09-21-2021, 09:37 PM | #23 |
Rep 139
Drives: '20 BMW F87 M2C
I've heard many people mention this about coils.. I don't see how they can be messed up by having them removed and just plugged back in. Are they that finicky/sensitive?
09-21-2021, 10:18 PM | #24 |
Rep 2,357
Quite the statement - where have you heard this? You mean actually "deleting" codes - like JB4 did on the de-cat CEL or running with a de-sensitised knock control?
(A Dane in China) |
09-22-2021, 12:13 AM | #25 |
Rep 7,602
Old ones are, yes... some people even have them break apart while pulling them out, like part gets stuck on the plug. Depends on your miles and the live your car lived (harsh winters, etc).
09-22-2021, 12:39 AM | #26 | |
Rep 7,602
However, these are the three most recent examples i could easily find: https://f30.bimmerpost.com/forums/sh...uppress&page=5 https://f30.bimmerpost.com/forums/sh...light=suppress https://f30.bimmerpost.com/forums/sh....php?t=1830137 Unfortunately these all come up in individuals threads, flashing back to stock reveales the issue, and the problem is solved so the thread dies off and never gets seen again. So, it's not deleting codes - either preventing them entirely or at least decreasing the sensitvity to them coming up. |
09-24-2021, 08:29 AM | #27 |
Rep 139
I'll plan on flashing back to stock to see if any codes come up. Will report back.
I'd rather have a code pop up and tell me exactly which cylinder I'm having issues with, that way I can pin-point the problem and not waste time changing out everything. |
09-24-2021, 01:33 PM | #28 |
Rep 139
Alright, here's an update, and not a good one:
Flashed back to the stock tune w/ the NGK plugs still in the car. Drove around for a bit and did some pulls. No stutters, no misfires, no codes. Decided to try and flash back to the BM3 Stage 2 93 Octane tune that I was running previously. Did that, and went out, did some pulls, and the stutters/jerkiness came back while accelerating hard. Still no codes. I think tomorrow I will go back to the old Bosch plugs and see if there are any issues. |
09-25-2021, 03:05 PM | #29 |
Rep 139
This has been more than frustrating at the very least. I tried the following troubleshooting steps but no luck:
1. I double-checked all of the NGK plugs and ensured I gapped them correctly and retorqued them to spec (17 ftlbs or 23 NM). Still had issues. 2. Switched out the plugs with the OEM Bosch plugs, and the issues seemed almost worse. I'm now wondering if I have a boost leak, and/or if the initial jerk of the engine when I first installed the plugs knocked something loose, or something entirely different. Last edited by okla_m2c; 09-25-2021 at 03:14 PM.. |
09-25-2021, 03:10 PM | #30 | |
Rep 23
09-26-2021, 11:52 PM | #32 | |
Rep 7,602
10-28-2021, 11:58 PM | #33 | ||
Rep 23
10-29-2021, 12:24 AM | #34 |
Rep 7,602
Might need to reset MAF adaptations or something due to air filter.
11-02-2021, 08:59 AM | #35 |
Rep 139
Changed the coils and flashed to Stage 1 instead of the Stage 2 tune.. stuttering seems to be gone now.
I was having issues with trying to datalog with BM3. For whatever reason, the logs just wouldn't save (I tried the online and offline modes). All of this may be a mute point.. I've been eyeing an M2C and looking to upgrade.. |
01-09-2022, 05:36 PM | #36 |
Rep 664
Drives: 2013 BMW 335i
I can run XHP tran tune along side bm3? What stage XHP do you run? Do you use BM3 or MHD?
01-10-2022, 11:23 AM | #37 | |
Rep 7,602
I run MHD and XHP stage 3 |
02-24-2022, 06:44 PM | #38 | |
Rep 23
The mechanic said my diff is howling, so it could be the culprit to the grinding sound I was hearing in RWD. Maybe the diff is trying to lock up which causes the stutter??? idk |
02-25-2022, 01:03 PM | #39 | |
Rep 7,602
No idea about your grinding sound, and don't know what you mean about "trying to lock up" |
02-26-2022, 07:02 AM | #40 | ||
1296
Rep 3,533
02-27-2022, 05:47 PM | #41 |
Rep 7,602
02-27-2022, 06:42 PM | #42 |
1296
Rep 3,533
You're almost missing out but don't blame you!
bm3, hesitation, n55, stutter, xdelete |
