BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Oil analysis element index for B58?
      05-21-2020, 03:36 PM   #1
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
One of my buddies works in an aircraft testing facility and one of the things he can do is oil vaporization analysis. I gave him a sample of some new Liqui Moly 0W40 to burn (listed as baseline) and some used oil BMW 0W20 with about 4000 miles on it. Here are the results.
Has anyone seen an index of nominal ranges of elements for oil analysis for our engines? I'm guessing that one of the responses will be "just send it to Blackstone" and that's fair, but I always enjoy learning things and doing them on my own too.
eksigned I saw that you had uploaded one but it was hosted on a picture site that said it wasn't available anymore
2020 X3M
MG Flasher; Wedge Performance E50 tune
MSS Urban; Rohana RFX11
eksigned139.00
      05-21-2020, 04:25 PM   #2
weehe126
Drives: 2017 340i
You would really have needed to use the same BMW oil for the baseline. I'm assuming you are making the switch to compare to on later changes, but can't really compare the two since they are different oils. Assuming Mo means moly, it is interesting how little the liquid moly has. I am a little concerned how high your iron (Fe) is. That is where the baseline of BMW oil would help.
Supr3me551.00
      05-23-2020, 04:48 PM   #3
eksigned
eksigned's Avatar
139
Drives: 4er
Here you go! Sorry for the delay. Didn't see a notification for some reason. Just happened to stumble upon the thread. lol
G.Newt810.50
Supr3me551.00
      05-24-2020, 05:09 PM   #4
Supr3me
Supr3me's Avatar
Thanks for the input. I'm concerned about the levels as well, iron included- assuming that the units are the same, ppm.
I went ahead and requested a Blackstone kit and will probably try to take an early sample prior to oil change - maybe do a 1500 mile test and a 3K mile test and start establishing a baseline.
At $30/test it seems like a cheap way to figure out if I'm headed for trouble with the power I'm making now.
Wish me luck with trying to pull a little bit of oil without making an insane mess =D
2020 X3M
      05-25-2020, 08:51 AM   #5
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
https://www.bobistheoilguy.com/used-...hat-is-normal/
For the record Blackstone has found no statistical difference with regards to wear rates regardless of which oil was used.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
Supr3me551.00
      05-25-2020, 01:43 PM   #6
Supr3me
Supr3me's Avatar
Thanks, that was a really interesting read. I feel smarder now.
2020 X3M
      05-25-2020, 01:55 PM   #7
G.Newt
Drives: CT4-V Blackwing 6MT
This was super helpful. I use the same oil, and while that's no indication our engines are wearing the same, it's good to hear that the oil is running well for you. Decently high levels of zinc and phosphorus for a non-diesel oil which makes me quite happy.
eksigned139.00
