes (being so generic) don't really tell much. Has anyone else faced the same issues? Is it possible thats it's a vanos issue?
08-28-2020, 12:19 AM | #281 |
Rep 39
2013 F30 n26 328i 70,500 miles running bm3 stage 2 with FBO . If I take it in to the dealership to get it diagnosed will there be an issue if I'm FBO and have the tune? Even if I flash it back to stock they'd see the FBO? I'm in CA . I dont hear any whining noises but wonder if I should bring it in to have them check or am I already out of the 70k warranty since im 70,500?
If I do bring it in, I'd be going to McKenna if that matters. I know Charlie isnt there anymore and I haven't been back since he left . |
08-28-2020, 05:34 AM | #282 | |
¯\_(ツ)_/¯
945
Rep 1,762
08-28-2020, 02:21 PM | #283 |
Rep 3
Model: 2013 320i
Build: Munich, April 2013 Mileage: 38k mi (62k km) Timing Chain Status: No problems Oil Changes: except for first oil change at 1400 mi, change interval ranges between 4300 mi and 7100 mi (average 5k mi) Stop/Start Status: Coded off at 16k mi |
08-29-2020, 02:57 PM | #284 |
Rep 39
got it, thanks for the feed back.
09-15-2020, 05:43 PM | #285 |
Rep 40
X1 2013
85600 miles No signs of TC failure Oil changed every 7.5k miles ASS coded off at 60k miles The car drives great, does not burn a drop of oil. Car smokes a bit upon start-up if not driven for several days so it probably needs the updated turbo oil line replaced. My wife loves it and drives it gently so we may just gamble and be vigilant for TC symptoms. |
09-19-2020, 10:25 AM | #286 |
Rep 34
Hi everyone.
I have read that after 03/2015 BMW changed materials used in timing chain system (chain, rail guides etc) and after that, the colour of rails should be white. I just checked mine thru the oil filling cap and its seems that I have old rails because they are yellowish! But my car is produced on 09/2015. Should I be prepared for timing chain replace? I have 80kkm. Kind regards |
