06-15-2019, 04:33 PM | #23 |
Rep 1,800
https://www.newtis.info/tisv2/a/en/f...nit/1VnXVC8jSu
On quick glance, this doesn't mention reverse thread.
06-15-2019, 04:50 PM | #24 | |
Rep 368
06-15-2019, 05:16 PM | #25 |
Rep 1,800
It's torqued to 65Nm (48ft-lbs), so the little ratchet will need some help.
06-16-2019, 04:01 PM | #27 |
Rep 368
Now it looks like I have no start.
I bled the fuel system, but it just keeps cranking with no fire. Not really sure whats up with it. Its giving an error for pressure and temp sensor but the values pretty close so Id think it would start. Can anyone confirm for me? There's two fuel lines going to the pump, one has a tee in it. Is the line with the Tee hooked up to the top port or the bottom port? Put another way, I just need to confirm that the supply line goes to the bottom port. Really dont want to pull this thing back off Last edited by kdog_x; 06-16-2019 at 04:22 PM.. |
06-16-2019, 05:49 PM | #28 |
Rep 123
06-16-2019, 06:29 PM | #30 |
Rep 1,800
How many bar is the system building up as you crank it?
You can see this in ISTA by choosing DDE on module map and opening it's own functuons with the button on bottom left. (Not the leftmost).
06-16-2019, 08:42 PM | #32 |
Rep 1,800
The rail pressure needs to be somewhere around 150bar (I can pull exact number) or more for the injectors to "fire".
06-16-2019, 08:58 PM | #33 |
Rep 368
06-16-2019, 09:19 PM | #34 |
Rep 368
It reads 11-12 bar when cranking. So does that sound like maybe my new pump is no good? i see it has the requested pressure while running listed at 299 bar.
06-16-2019, 11:06 PM | #35 |
Rep 1,800
Yea, unless you left the metering unit or the rail valve unplugged, the pump isn't making any pressure.
06-17-2019, 10:34 AM | #36 |
Rep 368
Yeah, I tried swapping the metering unit from the old one in case it was bad, with no luck. The rail valve doesn't get removed as part of the replacement process, so I assume that is probably fine. I pulled the new pump back off, The seller of the pump asked me to check the piston, he said if there was any debris from the old pump it could clog up The solenoid valve or re-run valve. I'm not really sure what those are, so I asked for instructions but I'm still awaiting a reply. I just hope this pump didn't cause any damage to the injectors or fuel system from being cranked, my proactive replacement might have turned into an expensive issue
I reinstalled the old pump last night, but I have not tried to crank it yet |
06-17-2019, 10:41 AM | #37 |
Rep 1,800
I don't think you would have damaged anything. And if you didn't have any metal from old pump, since it didn't go bad yet, you didn't ruin anything.
I've changed some of these on VW CR TDI (same pump) and it's straight forward when pump works. Since it's keyed, it's impossible to get wrong.
06-18-2019, 09:48 AM | #38 |
Rep 368
Well, I tried swapping the valve from the old pump to the new with no luck. So I ended up re-installing the original pump, car started up fine. I disassembled the new pump and inspected the piston and roller, everything looks good. No debris or scratches. Not sure what is wrong with it.I'm working on getting the pump exchanged under warranty.
I caused myself a major headache though, the plastic sealing cap that goes through the timing cover over the pump mounting bolt is stripped from repeated installation and removal. I tried a bolt extractor socket on it and mangled it worse. Not sure how I'm going to get that out,I am thinking the only way I can get enough access to maybe clamp some locking pliers on it it would be to remove the intake manifold and hood. (or the transmission). Definitely a bad spot to have a problem |
06-18-2019, 10:21 AM | #39 |
Rep 1,800
Have you opened your original fuel pump? If you've been putting quality fuel, it probably won't look that bad. I'd be curious.
The new idea about bubbles killing it is interesting too.
06-18-2019, 12:22 PM | #40 |
Rep 368
I didn't open the original one up, though I'm curious. I was going to do so but then I got to that plug and stripped it and I spent about 2 hours trying to remove it . At that point I was frustrated and done messing with it. At least the pump thats on there works.
Its a huge threaded 35mm plug with a 17mm hex head in the center, all plastic. When the new pump comes in I think I may try to drive a few self tapping screws into it and clamp onto those to grab to remove it. Hope that works! Don't want to do anything destructive to it until I have a replacement in hand. If I end up having to remove the intake manifold, I noticed the procedure mentions soaking it in cleaning solution and water, and then brushing it. Any Ideas what bmw Universal cleaning solution is? Or a good substitute? |
06-18-2019, 01:46 PM | #41 | |
Rep 123
Another option would be to heat up a nut setup like above that is slightly oversize (18mm?) and "melt" it in the plug. |
06-18-2019, 01:55 PM | #42 | ||
Rep 368
06-18-2019, 02:46 PM | #43 |
Rep 368
Decided to sacrifice a socket, filled it with JB Kwik and stuck it on there. If that doesn't work then I'll be putting my new pump up for sale when it arrives lol.
