BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > How to keep using expired E-Sys Launcher Premium by reverting system date (hack)
      01-20-2018, 03:23 AM   #67
Ian-F80M3-UK
Drives: F80 M3 2014 Black
Hi Tony, The date for the . dir is 01/01/2010 03:00.
When I do dir c:\programdata /tw /a it's the same date and time.
For the RearmLauncher.cfg file:
Created: 01 Jan 2010, 02:00:00
Modified: 19 Jul 2017 (date I tried to change to in a previous test, but note: this time, and the previous time I reported above, I kept today's date unchanged)
Accessed: 01 Jan 2010, 02:00:00
Hope this helps!
      01-20-2018, 03:56 AM   #68
Tony Twoclicks
Drives: 2012 F30 320i
Hope this helps!
The modified date of RearmLauncher.cfg is the problem. Why is that modified? Delete the file and extract it from the package again. It should be dated 01 Jan 2010. Despite the error, I think my script did work and the Launcher probably works.
Cheers, Tony
      01-20-2018, 04:03 AM   #69
Tony Twoclicks
Originally Posted by jkwhar View Post
First off, thanks for the script!!
I'm having an issue with the EST token. I've tried deleting the freetoken.est and recreating it but keep getting the "an error occured while processing the EST file" when trying to read FDL code.
Any help would be appreciated!
I'm running the 2.6.2 with psdzdata 63.
Not sure about this one. Could be a compatibility issue between psdzdata 63, your Launcher version (does it support V63? Does it support your E-sys version?) and your E-sys version (does it support V63?).
You might also want to try keeping your system date reverted while coding. Could be that E-sys has a problem if the system clock is past the expiry date of the EST token file.
      01-20-2018, 05:15 AM   #70
Ian-F80M3-UK
progress..
Hi, some progress I think (although I still always get the Windows System folder warning in my previous screenshot).
Using E-Sys Version 3.31.0 (build 50446), tried setting date to 19/07/17, got this when E-Sys Launcher tried launching E-Sys:
WARNING!!! There are 30 file(s) with suspect status. These files will not be loaded and will cause instability. It's highly suggested that you abort launching E-Sys and reinstall. Continue?
then the error in the attached screenshot.
So I tried setting the date to 22/09/17. Got further, Windows asked if Java could access local networks. Then this E-Sys Launcher Error:
Unsuppoerted Version - E-Sys Version 3.31.0.
I'll try and find a previous version of E-Sys and go again.
      01-20-2018, 05:40 AM   #71
Ian-F80M3-UK
It works! I installed E-Sys 3.28.1, using date 19/09/17, on Win 10 64-bit. Thanks Tony, much appreciated!
      01-20-2018, 09:47 AM   #72
Tony Twoclicks
Yeah, as E-sys Launcher Premium is no longer developed by Tokenmaster, the latest E-sys versions are not supported. Please read Tokenmaster's blog for more info about what works and what not. My script can't change that.
If you need support for higher E-sys versions, please buy E-sys Launcher Pro from Tokenmaster.
The reason you still get the error about locked system folders is due to the Last Modified Date of RearmLauncher.cfg. My script compares this to the dates of c:\ProgramData afterwards to see whether it was succesfull. In your case there is a mismatch, resulting in the error.
I'm curious, what program do you use to extract the package and what's the Modified date of RearmLauncher.cfg right after extraction on your system?
      01-20-2018, 10:17 AM   #73
Tony Twoclicks
Originally Posted by spudvti View Post
well then.. thanks for older launcher support.
but
still looping on token creation
once again
e-sys 3.27.1
Psdzdata_v3.59.5_lite
launcher premium 2.5.3
win7 x64 us/en
1.50 rearm
thinking about reinstalling windows
PM sent
      01-20-2018, 10:57 AM   #74
Bl33p
BMW Lover
Bl33p's Avatar
Drives: 2014 328i M-Sport
I keep getting an error running the 1.5.0 file. “The syntax of the command is incorrect.”
The dates show as 1/10/2010 but the launcher still says there is date manipulation.
      01-20-2018, 11:35 AM   #75
C-Poppy
Drives: 650i xDrive Gran Coupe
Followed directions to the T!!! Worked perfectly!!! Thanks Tony Twoclicks for the blessing!
One thing that I'll mention for anyone that is having issues. I have to keep my date reverted while running E-Sys. Otherwise it won't work and continue to search for the key. Solution...Just revert your time back anytime you need to use E-Sys...
