07-25-2018, 10:32 PM | #1 |
Rep 6
Taking car to Indy while under warranty
Does taking a CPO vehicle to an Indy shop for maintenance have implications on the CPO warranty? I read somewhere on the forum that repairs at an Indy do not get reported to BMW so if later, a repair under CPO warranty is needed, can they complain that proper maintenance on the vehicle was not performed?
07-25-2018, 11:21 PM | #2 | |
Rep 1,452
07-26-2018, 01:55 AM | #3 |
Rep 2,499
If the work was done properly, there is no way it can affect your warranty in any way. Maintenance or repairs can be done at home, at an independent mechanic, or by your mother. As long as the repairs are done properly and don't cause further damage to your car, it won't affect any warranty at all.
Of course, that doesn't stop shady dealerships from saying otherwise, but it's rare that they stick to their guns about that. That's just something they say to scare you into going in for service at the dealership. I plan on doing most of my own maintenance now that my free maintenance is complete. Just make sure you reset the counters on the car when you do the maintenance and also make sure that you keep a record of all the service you get, whether it be from an indy, from the dealership, or DIY. There doesn't need to be any official record of service being done to get warranty service. If they refuse warranty service because they claim you didn't change your oil for 3 years, then they have to prove why they think you're lying about it. Unless there's sludge in your engine, it'd be virtually impossible to prove something like that. Also, don't lie about anything. Even one small little lie will make them very suspicious about everything else you say. |
speedbird1922.50 Bobolat1.00 |
07-26-2018, 12:31 PM | #4 |
Rep 1,572
For maintenance that I do at home, I have a spreadsheet that tracks dates,mileage, parts, etc for each task, I also scan all receipts for parts, fluids used.
07-26-2018, 02:25 PM | #5 |
Rep 14,115
Drives: G82 M4C X-Drive
Do you still get a loaner for CPO maintenance work? If so, it's worth the premium IMHO to go to the dealer.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
07-26-2018, 02:40 PM | #6 |
Ex-Lurker
23
Rep 29
I believe so because I got a loaner when I had my CPO F32. I think it's up to each dealer too because my local one has a rule that it only offers complimentary loaners if you bought the car from them.
07-26-2018, 08:46 PM | #7 | |
Rep 6
07-27-2018, 01:23 AM | #8 | |
Rep 2,499
07-27-2018, 09:03 AM | #9 |
Rep 4,446
Drives: '23 X1 28i xDrive
07-27-2018, 09:15 AM | #10 | ||
Rep 560
07-27-2018, 09:47 AM | #11 |
Rep 5,993
I keep all my paperwork anyway. Sometimes what's stored on the keyfob isn't accurate. In case they claim an oil change wasn't performed I have the paperwork showing it was done at the dealer so it's not my fault if it wasn't actually done.
07-27-2018, 12:38 PM | #12 |
Rep 1,487
Drives: 2108 X3 xDrive30i
Just curious...why take it to an indy? If its CPO wouldn't you rather have it serviced at a BMW center in case they find something that they could repair under the CPO warranty?
07-27-2018, 01:29 PM | #13 |
Rep 6
Under CPO warranty but not under maintenance plan. Trying to save money by taking to indy.
07-27-2018, 01:29 PM | #14 |
Rep 4,446
You are still paying more money for service at the dealer. If an indy flags a problem, you can tell them "Don't fix it. It's under warranty." Just like any other car that doesn't offer complimentary maintenance.
07-27-2018, 02:44 PM | #15 |
Rep 1,487
You are right. They do charge more. Sounds like you have it covered. Like I said...just curious. Thanks...
07-27-2018, 09:28 PM | #17 |
Rep 1,452
07-28-2018, 05:49 PM | #18 | |
Rep 884
07-28-2018, 06:09 PM | #19 |
Rep 4,446
You can imagine it all you want; they give it. Same for the Lexus dealer before I had my BMW. And the Lexus dealer had pickup/delivery of the loaner within a 60 mile radius. Any service, as long as you scheduled 2-3 weeks in advance, because they only had 2 drivers per day.
07-28-2018, 06:10 PM | #20 | |
Rep 4,446
07-28-2018, 11:07 PM | #21 | |
Rep 2,499
The thing about hiring a lawyer is that the more BMW dealerships there are, the more expensive lawyer rates are likely to be. So if you don't have the option of going to another dealership for warranty work, most likely the lawyers in your area are much cheaper anyway. Also, most lawyers in the auto fraud industry don't require a retainer and will work with you if they think you have a case. True, if it's a small repair, it's not going to work out most likely, but then it's also probably not a big deal. Most people aren't going to be broken up about a $500 repair. If it's a $10k engine replacement, then absolutely it's worth hiring a lawyer. For the amount of money I save by doing my own work, I've definitely saved enough money that I can afford to deal with the occasional B.S. or hiring a lawyer if necessary although I've never personally had to do that. Also, whether your do your service at the dealership or not, people get denied warranty work all the time. Dealerships screw everybody and it usually has to do with if they suspect that you did any service AT ALL or if they suspect you've modified your car. Some people just don't take care of their cars or lie about their maintenance and service history. |
Tags |
cpo, maintenance, warranty claim |
