08-22-2021, 01:42 PM | #1 |
Rep 130
2014 435i Xdrive staggered wheel/tire feedback
I have a 2014 435i Xdrive. I wanted feedback as I need new tires. I have run Conti DWS06 tires on an F25 X3 35i and on my 2016 750i Xdrive with great luck. I live where it snows and although I use my truck on days where I can catch snow storms, I still need decent all season snow tires (not dedicated) for those times I get stuck having to drive in those conditions.
Current setup: 20x9.5 - 225/35-20 front 20x10.5 - 265/30-20 rear There is a good 1" clearance front and rear to the any rubbing issues, so I know that the new sizes will clear. Looking at this setup on the same wheels; 245/35-20 front and 275/30-20 rears on Vredestein Quatrac Pro tires. I see that there is a slight difference with the new front tire diameter at 679.5mm vs 673mm rear, or a .97% larger difference. I think that is ok for Xdrive? I qualify myself as pretty good when it comes to wheels and tires but would value any feedback from those that wish to chime in! Thanks in advance
Current: G01 X3 M40i (Carbon Black / Black Vernasca, Blue stitch Leather), E89 Z4 35i (Alpine White / Kansas beige leather), Ram 1500 Limited 4x4 (Black / Black leather), 2004 Honda Goldwing - Previously owned BMW's: E36 M3, E46 330i, E46 M3, F25 X3 3.5i M Sport, G12 750ix M Sport, F32 435i xdrive M Sport.
08-22-2021, 07:29 PM | #2 |
Rep 4,329
285/30/20(26.7")
275/30/20(26.5") 245/35/20(26.8") 235/35/20(26.5") what are the wheel offsets? if your front offset is too low a 26.8" tire will rub the fenderwell liner at full lock if the offsets are reasonable, why not run equal diameters for x-drive? i've seen people with 26.8" and even 27" on F3/4 series. while i understand your desire for increased sidewall for ride and impact, taller gearing, increased rolling resistance and weight reduces performance. if that doesn't bother you and you're happy, i'm happy. 245/35/20 275/30/20 is 1% difference, it's ok for x-drive but same diameters is better for x-drive if feasable. . Last edited by alohasurftoad; 08-23-2021 at 09:12 PM.. |
08-23-2021, 08:41 AM | #3 | |
Rep 130
Offsets: I have not had the wheels off the car yet, so I am not aware of what the offsets are front and rear. I measured (rough but pretty confident) the widths of the front and the rear. I will check offsets before I order, from the looks of it, front rubbing should not be an issue, I spot measured with left and right lock to lock to see the clearance and I have finger + clearance. Performance: While I fully appreciate "performance", this is a street car and I will not track the car either. The minimal performance drop due to gearing, weight, etc. is not something I am concerned with. Should that come up in the future, I would purchase some light weight 18's with performance tires to swap out if needed. 1% difference: The two tires I am looking at do not offer a 235/35 front, or a 265/30 rear option.
08-23-2021, 08:55 AM | #4 | |
Rep 130
08-23-2021, 10:15 AM | #6 | |
Rep 130
Will for sure do that. I will pull the wheels this week to get the full specs and report back. Thanks so much!
alohasurftoad3078.00 |
08-23-2021, 10:47 AM | #7 | |
Rep 611
As mentioned already by alohasurftoad, firstly find and share the exact parameters of your wheels; offsets are crucial, and nobody can tell without this information.
