01-01-2014, 01:38 PM | #24 |
Rep 949
Here, this shows how it works and more found at the link below
http://www.bimmerpost.com/goodiesfor..._Dynamics1.pdf |
01-02-2014, 05:00 AM | #26 | |
Rep 976
01-02-2014, 05:26 AM | #27 | |
Rep 949
However, I've tried to get my adaptive suspension to do this but don't notice it i.e. I've been in comfort then started to drive more aggressively and I don't feel the chassis tighten up. If I flick the switch to sport, yes, it makes a massive difference. |
01-02-2014, 05:42 AM | #28 | |
Rep 976
01-06-2014, 02:47 PM | #29 |
Rep 589
ASS still activates in Sport mode in mine - not tried it with the lever to the left mind
F36 435D M Sport + Glacier Silver
Gone F30 320D 8AT M Sport Mineral grey Gone E92 320D M Sport Sparkling Graphite Gone E46 320D M Sport Silver Grey |
01-06-2014, 02:57 PM | #30 |
Rep 11,292
Yes I realised this! Put it into Sport and it still cut out at the lights!
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
01-06-2014, 03:09 PM | #31 |
Rep 347
01-06-2014, 03:19 PM | #32 | |
Rep 3,983
Eco Pro - never use as nothing your right foot and a little common sense can't better Comfort - ASS on (I could disable altogether with coding but I don't mind it), suspension on comfort, steering light and normal throttle response (2nd turbo takes a while to spool). Sport - all that changes is suspension stiffens and steering gets heavier. Drivetrain still the same. To be honest, for most scenarios of fast progress, with the torque of 335d, this is fine. DSC and reaction behave as in Comfort Sport + - as above with Sport but also now mapping on throttle response changes dramatically with 2nd turbo spooling pretty much immediately. DSC is now relaxed a little allowing you a reasonable slip angle before coming into play. Gearbox will tend to be in one gear lower at all times. Gearbox D - you can at any point manually change but if left, the gearbox will go back to D. Gearbox S - will drop down a gear lower (so if you're in Sport + that'll be two gears lower). Main advantage is now it will not go back to auto when you use paddles. Only REALLY annoying thing is if you kickdown, if it can change down it will. It shouldn't do that as could really leave you in shit in on limit (yes I know naughty to suggest on queens highway). Have to consciously never go past kickdown point. DSC off - on adaptive will chose sport suspension and steering. you can also knock gearbox into Sport. However it will NOT put drivetrain into Sport which is a shame. Suppose most will never really turn DSC off but it is a shame. Apart from that and fact that gear shifts are unnecessarily thumpy in sports gearbox modes (oh and the kickdown issue), it's not half bad. Hope that helps!
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
01-06-2014, 05:02 PM | #33 |
Rep 1,919
Thanks for this gtsussex. Although I'm still not sure what boxes I should tick in sport setup??? Sorry for being dumb but what actually happens/changes if I untick a box??? Is it that noticeable? I'm only at 900miles so still being a tad cautious!
I have adaptive btw... |
01-06-2014, 05:09 PM | #34 |
Rep 11,292
Great description Guy of the different modes.
However, doesn't just Sport mode give a better throttle response? Else this mode would do virtually nothing for the guys who have no adaptive? I thought Sport mode does seem a little more responsive, to me.
01-06-2014, 05:13 PM | #35 |
Rep 11,292
And does Sport+ mode change down the gear, even if Sport is configured for chassis only? (I must admit, not played around with Sport+ that much!)
01-06-2014, 05:19 PM | #36 |
Rep 653
The drivetrain is only the same in Sport if you've turned changing it off, surely?
Also you can tell what the steering is like with the electric steering off as it gets disabled when the engine cuts out with ASS. I noticed this when stopped at some lights and I guess tried to turn the wheel a tad as I took my foot off the brake as used to my old 330d starting to roll instantly but the engine hadn't quite kicked in. |
01-06-2014, 05:21 PM | #37 |
Rep 185
The air intake is set very low, so going through puddles could cause up to £12k of damage to your 6 cylinder engine if it sucks up plenty of water popped into my local dealer the other day, after the recent floods they had 5 f30's in with lunched engines, so take it steady
01-06-2014, 05:27 PM | #38 |
Rep 347
Yes, on mine sport gives a more immediate/linear throttle response. Easy way to check is to switch to this mode when you are driving with a light throttle and the car lurches forward.
01-06-2014, 05:28 PM | #39 | |
Rep 347
01-06-2014, 06:11 PM | #40 |
Rep 386
Going to ask a really stupid question but how do you alter the setting for sport mode etc ? To set it to chassis or transmission etc?
I haven't had chance to play about with all the menus yet! |
01-06-2014, 06:25 PM | #41 |
Rep 347
There's a button nr the gearstick which switches the mode from Eco Pro to Comfort to Sport to Sport +.
If you want the gearbox in sport mode, just push the gearstick to the left. |
01-06-2014, 06:34 PM | #42 | |
Rep 11,292
Chassis Only OR Chassis and Drivetrain I cant remember and I'm not digging out the handbook this time of night!
01-07-2014, 01:44 AM | #43 |
Rep 386
Yes this is what I meant! I had a quick look on the iDrive this morning but couldn't see anything. I don't have the handbook to hand at the minute.
01-07-2014, 02:53 AM | #44 | |
Rep 3,983
Some like having the drivetrain ticked so it drops a gear and has sharper throttle response. If you've ticked it, will also stop ASS. I find with the 335d, I've got so much torque that it's unnecessary and I only want the dampers and steering to firm up. I can still make indecent relaxed cross-country progress. I then leave Sport + for playtime so for me that's when the drivetrain changes. Combined with fact DSC is relaxed, car takes on a whole new persona and my driving changes accordingly so it's kept for special occasions (usually wet roundabouts ) Everyone has their own preference. One thing to note for people without options ticked. If you don't have variable steering, this won't change regardless of what you press. If you don't have adaptive suspension, the damping will not change either. All that will change when you hit the Sport button is the drivetrain (lower gear and sharper throttle response). The difference then between that and Sport + would be the relaxing of the DSC. The gearbox settings then remain totally separate. Go manual in D regardless of what mode you're in and if you leave it, it will go back to D. Go into Sport Auto, it'll drop a gear relative to mode you're in and it will hold gears EXCEPT frustratingly it will kickdown if you press down hard enough and there's room to drop a gear (which often is if you're riding torque and short shifting in slippery conditions).
