BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F31 n20 to n55 swap coding advice.
      10-09-2023, 03:43 PM   #1
Markelldawe
Drives: Bmw E30
Hi all, I’m looking at the feasibility of an n55 swap into an n20 f31 touring.
I’m in Australia so we didn’t get the 6cyl touring.🙁
I’m just in the planning stages and after coding advice. I’m looking at buying a complete damaged 435i or 335i donor car and swapping everything over. Swapping engine, trans, driveline, brakes, wiring etc isn’t an issue. What is the easiest way to go about coding to make it all work? Keep in mind I will have the full set of modules out of both the n20 f31 and the donor n55 435i/335i. I haven’t had any experience with f30 coding before so please keep it simple! I am planning on using a shop or sending the modules away to get coded so any advice would be helpful thanks.
      10-25-2023, 03:39 AM   #2
TheNine90
Drives: bmw
The coding shouldnt be that complicated. Only the drivetrain modules need to be code, You can just change the typecode and code them.
      10-25-2023, 08:57 AM   #3
JuniorTech
Drives: F30 340i Msport & G05 X5 40i
i can help you for coding. chek your PM
