07-01-2015, 12:36 PM | #221 | |
Rep 3,659
Drives: 981 Cayman GTS
My question is should I revert my changes in EGS module back and do VO coding for Sport Automatic Transmission? |
07-01-2015, 07:16 PM | #222 | ||
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
07-01-2015, 11:12 PM | #223 | |
Rep 962
Thanks! |
07-02-2015, 02:05 AM | #224 |
Rep 1,894
07-02-2015, 08:38 AM | #225 |
Rep 6,990
Rsnic - the above cheat sheet has the NOAA Weatherband coding listed as "doesn't work", but it worked fine on my 1/13 build non-NAV 335i. It now shows up under the Radio menu and lists 10 channels to choose from.
07-02-2015, 10:43 AM | #226 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
That's odd because that was one of the first items I tried to code and it did nothing; perhaps it is the difference between 13 and 14 models (CIC vs NBT) or because I have Nav system. Will give another try -- it's well worth it because that is very useful when traveling Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
07-02-2015, 10:51 AM | #227 |
Rep 40,763
The Weather Band works only on CIC. On NBT, it will not work.
07-02-2015, 11:11 AM | #228 | ||
Rep 640
Good to know, I'll clarify that next revision.
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
07-03-2015, 07:52 AM | #230 |
Rep 98
I need help. I coded my 320 f30 with internet and everything works. My system is CIC.
I used these codes: Today I tried to activate internet on a 125i 13/14 (F20) using the same codes. Just last function did not appear in the module (BT_DATA_SERVICE - part - 8). The internet function does not appear in iDrive. And Bmw Live is not selectable. What could be happening? In fact the iDrive not changed.
07-03-2015, 11:15 PM | #231 | |
Rep 1,369
07-03-2015, 11:22 PM | #232 | |
Rep 1,369
There are just somethings where the auto industry has failed to catch up to . . . the late part of the 20th century. |
07-05-2015, 12:27 AM | #233 |
Rep 906
ASD: Wow.
I dabbled with ASD last year with no results, turned out I had to FDL code the Engine and Model Range.
Set my F30 to be a M3 and wow is there a big difference! Are there other choices besides M5/M6 and M3/M4? EDIT: I tried the M5/M6 combo as in the sheet, but it doenst do much. Couldnt tell the difference between that and stock.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 07-05-2015 at 12:37 PM.. |
07-08-2015, 12:07 PM | #234 | ||
Rep 640
2018 Audi RS7 4.0T
07-09-2015, 11:51 AM | #236 | |
Rep 1,369
07-09-2015, 11:52 AM | #237 |
Rep 1,369
07-09-2015, 12:02 PM | #238 |
Rep 141
07-09-2015, 02:18 PM | #239 | |
Rep 640
Sport+ will hold the gear at redline in Manual Mode Only. It will otherwise never hold it at redline in Comfort, Eco Pro, or Sport. And yes, it will always downshift while decelerating automatically because the car would stall.
2018 Audi RS7 4.0T
07-12-2015, 03:44 PM | #240 |
Rep 1,479
Hi,
Really like the automatic wiper function; it adjusts speed based on amount of rain on windshield. Perhaps, it the way I have seat and steering wheel adjusted, but it is extremely difficult to see the green LED on the wiper stalk that indicates the auto wipers are on --- so, is there a way to code something that will display an icon on the dash? My wife's Volvo has both automatic wiper and an icon that shows up on the dash.
Al
07-12-2015, 04:21 PM | #241 |
Rep 3,659
Couple of weeks ago, I FDL coded Sport Auto Transmission and I was quite happy with that. However, I still wanted to VO code it by replacing 205 with 2TB.
Yesterday I did VO code 2TB on top of my FDL coding. I coded EGS successfully. When I was coding ICM, car gave the error "Chasis stabilization: Drive moderately". Then I coded KOMBI and finished coding. In E-Sys, I cleared the error thru External Applications section. I drove 150+ miles since yesterday and there is no CEL or any errors showing up. However, I feel like the car was shifting gears faster in Comfort mode with FDL coding. I knowiIt doesn't sound reasonable and I think both FDL and VO coding the SAT should have the exact same effect. Maybe they're the same and it's only in my head I just wanted to share my experience and see if anyone else tried coding SAT both ways (FDL and VO). |
07-13-2015, 08:00 AM | #242 | |
Rep 113
Drives: E90 320D, F25 X3 30D
By far the best thing to code, if not already present on a car. |
