08-09-2018, 09:24 PM | #331 |
///M Lover
Rep 15
488 whp / 516 wtq lb-ft
2017 BMW F22 M240i
Colombia F-Series BMW Road Course lap time record! Water Meth Injection, JB4, BMS Billet Intake, BigBoost Stage 3 turbo, Throttle Body Injection! 11.5 @ 204 km/h(126 mph) Map 7 75 additive |
08-09-2018, 09:27 PM | #332 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
08-09-2018, 09:29 PM | #333 | |
///M Lover
Rep 15
2017 BMW F22 M240i
08-09-2018, 09:30 PM | #334 |
Rep 2,601
08-09-2018, 09:31 PM | #335 |
///M Lover
Rep 15
Baseline stock in this dyno was 326 whp /330 wtq
2017 BMW F22 M240i
08-09-2018, 09:47 PM | #336 |
Rep 474
Holy crap, that car is going to EXPLODE!
Looking for 335/n54
08-09-2018, 09:50 PM | #337 | |
///M Lover
Rep 15
2017 BMW F22 M240i
08-09-2018, 10:10 PM | #338 |
Rep 111
What are u doing about fuel running that much at the wheels? If you aren't on meth it does sound like your gonna explode, lol.
08-09-2018, 10:11 PM | #339 | |
///M Lover
Rep 15
2017 BMW F22 M240i
08-09-2018, 10:47 PM | #340 |
Rep 111
Yeah I'm reading more about that on the big boost website. How does it run with the combination of the injection and the tune? Does it feel like power is being lost and how do the AFRs look? Are you monitoring them? I've been considering getting pure turbos but maybe I should be looking in this direction.
08-10-2018, 06:54 AM | #341 | |
///M Lover
Rep 15
2017 BMW F22 M240i
08-10-2018, 10:47 AM | #343 |
Rep 330
Any impressions from the X3 M40i crowd?
TxHornX3M40iGuy128.50 |
08-10-2018, 08:12 PM | #344 |
Rep 57
So for those of us that are risk averse...and want piece of mind while still under warranty...
1) Does reverting back to stock for dealer warranty work and utilizing the "flash freeze" offer a solution in regards to denied warranty claims? 2) Assume my M240i has installed v8.1 of the ECU software and has a file size of 5MB. The "stock" file hosted on MP servers is v.8.2 and 5.2BM or some sort of variance exists. If reverting back to stock has a difference in versions, wouldn't this also be detectable? How does MP ensure that there is a seamless transition to the correct version of software when going back to stock? |
08-11-2018, 12:36 PM | #345 | |
Rep 1,461
08-11-2018, 01:46 PM | #346 | |
Rep 57
Say MP backs up your stock ECU file the day before a dealer visit (is this how its done? each car will have its on file on MP servers?), and then the dealer upgrades your software to a newer version when you get a routine oil change....How would this transition be captured? If you brought your car in for a warranty claim a week later, sure the flash counter would remain the same but the ECU software would not match the new upgraded software (checksum etc.) unless you backed it up again AFTER the dealer visit. |
Rob340i87.00 nzivkovic500.00 |
08-13-2018, 01:11 AM | #347 |
Rep 467
Had a chance to run the car this weekend. I'm still pretty happy with the way the car pulls. Drivability is worlds apart from that good old juice box.
Anyways, side note...does anyone recall what the stock AFR values are? I can't seem to find stock values. Also, can anyone share what their AFR values are on CA 91...on Alex's mFlasher? I saw ~13's, but I have nothing to compare it to. I've run 3 or so tanks of E85 blend (2 gallons), and I'm still just trying to figure out whether or not I'm okay with running it. Oddly, I saw an increase in mileage, but...probably an overall spoof. Car did run a smidget lean on the corn...but again, because I'm new to running E, I don't exactly know what's good, or what's bad? By lean = HIGH 11-12's on WOT. Overall impression? An even cleaner pull (think more effortless on partial throttle) and stronger pulls without a doubt. Thoughts? TIA! |
08-13-2018, 03:55 AM | #348 | |
Rep 2,601
The stock tune runs super lean, around 15:1. |
eksigned139.00 |
08-13-2018, 04:12 AM | #349 |
Rep 1,693
08-13-2018, 01:18 PM | #352 | |
Rep 631
Different engines (naturally aspirated or forced induction) run better on different AFRs. But for the turbo engines like ours, AFR is vital along with boost pressure, timing, and air temperature because all of that ultimately equates to how efficient the engine is running and how much power it will be able to produce. |
chenry2361.00 WolfGTI717.50 Neneonline5.50 sangy33538.00 Napster84612.00 Beek707.00 eksigned139.00 Bmw doubles983.50 |
