BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > MG flasher - mobile App for B58 Fxx/Gxx tuning -- NOW LIVE!!!
      05-26-2019, 09:07 AM   #353
pgadv
Drives: 2018 340 xDrive M Sport MPPSK
How can we check if our vehicle has the Otto Particulate filter?
      05-26-2019, 09:28 AM   #354
pgadv
I've seen some discussion about regapping or use of cold plugs for a tune. Is this required with a Stage 1?
      05-29-2019, 02:38 PM   #355
Jarek@JRAuto
Jarek@JRAuto's Avatar
Drives: G20 340i
B58 cars are equipped with OPF (Otto Particulate filter) starting as far as I know in July 2018 onwards to meet Euro 6 vehicle emission standards mostly in European countries.
      05-29-2019, 02:50 PM   #356
pgadv
Thank you
      06-03-2019, 04:02 AM   #357
henkherrie
Netherlands
19
Drives: 2016 M140i
No
      06-03-2019, 07:24 AM   #358
pgadv
Thanks
      06-05-2019, 07:19 PM   #359
chuck_GT
chuck_GT's Avatar
Drives: BMW X3MC
Still not supporting IOS?
      06-08-2019, 04:12 PM   #360
Works
Works's Avatar
30
Drives: G30 530e B48 + E82 135i N54
I have a B48 in a G30 chassis, any chance on seeing support for that combo within this year?
      06-09-2019, 05:45 AM   #361
janea1207
Drives: BMW 340i
MG flash
Originally Posted by D's Bimmer View Post
Just flashing my 2016 340 Xi 6sp thanks to Jarek! Great service!!!!! This is the perfect tune for my spirited driving needs! Stage II with stock hardware. Will be adding a high flow sportcat later this summer.
Any feedback?
I am coming from a custom tuned MHD N55 and prior to that a custom tuned N54.
The installation was easy and took about 35 minutes in total.
I have a full tank of Petro Can 94 in the car.
Spent the past couple of hours on the highway. First 100kms was easy driving. Allowing for adaptation.
The last 100k was spirited but not crazy due to weather and still allowing for adaptation.
The car has a very clean, assertive power band. No more gaps or hesitations in power. It is smoother than my two previous cars. Able to pass with ease and authority.
The tune is exactly what I want from this car. I don't plan to go crazy with it. But it will put you in the back of your seat quickly!!!!!
Jarek, a fantastic job my friend!!!! Best value for hp! Look forward to seeing how things progress with the OTS Maps based on further refinements and feedback.
No regrets about not waiting for the other two big tuners in beta at the moment. Have experience with them both. MG Flasher is right on the money for me!
How much $ is the MG flash?
      06-09-2019, 06:15 AM   #362
BackBlue
BackBlue's Avatar
Drives: E46, '13 E70 N63, '19 F33 440
Flashing License 249 USD/EUR + OTS Map 99 USD/EUR
      06-09-2019, 09:06 PM   #363
D's Bimmer
Drives: 2016 340 Xi
iOS???? Can we get a response to this instead of asking and nothing.
You advertise on your site like it is already there. When will you have it up on the App Store?
I have the Android with an older tablet and do not want to spend money and something newer.
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
      06-10-2019, 02:45 PM   #364
Bavarian MW
lurker
24
Drives: 16 s1000r 17 M240i 18 340i
There was a new MG Flasher release today with revised maps for st1 and st2, plus ethanol maps too.
I looked the other day, you can get an Android tablet for under $50 that will work. And you could spend even less if you are thrifty at finding an online deal or a good used one. You are missing out by waiting IMO. --MW
      06-10-2019, 02:53 PM   #365
Jarek@JRAuto
Drives: G20 340i
MG Flasher update release ver. 1.2.13
• Ethanol Blends support – OTS Stage 1 E30, OTS Stage 2 E30 – supported blends E20 up to E30
• New OTS stages classification and maps update:
Stage 1 ver 2.3: cars with stock hardware
Up to 430HP 610NM @ Crank
Up to 410HP up to 580NM @ Crank - cars equipped with Otto Particulate Filter (OPF)
Stage2 ver 2.2: Use only with high flow downpipe or high flow catalytic converter
Up to 470HP 650NM @Crank
• Added marker for OTS Stage 1 *8HP Flash NOT installed (550NM limit)* - mark this option when 8HP50 TCU flash is NOT installed
• Logger – minor bugs fix, a few data channels added
• OTS maps optimized for xHP transmission tuning software
Stay Tuned , more coming soon!
      06-10-2019, 03:49 PM   #366
Brett530
Brett530's Avatar
208
Drives: '17 F30 340i
Good stuff! Thanks. I've been feeling left out of the little updates running the torque limited custom map. Having it as an option is a perfect solution. My tires are going to hate you.
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
      06-10-2019, 09:30 PM   #367
bmc340
Drives: 2016 340i xDrive
So for those of us WITH the xHp trans tune and do NOT have DP, what stage and option do we choose with this new set up?
EDIT: Stage 1 with xHp marker option?
Also, what are the hp and tq numbers for stage 1 E30 tune?
      06-10-2019, 09:49 PM   #368
InstigatorX
Drives: 2018 440i GC xDrive
Stage 1 withOUT setting the xHP flag.
bmc34016.50
      06-11-2019, 07:22 AM   #369
D's Bimmer
Drives: 2016 340 Xi
How do I get the licence for the new Stage 1? I already have the Stage 2 licence but since you have changed the maps, do so have to pay more?
      06-11-2019, 10:30 AM   #370
Brett530
Brett530's Avatar
208
Jarek@JRAuto
I'm confused as to why this was put in for Stage 1, but not stage 2. I was assuming this would torque limit so that the car would drive smoother under heavy torque demand. Stage 2 is where it is more likely to hit the limit. Am I misunderstanding what this check-box is for?
      06-11-2019, 11:07 AM   #371
bmw22915
Drives: 440xi GC
Jarek@JRAuto
I'm sure I'll be corrected if I'm wrong, but it should be assumed you have a trans flash when you're going to run stage 2. If you don't have a trans flash, just stick to stage 1.
      06-11-2019, 06:42 PM   #372
InstigatorX
Jarek@JRAuto
Stage 1 AND check the "I do NOT have xHP" checkbox.
      06-12-2019, 10:40 AM   #373
Jarek@JRAuto
Drives: G20 340i
Please see the new Stages Classifications below:
Stage 1: cars with fully stock exhaust system
Up to 430HP 610NM @ Crank – cars with stock exhaust system
Up to 410HP up to 580NM @ Crank - cars equipped additionally with Otto Particulate Filter (OPF)
8HP flash recommended to take full advantage of the maximum TQ , otherwise please select the marker
Stage2: Use only with high flow downpipe or high flow catalytic converter
Stage 2 minimum requirements are: downpipe + 8HP50 software so we decided to not implement additional marker in ST2 since most of the users who willing to have ST2 power and tq level have 8HP50 already programmed.
I hope this helps
      06-12-2019, 11:03 AM   #374
Brett530
Brett530's Avatar
208
I hope this helps
Yes, thanks. I didn't see/notice that the trans flash was considered part of the stage 2 requirements. That is the next item on my list now that I got the downpipe installed.
