BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6WB Cluster Coding Issues
      12-19-2019, 01:37 PM   #1
vanderberg
Drives: 2015 BMW 328i F30
I'm in the process of coding my 6WB cluster with esys. (2015 BMW 328i)
(esys version 3.27.1) (psdzdata version 63.3)
I currently have HU_ENTRYNAV and BKOMBI and saw in a few other posts that you have to add 6WB to the FA.
I did that and now I read somewhere else that in order for DKOMBI to show up and replace BKOMBI, you must VO code the HU_ENTRYNAV first.
I did that but BKOMBI still shows up.
At this point, I'm lost and could use some assistance. Thanks in advance.
      12-19-2019, 03:53 PM   #2
RuleNormaliai
RuleNormaliai's Avatar
235
Drives: 2022 G20 330E
Launch esys -> Connect -> select expert mode -> select coding -> select read FA -> select save FA -> select edit FA -> add 6WB to your FA -> right click on FA and select Calculate FP -> save FA (floppy disk button at the top left) -> select expert mode -> select VCM -> open your saved FA there -> select MASTER tab -> right click FA -> select Calculate FP -> select write FA.
After that you will see a message at the bottom left (FA FP Written)
Go to coding section, read SVT (VCM) and do the further work, it should show DKombi.
you will have to flash it too to!
      12-19-2019, 09:06 PM   #3
atzebmw
Drives: Tesla Model 3
There’s no need to flash it or something else.
Try to read SVT or VCM (both buttons).
      12-19-2019, 11:15 PM   #4
vanderberg
I've tried both things. Still no luck unfortunately.
      12-20-2019, 01:12 AM   #5
RuleNormaliai
235
As i know coding writes short vin to 160D0WT and flashing writes long vin to other chip.
      12-20-2019, 02:50 AM   #6
atzebmw
However, i did retrofit the 6WB and didn‘t need to flash.
And i think also no other who did it.
      12-20-2019, 03:18 AM   #7
RuleNormaliai
235
Does it show all service requirements and other things that it should show?
      12-20-2019, 06:23 AM   #8
atzebmw
Yes, everything works perfectly.
Except the problem with the HUD and the covered navigation arrows.
2015 LCI
      12-20-2019, 06:58 AM   #9
atzebmw
Then try the following...
First check whether the following checkmarks are set.
Under Options -> Settings -> Options
"Update VCM after TAL-Calculation"
"Update MSM after TAL-Calculation"
If not then please set it (see picture).
After that load and activate the FA (with 6WB).
Read SVT or read ECU.
Mark the ZBE and code it.
Then try again to read SVT or read Ecu and look if the DKombi appears.
      12-20-2019, 10:09 AM   #10
atzebmw
Just got another idea and question.
Your BKombi is a 6WA (extended cluster) and you already have the optical MOST fiber cable installed or not?
      12-20-2019, 01:54 PM   #11
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Did you remove 6WA from your FA when you added 6WB?
      11-18-2021, 03:27 PM   #12
Sepehrtab
Drives: BMW 440xi
Hello everyone,
I have a 2017 440Xi and I had retrofit the 6WB cluster around 3 months ago, suddenly one day my service got reset and it was telling me that I have to do the oil change, and soon after that dealership called me to book me in for service because they got a call from the car that it needs service and I told them what happened and they had to reset the service. Yesterday the same thing happened and now they say we have to do diagnostics which you know it will cost a lot and I know it's because of the cluster because every time this happens, first cluster goes blank for a few seconds. I am not sure if it's because of any mistake that I did during coding or not. If anybody can help I would appreciate it a lot.
