01-14-2019, 11:38 PM | #1 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
New BBS LM - 19" x 9.5 (x2) Plus front spec of your choosing!
I bought these for my F31 wagon but I have decided to go with LM-R instead. LM's will always be a timeless design and looks good on everything. The wheels are brand new - in boxes. Pics are shown with my last set of LM's installed on the car. *** I sold 2 of the wheels and have 2 remaining. Therefore I can order you a matching pair in the size and spec of your choosing! 8.5", 9", 10", 11", etc. Wheel Model: BBS LM in Diamond Silver with Diamond Cut Lip (Black with Gold BBS logo center caps included) Wheel Spec: * 19 x 9.5 et32 - (X2) ** I can order a second pair in the spec of your choosing! Wheel Condition: NEW - In boxes! Tires: Not included in price. Location: Santa Barbara, CA - I will ship. I also travel frequently throughout the state and would be open to delivering if it works for our schedules. Price - Wheels Only: SOLD! Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr 9.5 square in First Pic (all other pics are my old set in 8.5/9.5). I put my two rear wheels/tires on one side for pics to illustrate how they will look - which is awesome! Untitled by slicerM, on Flickr 8.5/9.5 Pics>>> BBS LM by slicerM, on Flickr BBS LM by slicerM, on Flickr BBS LM by slicerM, on Flickr
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 02-06-2019 at 08:22 PM.. |
01-16-2019, 06:56 PM | #2 |
Rep 99
hey, I've been using your square setup as inspo for what I'm looking to get. LMs are out of my price range and I'm looking at the CH-Rs.
Did you have any rubbing, fitment, or clearance issues (with brakes or strut)? Did you have to do any fender rolling or anything to make these fit? The CH-Rs et35 and my car is an f32. not sure if the additional offset is a dealbreaker or not. Only seeing mixed opinions everywhere. Thanks! |
01-17-2019, 12:57 AM | #3 |
Rep 6,734
The wheels arrived! 2.5" lips - Available Now -
9.5 et32 by slicerM, on Flickr 9.5 et32 by slicerM, on Flickr
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
01-17-2019, 01:12 AM | #4 | |
Rep 6,734
Did you have any rubbing, fitment, or clearance issues (with brakes or strut)? No issues. They cleared my track pack brakes. 9.5 et35 with a 255.35.19 is the highest offset that would clear the strut. It was only a few mm away from the strut. et32 gives you more inner room but they were a little aggressive on the outside (no rubbing). It would look better with some camber. I am on HR lowering springs with minimal camber, no camber plates. Did you have to do any fender rolling or anything to make these fit? Nope.
'23 X7
01-17-2019, 09:35 AM | #5 |
Rep 49
Drives: Black 2015 328i Sport Wagon
Wheels look great... but the stance is better. Would you provide H&R Spring model numbers you used? Also, did you change out the shocks or bump stops? Really love the stance!
01-17-2019, 09:41 AM | #6 |
Rep 6,734
Thx - There's only one option from H&R for the F31 (in US at least). I did do shorter OE BMW bump stops. Factory adaptive shocks. I'm very happy with the results
'23 X7
01-17-2019, 09:48 AM | #7 | |
Rep 49
Sorry, one more question, I see the wheel dimensions in your post, what's the tire size used for the square setup? I really want this look. Last edited by 2015F31; 01-17-2019 at 09:56 AM.. |
01-17-2019, 09:59 AM | #8 | ||
Rep 6,734
* Bump Stop Part Numbers: Rear - 33536762722 Front - 33536784122 My car has the adaptive M-sport suspension from the track package. 255.35.19 Michelin 4S tires (as stated in a few posts above your question)
'23 X7
01-17-2019, 10:02 AM | #9 | |
Rep 49
Thanks again for all your help. |
01-17-2019, 10:10 AM | #10 | ||
Rep 6,734
That being said, matched shocks and spring packages are a good move. That way you know the dampening and spring rates are well matched. Adaptive suspension is helpful because I have the option to stiffen the shocks. However overall it's a wagon, I was not seeking track performance. I have an M3 for that purpose.
'23 X7
01-17-2019, 11:11 AM | #11 |
Rep 1,934
Do you know what your fender to ground measurement is? Highest part of wheel well to the ground
01-18-2019, 01:38 PM | #13 |
Rep 6,734
No extended lugs needed unless you use spacers. Help me understand why you are asking. Lug length is not impacted by wheel offset.
'23 X7
01-20-2019, 02:22 PM | #14 |
Rep 6,734
Pics of actual wheels. Wheels in stock and ready to ship.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 01-20-2019 at 02:35 PM.. |
01-22-2019, 07:10 PM | #15 |
Rep 6,734
PRICE DROP - $3575!
'23 X7
01-24-2019, 11:25 PM | #17 |
Rep 6,734
Yes, absolutely.
'23 X7
01-26-2019, 11:37 AM | #18 |
Rep 6,734
More pics of the Actual Wheels:
Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr
'23 X7
01-31-2019, 12:30 PM | #19 |
Rep 6,734
'23 X7
02-03-2019, 12:26 AM | #21 |
Rep 6,734
Sold!
'23 X7