Hope this helps...
      01-20-2018, 12:47 PM   #76
Ian-F80M3-UK
For your package I use the native Windows 10 'Extract' option that pops up for zips in the File Explorer. I used the same for E-Sys Launcher, and had to use WinRAR for the e-sys 3.28.1.
I just re-extracted your rearmer 1.5 into a temp folder and the timestamp is now 18:43, 20/01/18 (i reset the clock to get back on the net, chrome doesn't like it otherwise). Let me know if you need anything else
      01-20-2018, 01:29 PM   #77
Celestion
Drives: '22 M3 Comp
I also get this error...
Does anyone know how to fix this?
The script does not work, despite executing it with admin privileges and disabling Windows Defender.
      01-20-2018, 03:58 PM   #78
Tony Twoclicks
Hope this helps...
Thanks for the feedback. I think this is E-sys checking the validity-date of the token file which is created by the Launcher and ends on 30-12-2017. So it would make sense to turn the clock back to fool E-sys into thinking it's still valid.
Cheers, Tony
      01-20-2018, 04:03 PM   #79
Tony Twoclicks
A screenshot or pasted text of the entire script's output would be nice to see what's going on. It looks like one of the steps fails. Also, what systems are you on?
      01-20-2018, 04:30 PM   #80
Tony Twoclicks
OK, so it seems like the native Windows extractor doesn't retain the original Modified Dates of the files it extracts. That's typical...
You can use WinRAR to extract and you should be fine. Too bad this forum won't allow to attach the .RAR format to a post, that would solve the problem immediately. Don't worry, I'll use another method of doing the self-check in the next version
      01-20-2018, 04:50 PM   #81
Celestion
Drives: '22 M3 Comp
You can use WinRAR to extract and you should be fine. To bad this forum won't allow to attach the .RAR format to a post, that would solve the problem immediately. Don't worry, I'll use another method of doing the self-check in the next version
I modified your batch file and I was able to get the script to work.... almost.
Now I can launch e-sys, but I am unable to FDL code and instead I am given a FreeToken.est error.
      01-20-2018, 04:50 PM   #82
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Hey Fellas
Thank you Tony for doing this hack. However I noticed Tokenmaster is now advertising Launcher Pro 3.0.
Is there a reason why we can't use that? Or what is the reason for continuing to use Premium? I haven't coded my car in a while, but I found some other mods I'd like to do, so am curious as to best course of action prior to starting again.
-A
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      01-20-2018, 05:58 PM   #83
Tony Twoclicks
Originally Posted by ooshnoo View Post
Hey Fellas
-A
Tokenmaster stopped development and support for the free Premium version. The Pro version is still actively developed and supports the newer E-sys and pdszdata files. It requires an activation code and you'll have to donate 50 bucks to a charity to get it directly from Tokenmaster.
      01-20-2018, 06:00 PM   #84
ooshnoo
ooshnoo's Avatar
2018 BMW X5  [0.00]
Ah. Gotcha. Guess I'll use your batch file!
___________________
2018 F15 M-Sport
      01-20-2018, 06:02 PM   #85
jkwhar
Drives: F30 328i Xdrive | F15 x35i
It is possible that my psdzdata might be too new for the esys version (esys 3.28.1).
I tried looking online to see which esys works with psdzdata 63 as I need one of the caf files for the 6wb dkombi.
Do you know if I can use psdzdata 60 and just pull the 1 CAFD I need from 63?
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      01-20-2018, 06:15 PM   #86
Tony Twoclicks
I'm not sure, but I wouldn't recommend mixing different pdszdata versions. That's a disaster waiting to happen if you ask me....!
Do a search on Google and read Tokenmaster's blog to see what combinations of E-sys, launcher and psdzdata work for other people. I think your Launcher is too old if I had to make a guess.
      01-20-2018, 06:23 PM   #87
sevenn
sevenn's Avatar
64
Drives: 2023 M340i
I recently install E-sys 3.28.1 (PSdZData 63.3) with Launcher Premium 2.7.1 and your Rearm 1.5.0. Everything works perfect!
      01-20-2018, 06:29 PM   #88
jkwhar
Yeah, that didn't work lol.
I'm waiting on ShawnSheridan to send me a link to the newst esys.
Thanks for your help!
clock, date, esys, launcher, premium
