02-19-2020, 09:02 AM | #23 | ||
Rep 5,391
I believe the Xdrive transfer case is a bear because you need a very thin tube to get past the stuff in way and if you are lucky you will remove about half of the fluid through suction. It's fine to mix old and new. But it may be a good idea to do that one more often to have more new than old in the mix. It's important to keep track of how much fluid you have removed so you have an idea of how much has been replaced. Been getting my fluids from FCP Euro. All BMW labeled fluids except for transmission fluid. I use ZF made by the transmission manufacturer, ZF. I always replace my drain and fill plugs with Dimple plugs which has a really strong magnet to pick up any fine metal particles that would cause internal damage. It's something like $30 a plug but that's cheap insurance on a very expensive engine. Hope this helps! |
02-19-2020, 02:07 PM | #24 | |
Rep 923
Lifetime fluids? tsk BMW! I guess I'll get a vac pump of some sort because I'd like fresh fluid. It's weird bmw calls for different hyploid oil in front and rear diff...and that I saw only one liter of fluid in transmission (manual). Does that seem right? Anyway, haven't ordered fluids yet. Plugs and oil are up next.
02-19-2020, 03:37 PM | #25 | ||
Rep 5,391
02-19-2020, 04:24 PM | #26 | |
Rep 923
I've used fcp for years and years...always been great in every way! I'm going to study up on fluids, but I'm disappointed that finding capacities for things is not easy. At $2xx/hr., I'm not surprised bmw wants to support its dealer network.
02-20-2020, 01:13 AM | #27 | |
Rep 118
02-20-2020, 05:43 AM | #28 | |
Rep 923
'We're' just coming out of warranty, so suspect more parts will come as we need them, though I also suspect fewer will be diying the f30 than the e46. This is a frightening looking engine to work on--I nearly cried when I saw the diagram of our 20 cooling hoses and four radiators.
12-02-2020, 06:48 AM | #29 |
Rep 923
I'm getting my $400 worth of OEM fluids soon...have a mityvac...ready to change out my fluids underneath--
Any tips? I'm sure they should be warm when draining...will I be able to do all the fluids at once you think and get them all out warm-ish? I'll be working with it up on jackstands...with a friend operating the mityvac. If you notice I don't have the right amount of fluids, please let me know--I'm going off of realoem quantities: 2L MTF LT-5 1.5L G1 Hypoid Diff Oil .5L G2 Hypoid Diff Oil 1L DTF1 Transfer case fluid I also have the diff fluid extractor adaptor (bent brake line pipe) and extra plugs. Will I need to remove any or all underskirts?
