11-14-2019, 05:25 PM | #1189 | |
Rep 132
Drives: OG M2
M2 - TC Kline DA Coilovers - Apex SM-10s - 265 RS-4s - Dinan Intake - BM3 - CSF Intercooler - VRSF CP
Previous: 6th Gen Camaro SS 1LE | 2020 JLUR Wrangler | F30 340i | B7 Audi A4 APR Tuned | E46 330ci Instagram @track.n.trail |
joeyb26281.50 |
11-15-2019, 10:42 AM | #1190 |
Rep 446
Does running stage 1 91 tune gives you a clutch slip?
Mod bug will bite you if you buy a BMW ================================= |
11-15-2019, 10:54 AM | #1191 |
Rep 248
11-15-2019, 11:38 AM | #1192 |
Cheapskate
4458
Rep 4,995
On the other hand, I have not had any on Stage 1 E30. I've done logging and 2nd gear pulls in the 40F-50F range. 11k miles, RWD, no spin, no fuel cut, no drama.
11-15-2019, 11:37 PM | #1193 |
Rep 152
Drives: 2016 BMW 340i
I have ACN91 gas.
Is it okay for me to use the Stage 1 93 Octane map if I use an octane booster like Boostane Professional? |
11-17-2019, 12:46 AM | #1194 |
Cheapskate
4458
Rep 4,995
Try it, run logs, and report back.
11-17-2019, 01:26 AM | #1195 |
Rep 446
I have couple questions about the BM3 after installing it. I have it on Stage 1 91 octane. Stock downpipe and exhaust.
Due to the high torque, sometimes my front tires lose traction, Is it because of tires or just the xDrive couldn't handle the extra torque ? will doing it often cause any damage to the AWD System? Tires are continental DWS06 with around 5.5" remaining all round Next question, eco pro now produces a lot of burbles. not louder, but just more. I have the settings at OEM. I heard that burbles actually destroys the CAT and is it going to be okay? Thank you!!
11-17-2019, 12:00 PM | #1196 |
Rep 141
I looked through the faq and about 10 pages of this thread, but couldn’t find the answer.
I presume I can go Save As as well to save my current stock tune? I have the MPPSK that I don’t want to lose. Would it be possible to leave the DINAN Elite tune on in bypass mode just to compare before I pull it off? Would love to dyno and compare them both. |
11-18-2019, 06:34 AM | #1197 | ||
Cheapskate
4458
Rep 4,995
Burbles shouldn't damage your cat as long as you don't run custom settings with them turned up too high. OEM is fine. Quote:
Yes it can be run but not really recommended. I'm not sure about Dinan but some people have had unexpected results with piggybacks. Isn't the Dinan just 2 plugs? Probably easier to plug it in for the dyno run, then unplug it again to switch back to BM3. |
11-18-2019, 10:45 PM | #1198 |
Rep 461
Whats up guys,
Can an N55 license be transferred to a B58 vehicle? Or for transferring purposes the licenses are specific to the motor for which they were originally purchased for?
HS S55 F87
MG B58 F30 - Gone MG N20 F30 - Gone |
11-19-2019, 09:52 AM | #1200 | |
Rep 461
HS S55 F87
11-20-2019, 05:49 PM | #1201 |
Rep 4,912
I've been running stage 2 for about 6 months now, with my biggest concerns around winter. Couple points that concerned me:
1) What happens to traction control with the added power? 2) Will really nasty (aka icy days) end in sadness from the extra bottom end power? Over the past month an a bit, I've had the "joy" of driving 15MPH on the freeway (which was still too fast for road conditions due to the ice), as well as multiple other snowy / brutal days. Traction control was flawless (I can get AWD to spin tires on snow though), but the linearity of throttle in comfort is OUTSTANDING. The extra power at the bottom end gets rid of that dead spot where you start hitting the throttle harder, and then it takes off. Now it's perfectly controllable, and felt 100% stable in even the crappiest conditions. Pre-BM3, I used to park it for our Audi SUV since it felt more controlled on those types of roads. HUGE THUMBS UP for this tune with latest mapping. It s harder on tires tough. |
kern4174458.00 azuritschwarz347.50 |
11-21-2019, 07:29 AM | #1202 |
Rep 21
Hi I'm currently running a tune from a local tuner in my home country of Belgium. A few questions for you:
Can I use your application to delete that tune and add BM3? For burbles: will my stock exhaust be sufficient for burble sounds? |
11-21-2019, 04:48 PM | #1204 | |
IG @bmwF9xG80
3813
Rep 7,592
elg0rd0yadigg can help you out
60-130mph 6.5s X4M #HCP
11-23-2019, 06:03 PM | #1205 |
Rep 1,449
I've gotten this twice in the past month. Looks like it's time for a clutch upgrade. This is with Stg 2 91 octane. I'm looking at Spec clutches. Anyone have experience with a single mass flywheel?
[IMG][/IMG]
2022 CT4-V Blackwing 6-speed
11-23-2019, 06:58 PM | #1207 |
Rep 1,449
11-25-2019, 07:52 AM | #1208 |
Rep 775
Yes I had this exact problem. Same error message. I'm stage 2 93 octane. I contacted bootmod and sent them some logs and they made a custom tune that has pretty much eliminated the problem
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
11-25-2019, 08:00 AM | #1209 |
Rep 1,597
11-25-2019, 12:13 PM | #1210 |
Rep 1,449
BMS intake, CG DS-1 5" high-flow catted DP, AWE catback. That's it lol. Just basic FBO.
bm3, bootmod3 |
