BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Home Security Cameras
      07-05-2015, 07:54 PM   #89
Kolyan2k
Drives: 2006 S2000
Originally Posted by P1et View Post
You got it up and running yet? Interested to see the image quality.
Yeah it's running. I will make some and post tomorrow its dark now
      07-06-2015, 08:41 AM   #90
Kolyan2k
Drives: 2006 S2000
Decent camera I guess, motorized mechanism is silent, images without any lens tweaking, not happy about motion detection. Manual says PIR only works for like 16-17ft......with PIR on and Video Detection set at 100% I get false alerts, with PIR on and Video Detection set at 88% it cant seem to detect any motion past 23-25ft and my front door, kitchen, and walk-in closet area past 25ft...about 30-35. Would really like something more reliable in this area, something that can instantly detect front door opening at 30-38ft
      07-06-2015, 09:16 AM   #91
Kolyan2k
Drives: 2006 S2000
Called tech support...guy said that Video Motion Detection is only up to 15ft with PIR enabled 17ft and clip duration is 100 seconds max per motion. (I noticed it detects up to 20ft), Night Vision is up to 26ft....not sure if this is normal for <$200 camera. If it is then I guess I have to preposition the camera closer to door
      07-06-2015, 11:18 AM   #92
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
Pulling cable through the attic is fun.. just careful of the nails from the roof shingles!!
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      07-06-2015, 02:36 PM   #93
P1
P1's Avatar
11542
Drives: 2004 3/4 ton Duramax
This is more to do with the software you are using vs. the camera itself. Have you tried other software. Try Sighthound free for 14 days and see if that resolvrs it.
Using IR on the camera looking outside is useless. The IR reflects against the glass, and even if it did not, that is quite a distance to cover.
      07-06-2015, 06:04 PM   #94
GotE46M
GotE46M's Avatar
58
Drives: Few M cars.
Guys with the hikvision ds-2cd2432f-iw 3mp can you leave it on for months at a time? Does it heat up? I mainly want to use this for when I am traveling overseas. I have the dropcam but that heats up very fast after a few hours
      07-06-2015, 07:54 PM   #95
zx10guy
Drives: 2013 135i
I don't remember if I've downed any of the cameras providing home surveillance but going by the run time counter on my PoE switch, the two 2432 cameras have been up for about 69 days running 24/7 without one hiccup. One 2432 is in an unconditioned 2 car garage and the other is in my finished basement. So this should also tell you the different extremes in operating environment my cameras are exposed to.
      07-06-2015, 09:01 PM   #96
Kolyan2k
Drives: 2006 S2000
Are you happy with Hikvision software or you don't use that?
      07-06-2015, 10:59 PM   #97
GotE46M
GotE46M's Avatar
58
Drives: Few M cars.
Do you still need a DVR for just one camera to record or are there other options so I can check online through my phone or computer while I am away.
      07-06-2015, 11:15 PM   #98
zx10guy
Drives: 2013 135i
You have two options. First is to install a micro SD card into the camera and it will store the recorded video there. The other is to point the camera to store it on a NAS.
The 2432 can support up to 64 GB micro SD cards.
      07-08-2015, 12:04 AM   #99
P1
P1's Avatar
11542
I think the Hikvision software is probably OK if you just leave it to record 24/7 and not have to worry about motion detection. Since I do worry about motion detection, I don't use Hikvision software for that.
However, their client for the PC to just watch the cameras is very good, as is their app on the iPhone/iPad. I definitely use Hikvision for that.
      07-08-2015, 12:04 AM   #100
P1
P1's Avatar
11542
Mine have been running for a while now in the 100F+ Texas heat. Still going strong. So is my PoE switch by the way...
      07-08-2015, 12:08 AM   #101
GotE46M
GotE46M's Avatar
58
Drives: Few M cars.
Sorry noob, what is NAS? Cloud storage?
      07-08-2015, 12:14 AM   #102
P1
P1's Avatar
11542
Network Attached Storage. It's essentially a hard drive (or multiple hard drives) in an enclosure that hangs off your network. In other words, storage that can be reached from your network, whether internal or external.
      07-08-2015, 12:18 AM   #103
P1
P1's Avatar
11542
I just looked at these imagines on a PC as opposed to a mobile devices. The image quality is subpar mate. In the day, it's barely passable. At night, it's horrendous. There is something wrong with this camera... What is the resolution supposed to be?
      07-08-2015, 10:46 AM   #104
Kolyan2k
Drives: 2006 S2000
Its 720p but yeah many complain that its much worse then real 720p vid. I actually returned it today and bought Nest to try. Have it setup already.
Not much features, but its pretty simple and seems to work so far (tried for an hour maybe). Motion detection works better, camera has better built quality, sound works better, heats up pretty quickly, app is nice, motion history gets recorded as soon as motion detected, but alerts only get sent out every 30 minutes (not sure why because I want to be able to control that), also cant take snapshots
As far as subscription, I suppose when I am away I can activate the service for 1 month and unsubscribe when I get back....was told its pretty easy to do on PC (maybe app too)
Had a long chat with rep from Piper camera, looks like a nice product too with nice app etc, dont need to subscribe to anything. Problem is when motion is detected it records for 35 seconds, next recording will start if there is another (not motion based) trigger, if you dont have any other triggers then you MUST manually reset the motion trigger. That just made it useless to me.
      07-08-2015, 11:14 AM   #105
Kolyan2k
Drives: 2006 S2000
I noticed Nest heats up too, why does the heat bother you ? Maybe its normal operating temp. for them
      07-08-2015, 05:16 PM   #106
Kolyan2k
Drives: 2006 S2000
Nest....dont know which position is better....
      07-09-2015, 02:35 AM   #107
P1
P1's Avatar
11542
The quality is noticeably better. I'd go with the first option. That way, you should see anyone who enters your spot right off the bat. Also, the harsh light coming through that window might be hard for a lot of cameras.
      07-09-2015, 07:34 AM   #108
Kolyan2k
Drives: 2006 S2000
Yeah I went with 1st option. I don't want camera looking in my bedroom even when it's off
Pretty sure I will keep Nest. Don't know why it has 2.5 stars in Amazon, Dlink has 3.5 and its much worse
EDIT: Still keeping it for now, but not as happy....motion detection seems to be glitchy and customer support is clueless, I expected better from Google. I have pretty much the same problem as with Dlink, motion past 20-25 feet is not detected or not always detected
      10-09-2015, 11:29 AM   #109
P1
P1's Avatar
11542
How have the cameras been running for you? Did you get them dialed in?
      10-09-2015, 11:43 AM   #110
Kolyan2k
Drives: 2006 S2000
Nest is decent, magnet mount worked really well for me (Ended up mounting on entry door metal frame). App is nice. Unfortunately only paid recording. Camera is only useful for me when I go on vacations, so have to subscribe and unsubscribe each time. I still havent paid though, there seems to be some extended free trail.
