BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Bootmod3 Stage 2+ E30 octane maps for N55-EWG are now available!
      07-08-2021, 11:49 PM   #353
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Originally Posted by ctt300 View Post
I hear what you guys are saying...haha, but ran him twice with same exact results. Only thing I can think of is that he let his dct auto shift and ran past the shift points that are ideal. I have my shift points set to 6000 in XHP, so that is perfect. I also ran it in comfort mode in dynamic traction mode and trans in D, not even S. I bet I'd do even better in sports mode and S..
All I know is that this thing is a rocket.
Edit: found this on M4 shift points from https://f80.bimmerpost.com/forums/sh...251&page=2
Shift points
https://f80.bimmerpost.com/forums/at...8;d=1535475967
listen.. my car doesn't run anywhere near that mph and I can guarantee I'm faster than you
congrats on your wins though! I beat cars all the time that I have no business beating
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      07-09-2021, 07:01 AM   #354
ctt300
Drives: F30 335i
I hear you! I'd love to see you run this Stg 2+ E30 map or the Race one and run cars on your YT channel to see how it does.
I'll also try to get more runs in.
n55david1295.50
      07-09-2021, 07:18 AM   #355
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
it's not really any different than my tune tbh. nearly identical till higher rpm then my map has way more timing.
if I could find my damn dragy I would do some comparison runs. I know the e30+ map is a good power map.. its just not a 127mph map
      07-09-2021, 06:12 PM   #356
jq_f22
Drives: BMW M235xi
Shift points
I hear you but even then, it sounds like you ran a stock tune or comp tuned m4. Best I ever trapped with e30+ race gas was 120mph.
IG @jq_f22
      07-09-2021, 06:14 PM   #357
jq_f22
Drives: BMW M235xi
Have you used the custom dragy slip feature? You can setup 40-100 or whatever. Could be fun to have virtual races among the forum members haha
IG @jq_f22
      07-09-2021, 06:15 PM   #358
jq_f22
Drives: BMW M235xi
Ots+ also overboosts the stock turbo on the top end😉
IG @jq_f22
      07-09-2021, 09:39 PM   #359
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
I've never messed.woth it since those roll times never really mattered to me. also much much more difficult to do where I live.
once I find my dragy, been looking for weeks I will do some.
      07-09-2021, 09:40 PM   #360
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
yeah, Cary let's my boost fall off at around 6k and I get a ton of timing. I would still be curious to see the time difference.
      07-10-2021, 07:57 AM   #361
ctt300
Drives: F30 335i
I talked to the guy and we were talking about our mods...he said his tune was BM3 Stage 1 93 Octane.
      07-10-2021, 08:04 AM   #362
ctt300
Drives: F30 335i
Find that dragy man! and also get some runs in against others with both tunes.
Yeah, no way that fast mph. Something either amiss with his tune or gas used or my car is a freak. Or the race gas tune with E43 is really nuts. Will have to get a dragy or take it to the drag strip.
I have flashed back to stg 2+ E30 with E45 in the tank and it feels just as powerful.
      07-10-2021, 09:38 AM   #363
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
I just doubt his car is that fast tbh.. likely he has no idea and just raced someone or read something about some car should run that fast blah blah blah.
you're car isn't a freak, he's just not as fast as he says.
yeah, wish I could find the damn dragy... no idea where it's at
      09-26-2021, 02:14 PM   #364
motivman
Drives: 2022 G80 M3 6MT
Just wanted to add some data to this thread, if anyone cares... comparing power difference between the stage 2+ e30 tune and the stage 2 E30 tune. My car is an M235i 6MT, full bolt on, with dorch stage 2 fuel pump, stock exhaust, stock turbo, turbosmart diverter valve, MST inlet, and stage 2.5 LPFP (a useless upgrade tbh if not running full 85)... anyways, these are my numbers
Stage 2 E30 ----- 392whp, 442wtq
Stage 2+ E30 ---- 415whp, 466wtq
dyno map shows stage 2 E30 held the power to redline, but there was a massive drop off in power for stage 2+ after 6k rpm, so basically with the stage 2+ tune, shifting should be done at or around 6k rpm...
the Garage was super hot (over 100F) when I did the dyno, and car was running stock bosch plugs at 0.022 gap, a little disappointed with the numbers honestly, would liked to have gotten maybe +10 whp more on both maps, but oh well.
      09-26-2021, 04:45 PM   #365
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
turbo is done on a stage 1 tune at 6-6200, it's just can't flow the air efficiently enough to make boost. it's too small.
      09-26-2021, 09:51 PM   #366
motivman
yup, looks like 415-425whp is the absolute best the stock turbo can do with the stage 2+ E30 map on the regular N55, M2 maybe a little bit more... next upgrade is pure stage 2 for sure... my goal is 500whp, and I know this map can get me there... I am also having issues hooking up in 3rd gear with like new pilot sport 4s tires, so looks like LSD is in my future too.
      09-26-2021, 10:43 PM   #367
ZM2
Drives: 2017 LBB M2
Stock turbo M2 with decat on the 2+ map will hit 442+ whp on a Dynojet, but chokes hard above 6k. Redline hp is 375ish if IIRC.
Even with my Dinan turbo (and 300-cell DP) I hit the same peak whp, but drop to 410whp at redline. Altho, the fun part is 507wft-lbs at 2500rpm….
Currently looking at a TTE460 to smooth out up top. Thinking I can hit 475whp peak with a big jump in redline whp (50ish?) while not introducing low end lag. We’ll see.
      09-27-2021, 09:08 PM   #368
motivman
doesn't the M235i and M2 have the exact same engine and turbo? how is the M2 making 29 more whp than my M235i? was running the stock bosch plugs robbing me of some power? will I make more power with the N20 plugs?
      09-27-2021, 11:13 PM   #369
ZM2
Drives: 2017 LBB M2
Nahh. There’s some talk that the M2 turbofold flows more, but no one knows for sure….
      09-28-2021, 12:04 AM   #370
AmuroRay
AmuroRay's Avatar
2268
Drives: M235i
Hard to say what happened without a log or graph, but I imagine timing being pulled could have caused some issues up top.
Can you post them?
      09-28-2021, 12:49 AM   #371
thejeremyman9
thejeremyman9's Avatar
4362
Drives: 2015 BMW 335i
Can you post them?
That or its just a different dyno, or dynos had different WCF, etc etc. Can't compare different cars on different dynos on different days unfortunately.
      09-28-2021, 01:00 PM   #372
motivman
here is the dyno, was done on a dyno dynamics dyno....
red is Stage 2 E30
green is Paul Johnson Custom tune E50 (very disappointed honestly)
Purple is Stage 2+ E30
View post on imgur.com
AmuroRay2267.50
      09-28-2021, 01:09 PM   #373
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Currently looking at a TTE460 to smooth out up top. Thinking I can hit 475whp peak with a big jump in redline whp (50ish?) while not introducing low end lag. We'll see.
it just has more boost through the tune
      09-28-2021, 01:19 PM   #374
thejeremyman9
4362
red is Stage 2 E30
Interesting that the stage 2 holds power better up top. Do you have datalogs for these runs?
Also what correction factors were used for weather, etc? If none what was the DA? So many variables like i said, can't really compare dyno results like that (different cars/days/dynos/etc)