245/35/20 & 275/30/20 is perfectly fine for x-drive. In terms of overall balance, it is the best staggered setup I have tried yet. Due to the small difference in width of your front/rear wheels, the fronts will be a bit more stretched resulting in even a bit less of overall diameter difference than usual. Quote:
However, the final fitment (and if the tires will rub or not) on the same chassis depends on a combination of two things: - wheel size: width+offset, see above, - tire make/model: different tires are physically different in profile, and width, no matter the same specs on paper. Haven't seen these Vredesteins fitted, but typically Vredesteins are pretty narrow (slightly reduces the risk of rubbing the fenders/fender liners) btw, expect the Vredesteins to be very heavy, with high rolling resistance, especially when compared to Goodyear/Michelin/Continental. Last edited by J555; 08-23-2021 at 10:59 AM.. |
08-23-2021, 12:43 PM | #8 | |
Rep 130
Thanks for your input on the sizes (245 / 275)! I looked up the weights of the tires reported on TireRack for the 245/35-20 and 275/30-20 for three different tires. Can weights on TireRack be considered accurate? Conti DWS06 Plus: F:24lbs, R:24lbs Quadtrac Pro: F:24lbs, R:27lbs Pilot Sport All Season 4: F:24lbs, R:27lbs Love your details on different tires and their different profiles.....Appreciate that! You all are extremely helpful....Thanks to all!
alohasurftoad3078.00 J555568.50 |
08-23-2021, 08:41 PM | #9 |
Rep 130
OK, wheel specs are in:
Front: 20x9 ET35 Rear: 20x10 ET40
08-23-2021, 08:51 PM | #10 |
Rep 4,329
you can do 245/35/20-285/30/20(or 275/30/20). 275 will give you better clearance but 285 has negligible reverse rake diameter stagger, closer diameter difference and retainment of that difference for x-drives, since rear tires wear out faster.
. Last edited by alohasurftoad; 08-23-2021 at 09:01 PM.. |
J555568.50 |
08-23-2021, 09:17 PM | #11 |
Rep 130
You rock, good stuff!!! My tire preference would be the 275, second choice would offer the 285 option. SO......is the 285 that much safe a bet to run then the 275 due to Xdrive, transfer case and overall diameter being that much closer?
08-23-2021, 09:29 PM | #12 |
Rep 4,329
J555 is running 245/35 & 275/30 (0.97%) on his xdrive without problems so it's safe.
personally, if i had an xdrive, for 245/35 front, i would do 285/30 rear because i prefer closest to zero diameter difference and don't care for reverse rake diameter stagger. but then again i wouldn't be running that far over OEM anyway and would have done 235/35 & 275/30 at most. post pics after they're installed. |
J555568.50 |
08-23-2021, 09:42 PM | #13 | |
Rep 130
08-24-2021, 05:13 PM | #14 |
Rep 611
The 245/35+275/30 is perfectly fine, it is also a factory setup for some same and newer generation models. Indeed, I agree with alohasurftoad that getting as close in diameters as possible (235/275 or 245/285) is certainly a good idea for the transfer case protection. I went for 245/275, as I want the widest front tires (for front grip and steering feedback/feel), less difference in width between fronts and rears to reduce the understeer a bit, and reduce the risk of rubbing.
With 20x9 ET35, you'll be fine with 245/35. As mentioned before, depending on the tire and your car, you may have a slight rubbing in front of the fender liner at partial lock. I see that on most cars running similar diameter, usually you cannot even hear it, and disappears completely with wear. With 20x10 ET40, it ain't that simple - at least not on F31. While I haven't found any such mention before, both 275/30 different tire models fitted to my 20x10 ET40 rubbed a bit the fender (under load when hitting moderate bumps). That was the case both on stock, and lowering springs (with EDC) with full alignment done. After all, it was not a big issue, as the fender just shaved a tiny bit of rubber at the edge, and have no rubbing anymore. I am glad I haven't tried the 285 instead... While the F32 is a bit different, I can only suggest performing some additional research on the F32 stock (!) suspension fitments of this exact combination. |
08-25-2021, 08:30 PM | #15 | |
Rep 130
09-25-2021, 11:40 AM | #16 | |
Rep 130
Front: 20x9 ET35 / 245/35-20 on Vredestein Quatrac Pro tires. Rear: 20x10 ET40 / 275/30-20 on Vredestein Quatrac Pro tires.
