BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Eibach ARB's with EDC + lowering springs
      08-26-2021, 11:04 AM   #1
J555
Drives: F31 LCI 340iX
Guys, I consider upgrading the ARB's and looking for a real-world experience of somebody with a similar setup and upgrade path... While my garage recommended the H&R ARB's, based on the comments here on being too stiff in the rear I consider going Eibach.
Can you share your experience with Eibach ARB's on M Sport EDC (adaptive) LCI x-drive with AC Schnitzer or Eibach lowering springs, please? As the car is a daily driver, I am interested to hear both the subjective benefits in terms of handling and the impact on ride quality?
      09-01-2021, 04:18 AM   #2
gds
gds
Greece
Drives: bmw 320i ed 2016
I installed Eibach ARB (and Koni sport with normal msport springs ) in my 2016 F30 LCI 2 months ago and i am very satisfied. The body roll is signficantly reduced , the feel of the steering wheel is better , the handling in windy roads is better too and the greatest imporvment is in the high speed stability and in the side wind sensitivity .
The comfort is not affected (maybe 10% less comfortable in really bad roads at low speeds but still better from my previous coilovers). The car is more planted and i think that that the ARBs is the best modofication ihave done to this car. Ι think that the car should have these ARBs as new , especially the sport -msport variant.
J555568.50
      09-02-2021, 10:30 AM   #3
J555
Many thanks for sharing your experience! While your setup is very different, it is helpful to hear the change you notice after upgrade to these ARB's!
      09-15-2021, 04:53 AM   #4
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
Sorry, what is LCI?
And, with this new Eibach setup are you still able to switch between comfort, sport, sport+ via the console button?
      09-15-2021, 06:11 AM   #5
gds
gds
Greece
LCI stands for Life Cycle Impulse or, in more basic terms, mid life cycle refresh or the facelift for the f30 model after 7/2015 .
With the Eibach ARBs you are still able to change the driving programmes without problem.This modification is clearly mechanical and does not affect the electronics of the car.
      09-15-2021, 11:02 AM   #6
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
Very cool! Thank you!
      09-17-2021, 05:10 PM   #7
J555
Exactly, and the reason I included it in the question is the stock ARB's should be different for pre-LCI cars.
btw, I ordered them, and report back, when installed
      10-29-2021, 12:18 PM   #8
Tommi_Mav
Greece
66
Drives: F32 435dx
In your case (F31), there are LCI and pre-LCI models with exactly the same ARBs, depending on the engine version. Check realoem.com.
