01-24-2024, 03:21 AM | #1 |
Rep 35
Coding for a dummy
Having owned my car a couple of years now, 2015 330d, there are a couple of things I would like to change.
So far black grilles and a Royal Steering wheel refurb are as much as I felt the car needed. There a couple of thing that are slowly becoming annoying... I would like the car to remember my start/stop to be off and to remember my ventilation settings. I have done some searching and think I need to go down the route of ODB and Bimmercode but looking for a grown up to confirm this. Also the fact that fairly IT inept bloke can carry out such a task. I am sure if I start playing with Bimmercode there will be other bits and pieces, but if I can fix those 2 thing I would be happy. Or any other coding suggestion that I havent considered yet. Cheers |
01-24-2024, 03:31 AM | #2 |
Rep 8,636
For sure, if you want the easiest way to apply coding then Bimmercode and an OBD dongle all day long. It’s very simple.
Other things you can do: Media off on door open Puddle Lights on in reverse Angel Eye Brightness Heated Seat temps Digital Speed in Instrument Cluster Change idrive Startup logo Amongst others…. |
01-24-2024, 03:52 AM | #3 | |
1942
Rep 2,115
You need Bimmercode on your mobile and this dongle: https://www.amazon.co.uk/iCar-Pro-4-...%2C132&sr=8-10 That's what I use and it's faultless However; I've not been able to get my F31 to remember my ventilation settings even though I've set the coding to what I've read it should be But everything else I've done (start/stop off / brightness of the DRLs / mirrors folding/unfolding on opening/locking etc) all works and it's a cinch to do
jaf6526.00 |
01-24-2024, 03:53 AM | #4 |
Rep 3,664
Download BimmerCode and then you can run it in Demo mode. You will see just how easy it is and it should give you the confidence to have a go. It really is easy 👍🏻
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
jaf6526.00 |
01-24-2024, 03:54 AM | #5 |
Troopa
63
Rep 85
I have coded start/stop permanently off and i did this via the Bimmercode app. There are many other features on the app you may find useful so you can have a play around to see what suits you.
In regards to the OBD device itself, i've tried a couple of them and the best one i have found that works faultlessly every time is this one - https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
EBII F30 340i Shadow Edition |
01-26-2024, 04:23 AM | #8 |
Rep 125
Yes i have been using Carly for a long time but i have recently come over to Bimmercode as i felt Carly has gone to universal now with all makes and models.
You can also code in Cornering lights where your fog lights come on at low speed cornering. Once this is activated then your fog lights also automatically come on when you put it into reverse. You can change what front lights come on when you unlock it aswell. Also change the setting so that your Welcome lights will come on during the daylight instead of just night time. Set beeping to active when you lock and unlock the car. There is loads you can do. I have not used expert mode yet but i havent really looked into it. But i have heard there is alot more that can be changed. |
